Question about Singer Electronic Steam Press Iron
Can't find where fuses are on pants presser 11OVLED
Where are the fuses located
Water tank reservoir for steam presser FSP5
Contact the manufacturer of the appliance for parts, if it is available they will be the only one tat will have it.
Nov 29, 2016 | Irons
What could cause the singer 9960 presser foot does not lift with presser footlifter
Apparently the lifter is loose or broken. Remove front cover , check movement of lifter where lifter stops movement will be where your problem begins!
May 28, 2014 | Singer 9960 - 9960 Quantum Stylist
Change the thermal fuse inside iron that's why not getting hot. thermal fuse blown up due to overheat inside
An iron should be calibrated to 410 degrees on wool setting to get the other settings to work correctly.
Dec 26, 2012 | Irons
Rowemta DA1560 won't turn on
1) No voltage to receptacle
2) defective cord or terminal connection
3)open thermostat
4) open heating element
4a) the heating fuse blown
5) test the outlet wal with lamp desk, if work, the iron is the problem follow the steps before mentioned. reset the c.breaker or change the blown fuse is necessary.SEE the diagram
God bless you
Sep 09, 2012 | Rowenta DA1560 Iron
I read to check the fuse when the iron is flashing and not heating, Where is it located?
Hello. The fuse is called thermal fuse, it is a small cylindrical metal, placed in series with one of the main line and screwed and enclosed in an insulator. You can see that inside the iron.
Mar 03, 2011 | Rowenta DZ5080 Iron with Auto Shut-off
Iron was working long enough to complete ironing pants.Iron stopped heating up completely. Lost heat completely, I tried plugging it into another circuit but it did not heat up.
Firstly Check the fuse in the plug and replace if blown,if ok it could be your cable ,element or thermo switch.Please come come back if you need further assistance
Aug 10, 2009 | Irons
Steam iron residue on suit pants
I would send them to the drycleaners and point out the contamination. If they were mine, I would treat them with a little white vinegar; the white deposits are caused by a buildup of calcium in your iron. Don't put the vinegar directly on the trousers but use a clean cloth with some vinegar on it and gently massage the deposits.
It may stink, but it is wise to now and then run it warm (only) with some white vinegar which will dissolve the deposits. Put it on a heat-proof surface (such as a stove grate) so it can stand flat otherwise not all of the deposits will get soaked with vinegar. After letting it soak warm, run several tanksful of plain water to remove the vinegar and shake it over the sink in case there is chunks (very well could be) that have been loosened.
Mar 27, 2009 | Rowenta DG-980 Iron
Singer Electronic Steam Press Iron Logo
23 people viewed this question
Top Singer Irons Experts
Chance Miller
Are you a Singer Iron Expert? Answer questions, earn points and help others
