Question about HP Photosmart D7360 All-In-One InkJet Printer
Can't print on home network
We have a home network for our two laptops. We have three printers connected through a printer port hub (an HP D7360, an EPSON photo printer and a Canon i860). I've previously been able to print just fine from my laptop. I can print to the Canon; I have not tried printing to the EPSON because that's my husband's printer; even though I've been printing to the HP D7360 just fine, when I recently tried to print a document (a photo) - as I have done many times before - it will not print. I CAN successfully print a test page which tells me that this printer is correctly installed. But when I try to print a document, the printer doesn't even blink. When I send a document to the HP, I receive a message saying that my document has printed out, even though it has not; also, under "Printers & Faxes", this printer shows as "ready" and shows that a document is "printing" - even though it is not. Can you help?
    Problem Solver:
  • 6 Answers
Disconnect that USB cable and reconnect back
Make sure printer will be detected by computer
Go to Printers and Faxes
Right click HP printer icon and select properties
Select 'Port' tab
Make sure the one that has a check mark is USB Virtual Printer Port....or DOT4......
If issue still persist continue with the next step
OPen RUN
Type net stop spooler
and the press OK
Go back to run and then type in
net start spooler
PressOk
Posted on Sep 24, 2009
    Scholar:
  • 169 Answers
Well an unisall and reinstall of the printer drivers on the network would definately solve your concern.If you want further support you can avail free online technical support on http://tinyurl.com/m7ghqz
Posted on Jun 19, 2009
3 Suggested Answers
SOURCE: Network printer problem
try the usb cable if the computer can print print test that would be the network is wrong ip address that declare you on printer
Posted on Feb 04, 2010
  • 39 Answers
SOURCE: HP3600 USB printer works but won't print on my HP7058 Laptop
Try removing all ports from your laptop, then reboot, and then create just one USB port. Also, go to your hardware devices and make sure your usb ports don't have any question marks or yellow warning symbols. Be sure first that the drivers for your USB ports are installed and working first. This sounds either a faulty USB cord, which does happen, or USB drivers issues in your laptop. The printer is probably not the problem here.
Posted on Feb 17, 2010
Iam trying to set up a photosmart D7360 to work in my home for all PCs so I'd like to set it up wireless. I'm currently using a router. How do I start? I have a brand ne HP lap top and the photosmart is in...
HP Photosmart D7360 is Not completely Wireless Capable, However if you want to make it Wireless, You will have to use HP bt450 Bluetooth Wireless.
However since this printer has Ethernet Port, you can still make this printer wireless.
You will have to connect this printer thru Ethernet cable ( network cable ) to Router ( this is called wired networking )
Once you have connected the printer to Router, insert the disk in CD Drive and start the installation process, It will prompt you to choose the type of Connection, Choose Wired/Wireless Network and continue with further installation to complete.
How this works,
With any PC that is connected Wireless to Router, You will be able to print wireless from the PC to Printer.
Jul 03, 2010 | HP Photosmart D7360 All-In-One InkJet...
Just got a HP laptop for work that's running windows 7. It won't find our HP 5610 printer at home even tho I've downloaded the right driver
Is the printer directly connected to the laptop by a USB cable? Try a new cable. Check that the USB ports work by plugging in a known working device.
If you are using a print server or USB hub, try a direct connection. (If networked, check that your firewall isn't blocking the access by disabling it. If the print server is another computer, make sure that computer's firewall isn't blocking the laptop (trust level between the two machines).
I hope this helps.
Jun 28, 2010 | HP Officejet 5610 All-In-One InkJet...
Can I connect my HP PSC1510 to my BT Homehub v1?
yes, you can. I have my printer connect to my hub and my desktop and I can print from my laptop wirelessly.
You will need your all in one connected via a printer or USB cable to a computer AND also connected to your hub. Then, go to the computer that is connected through a cable to the all in one. Your all in one should have some way to configure its IP address. I have my printer configured as 192.168.1.4 and it's plugged into the 4th port of my hub. Check if this works.
