Question about Dell Inspiron 300M Notebook
Hot on bottom - Dell Inspiron 300M Notebook
Make sure the exhaust vent is not blocked
Posted on Jan 06, 2013
I want to replace a current dual outlet with a combo switch outlet where the switch controls the outlet.
Based on what you said, your hot wire feeds the top left and the neutral connects to the bottom left. The two brass on the right should be connected to each other with a brass tab. If you look at it, you should be able to see it.
This is the way it works: hot feeds top left, when switch is turned on, hot goes through to the top right which also feeds bottom right. Now the outlet is powered.
If you are not sure, use a multi meter set on continuity and check from the top left to the bottom left while turning on the switch. Good luck!
Jan 28, 2017 | Electrical Supplies
Hot air blows into car from underneath of car what is causing this
does the air blow in when the car is not moving. if it does, your heater switch is on and blowing hot air in through the bottom vent.
Apr 01, 2014 | 1997 Ford Taurus
Running out of hot water after 10-15 minutes. already changed the bottom element and theromstat and still missing hot hot??
Is the upper element working?
The cold water comes in at the top inlet and there is a tube inside the water heater which takes the water to the bottom. If this tube breaks off the cold water will mix with the hot water on the top and you'll have less hot water. You can take it out and inspect or replace it.
Mar 05, 2011 | Rheem Water Heaters
How does rhe hot and cold water hook up on a 71-40d which is which top and bottom
Tanks are marked with Hot and Cold.
1) If water connections are on top of tank, look for red marking or word HOT that shows where hot water pipe connects. Look for blue marking or word COLD that shows cold water connection.
2) If water connections are on side of tank, cold water connects to bottom one, and hot connects to top.
3) If hot and cold are reversed, the tank will not work.
Pipes on top of tank: cold water enters tank and is sent to bottom of tank in a long tube called the dip tube. This means the cold is on the bottom since hot water rises to the top. The hot water exits top of tank.
Pipes on side of tank: You want cold water to enter bottom, so hot water naturally rises to the top outlet.
Nov 14, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have hot water for a minute then it goes to warm. I took off the 2 wires on each element and I have 15 ohms on the top and 5.5 on the bottom. Is my bottom element bad?
Sounds like bottom element may be bad but usually reads open circuit if bad. Also tan k would run about 8 gallons hot water then go cold. lots of warm water usually means bad dip tube.
Check if tank is hot at bottom element when not used for a while. If bottom element is still cold then bad element.
If bottom element is hot - (all water in tank is hot then you have a bad "dip tube" This is allowing incoming cold water to mix with outgoing hot water. The dip tube is usually A part of the cold water nipple or B located under the cold water inlet nipple.
Jan 18, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Radiator problems
it may be a little off, but the lower water hose seldom gets very hot,, as its this hose that suplyes the engine with ""cold water"" the hot water comes out the top hose,, drains down the rad and cools on the way down then enters the engine through the bottom hose """if your engine stayes running in the normal place on the gage,,,and not over heating""" why are you spending money for nothing???""
you wont get the bottom hose to run hot unless the engine is cooking
Oct 30, 2009 | 2001 Chevrolet Tracker
Hot water comes out cold side for few seconds and gets cold, no hot from hot side, only cold
Make sure that the water pipes for the cold water coming in and the hot water going out are connected to the correct positions on the water heater. If the connections get reversed, the water that is supposed to be hot will be drawn from the bottom of the tank and will not be as hot as it should be. The cold water input goes to the bottom of the tank. The hot water out comes from the top of the tank.
Oct 09, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Low amount of hot water
You say a very new water heater. You won't get 40 gallons of hot water from a 40 gallon water heater because the continuing influx of cold water will cool your hot water down. However, it appears that your bottom water heater element needs replacing. If the top element is bad, you'll get no hot water. If your bottom element is bad, you'll get "some" hot water. Try replacing the bottom element. DON'T FORGET to turn off the electricity AND water first (closeby towels are also handy)!
Mar 09, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Dell Inspiron 300M Notebook Logo
22 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
