Question about Dishwashers
Amana washing machine with error dc flashing - Dishwashers
  • 691 Answers
I am pretty sure it is an unbalanced load error. Empty it of everything and turn it off then back on again. If it hasn't drained of existing water see if you can get it to do that first. there could be other faults causing this one.
Posted on Jan 06, 2013
  • Troy Anderson Feb 20, 2013
    Fixed it now how do I delete an answer?
  • Daniel Bakewell Feb 22, 2013
    Sorry for delay, click on report abuse icon near bottom of a post and ask the moderators to remove any inappropriate comments.
Error code F8 E1
My Maytag MVWX700XW1 washer does not spin, the lid lock light is flashing red and when I run the diagnostics, and check the Fault Error code I get F7 E1.
I would alos like to find the list of Fault Error codes.
Thank you for your help.
John
Jan 10, 2014 | Amana Washing Machines
What does dc Flashing on my Samsung aqua jet dryer mean?
A "dc" error occurs when a Samsung washer is unable to spin due to an unbalanced load. Redistributing the items inside the washer and pressing the "Start/Pause" button typically clears this error
Nov 11, 2012 | Washing Machines
My amana washer is flashing an error code nf. What should I do?
This code means the Washing Machine is Not Filling with water.
Hopefully only the hot or cold water inlet valve is clogged on the unit, remove the hoses from the back of the machine and look inside where they hook to the machine, make sure that they are not clogged up with debris, if they are clean them the best you can. If they are clean you may need to replace the hot or cold inlet valve on the machine.
Dec 13, 2010 | Amana Kitchen Ranges
Wont Finish Spinning stops and Flashed DC
If the machine type is a FAV6800A/FAV9800A see this Clutch repair post if you want to DIY. You will find links to the Service Manual and parts info if needed.
You can check out the TDS but I would go right to the Clutch repair post if the machine shuts down in with a error code dC or uC.
That means the TDS is producing analog voltage swings +3.5VDC to 0VDC to the input of the Control Board Conn_P3 pins 10 and 11. Those DC voltage swings are at the design limit of max Wash Tub movement and the Control Board shuts the Spin Cycle down……..so thebTDS is working as designed.
The machine will make several attempts to redistribute the load before error code generation failing with dC or uC error codes.
Post back if you have questions any DIY'er with basic skill sets can do the Cluch maintenance/repair.....Rich
Jan 04, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Flashing code dc and does not spin any more
DC is an unbalance error. You need to open up the back and take off the top and check the shocks and springs. That would be the first thing to do.
Dec 21, 2009 | Samsung WF337AA Front Load Washer
MAH 2400 AWW flashing error code "dc"
Hi Pepsi,
"dc" means that the control board is trying to ramp up (that is, send a signal to the motor controller), but has encountered an unbalanced load and so shuts down. Specifically, "dc" means "distribute clothes".
I took this opportunity to upload a Tech and Troubleshooting manual for you. Here is the link for it. Read it carefully. You will be required to perform a "board output" test after placing the machine in "Service Mode".
I gotta tell ya, though. Based on my history with these, I highly suspect that the machine control board has failed. Let me know what you find, OK?
(And don't forget to rate this solution as "FixYA!", deal?
SG
Apr 11, 2009 | Maytag MAH2400A Front Load Washer
Fault code on an Amana Washer
The door is open. Be sure that the door is completely closed.
Jan 21, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Dishwashers Logo
77 people viewed this question
Top Dishwashers Experts
Owen Barnes
