Question about Balboa Instruments Duplex Digital Panel 2 Pump
Hot tub wont come on
The hot tub was running and just quit for no reason, and would never come back on, we can jump it and it works but we cant figure out whats wrong. do you have any ideas, the topside panel wont light up or anything .
  • Balboa Instr... Master
  • 1,631 Answers
What do you mean "Jump it"?
Check with a meter, ACROSS both hot wires to get a reading of 220-240 volts. do not test across 1 hot and the meter lead on ground! You probably are not getting proper voltage to the hot tub. Or you may have a burned system fuse normally 20-25-or 30 amp fuse, which is found within the control box of the spa.
Posted on Jan 16, 2013
Cant find the filter for my Aeware Hot tub
Take the filter to a hot tub shop and they will be able to identify it for you. Any shop that sells pool or spa equipment should be able to help as most manufactures use aftermarket filters for cost reasons.
Apr 26, 2013 | Televison & Video
Car won't start without a jump but battery okay
wont crank or wont start.??
no car starts , if it cant crank. (unless push starter (M/T magic)
that is not a trans sensor its the PRN switch.
ill answer for, wont CRANK !
it wont crank even with a good battery (charged) or jump started.
1: bad start
2: bad wires to same.
so hot wire the starter small wire, the key start line is tiny.
cranks. , starter good, no crank starter bad or cables bad.
if it cranks hot wired, then the key line is dead.
easy, huh?
Feb 11, 2013 | Suzuki Forenza Cars & Trucks
Ac quit working right after speedometer quit working around 60 mph. the rpms after i got off the interstate started to jump and my steering wheel seemed hard to turn
Hello, The reason why it was hard to steer was the engine wasn't running. The rpm, seedo, air condition, power steering does work if the engine has died. First check to see the belts are on the pulley and rolls in the engine carpment. If they are on and not broken then you other problem.
Will you car start, if doesn't. You could have run out of fuel?. Power steer pressure valve is faulty, broke a timing belt, run out of oil and the engine quit working. Engine got hot and stopped.
If it not starting, call a wrecker have them take to a garage of your choice. GB...stewbison
Aug 25, 2011 | 1998 Ford Taurus
The dryer in my trailor tub wont turn I have Heat but the tub wont spin.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 08, 2011 | Dryers
My new lg direct drive washer just quit mid cycle, it wont start back up the code indicated power outage, but it comes on just wont run
heatman101
Sep 04, 2010 | LG DLE2512W Electric Dryer
My JBL Marine Hot tub Sterio quit working suddenly?
JBL is at best a low quality marine grade brand of stereo. It is now garbage. I have worked on hot tub stereos for many years, PolyPlannar is the only one that is any good. If it was bought 30 days ago, where's your warranty?
May 31, 2010 | JBL Am/Fm/Cd 180 Watt Marine Audio System
Frigidaire top load washer that keeps shutting off
i canty be 100 percent sure
without the model
but it sounds like you motor is trying to start but for whatever reason is cutting out on the overload. Meaning it gets hot,,,and shutsd it self off to save it self
ther ecould be alot of reasons for this,,, far to many to type here,,,
with frigidaire it could be a bad motor capacitor, or a bad start winding on the motor.......
or a simple as a sock between the tubs preventing the tub from truning
sorry i cant be more help
but figured you should have some sort of answer to at least5 investigate
Oct 28, 2009 | Washing Machines
Water temperature from shower is eratic
swap the guts between the two valves to see if problem persists. if the guts from the shower has the same problem in the tub, bad guts. if not and the tub guts have the same problem in the shower valve, the problem may be a water saver shower head restricting the flow too much for the valve to operate.
please take the time to give this solution a fix ya rating.
clarkco
Mar 19, 2009 | Plumbing
Balboa Instruments Duplex Digital Panel 2 Pump Logo
233 people viewed this question
Top Balboa Instruments Garden Experts
Ian Kime
Ian Kime
Paul Stonecypher
Paul Stonecypher
Level 1 Expert
Mister Danger
Are you a Balboa Instruments Garden Expert? Answer questions, earn points and help others