Mar 14, 2010 | Acer Aspire One Netbook 8.9" Notebook
Lost ip/connection on Dell 1720dn
try resetting the "print spooler"
  1. start
  2. control panel
  3. admin. tools
  4. computer management
  5. services and applications
  6. services
  7. scroll down till you see "print spooler"
  8. left click once
  9. "restart"
Jan 06, 2010 | Dell 1720dn Laser Printer
I have 3 laptops connected to a bell 2wire router. They are all able to connect wirelessly to the router and access the internet fine. But I am trying to connect my hp2605dn printer to the router with a...
To install a HP printer (with built-in Jetdirect print server) as a network printer you need to do the following -
1. Open the printer’s menu and enable the Network Card – then configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100 then set the Subnet Mask IP address to 255.255.255.0
If you have a wireless router then check the IP addresses that the router issues to the computers on your network and configure the IP address in the printer accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP's printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
Install the HP printer driver on every computer on your network and configure the printer’s TCP/IP port as previously detailed.
Do a test print page to check the printer.
You can now print from any computer on your network.
Dec 03, 2009 | 2wire Computers & Internet
Need my laptop to communicate wireless to printer
If the printer does not have a built-in network card/print server then there is a couple of ways to do this.
If you have a desktop computer connected to the wireless router with a LAN cable, then connect the printer to the desktop computer and make this printer a shared printer on your network. This means that the desktop computer and printer needs to be on when you want to print from the laptop.
The other way is to purchase a print server, connect the printer to the print server and connect the print server with a LAN cable to the Wireless router.
If you don't have sufficient network ports on the wireless router then you need to purchase a hub. Then connect the hub and wireless router with a LAN cable and then the print server to the hub and other computers to the hub.
Setting up the wireless printing will depend upon which method you want to adopt and I can advise you when further when you are ready.
Aug 02, 2009 | HP Photosmart 3310 Printer
HP printer will not print over wireless network using Belkin hub
Try turning everything off, wait a couple of seconds and then turn it back on.  Also try disabling McAffee to test.  When you go to printers and faxes on the PC, what is the status of your printer?
Apr 16, 2009 | Belkin (F5U237) 7-Port USB Hub
Wireless Dell laptop can't 'find' HPDeskjet 5150 Printer
this printer is (as per HP specs) only connected via USB or Wlan Print server.
Check connection using USB cable and be sure Printer driver are correctly working.
Check on Router your Print server IP address (Lock it out of DHCP)
Put both PRT and PC on same home network (normally HOME or MSWORK)
Put Printer server IP address into your printer properties/port tab/ IP.
OR check if you see your printer server in your Windows network/home network
Jan 11, 2009 | Computers & Internet
I have a new Compaq laptop running Vista home and an old samsung 4216f. I tried a parallel to usb and cannot get the printer to work. No parallel ports on laptop and no usb on printer. Any ideas?
If you have a home network, try a Print Server with parallel port. You will connect the printer to the print server via parallel, and the print server to a network hub/switch/router (any of the listed) via a network cable, and the computer to the hub/switch/router via network cable or wireless.
Cost should be around $20 - $60 depending on make/model.
Nov 30, 2008 | Office Equipment & Supplies
I need to know what connections i need to connect two computers to one hp printer
A 5 port switch (Hub) and network cables are about the simplest.
If the printer doesn't have a network port, you can add a small print server.
The print server is a little device the connect to the parallel port on the printer.
You then connect it to one of the ports on the switch (Hub)
Another way to share a printer is to connect the printer to one of the computers, and then share it. This is considering that you have the 2 computers networked together.
The drawback with this setup vs the first one, is that the computer that has the printer attached, must be on for the other computer to be able to print to it. The first setup, you only need to have the printer on, for either computer to be able to print to it.
Aug 16, 2008 | HP Office Equipment & Supplies
HP Photosmart D7360 All-In-One InkJet Printer Logo
67 people viewed this question
Ben Johnson
