Question about Apex Digital PF2725 27" TV
Apex PF2725 tv, no sound only picture
Picture and dvd player work fine.....there is no sound....i have tried the function key with the mute button...nothing seems to work
please help...i am going insane !
  • 308 Answers
SOURCE: Can't see scrolling text or sport scores
If the set is still in warranty I would get a shop to fix this. If not and the set is over 5 years old and had a good picture in the past, I would suspect failing capacitors in the vertical circuit. On older sets, you could adjust this out with controls located on the main circuit board. With these newer sets, you would have to adjust it via service menus using both the remote control as well as the video button on the TV itself. For instance, on a model PF2720 which has a CH-16CD chassis (may or may not be the same as yours) you would have to first decrease the volume to zero then press both the mute button on the remote control and the video button on the TV at the same time to get into the service menu then by using the menu select buttons on the remote control go down to where the symbols S2 VAM comes up, and that setting when adjusted would vary the vertical height of the picture. It might also be necessary to adjust the VSH to shift the vertical up or down so there are no lines at the top of the screen and you could still read the bottom. When finished, you would have to press the timer(?) button on the remote the key that looks like an apple with a stick in the center to get out of the service menu. Note that if you try this, do not tamper with any other adjustments, or you may never get the set back to normal again. Since I do not have the instructions for your particular set, you may not even be able to get to these adjustments by using this method. If you have a TV shop nearby, they may be able to do this for a nominal charge as they would not have to take the back off the set to adjust it. If you do decide to do this procedure, write down the values before changing them in case you have to back track to where they were.
Posted on Dec 09, 2006
SOURCE: dvd/vcr combo,vcr is fine ,but dvd no picture,or sound,disc reads.
Hi There is an I/P button on your player's remote control. Power your player on then press the I/P button on your remote control.
Posted on Mar 31, 2007
SOURCE: Apex Digital GB4308 remote
Programming the Remote Control Remote-control switchover Press VCR/DVD, SAT/CABLE or AUX to select the device you want to control. To program the remote control Press and hold VCR.DVD, SAT/CABLE or AUX for over 2 seconds until the LED on the remote control turns off. Release the button the LED will light again (the remote control enters the PROGRAMMING mode). Enter three-digit code number for your equipment. If the correct code number is entered, the LED blinks three times. If you enter a code not listed below, or you press any other buttons than SEARCH and 100+, the LED turns off. To search codes Press ad hold VCR/DVD,SAT/CABLE or AUX for over 2 seconds unil the LED turns off. Release the button (the LED wil light again) and the remote control enters the PROGRAMMING mode. Press SEARCH. Press CH+/- to search codes downwards or upwards. Each time you press CH+/-, the code number decreases or increases by 1 while the remote control sends the code number for POWER button on your device. If the desired code number is found,press 100+ to program the code for your device until the LED blinks three times.Then the remote control exits from the PROGRAMMING mode and returns to norml operation. Or press any other button to exit from the PROGRAMMING mode after the LED blinks rapidly eight times, and the operation is not active. To check the current code number Press and hold VCR/DVD, SAT/CABLE or AUX for over 2 seconds until the LED turns off. Release the button (the LED will light again) and the remote control enters the PROGRAMMING mode. Press 100+ . You may read the code numder according to the LED display status as follows. * If there is no operation within 20 seconds during the steps mentioned above, the remote control will automatically exit from the appropriate operation. Code Number First - digit 0 1 0 1 Second - digit 0 0 4 5 Third - digit 0 6 3 0 First - digit Blinks rapidly once Blinks once Blinks rapidly once Bliks once Secod - digit Blinks rapidly once Blinks rapidly once Blinks four times Bliks five times Third - digit Blinks rapidly once Blinks six times Blinks three times Bliks rapidly once
Posted on May 01, 2007
SOURCE: DVD/VCR combo player won't work
I had a similar problem and corrected it with a solution found on another site. Try hitting the I/P button on the remote which controls whether "Interlaced" or "Progressive Scan" is used to display the image on the TV. Mine worked when "Interlaced" was used. but no picture was displayed when "Progressive Scan" was used. The I/P button toggles between the two settings.
Posted on Jul 19, 2007
robotek
  • 1512 Answers
SOURCE: Apex 32 inch tv Model #PF3230
G'day mate
Sounds like the power supply regulation has gone high volts, and the screen is blooming because of it. I suggest getting a tech to look at it, will probably have the usual issues of capacitors failing in the power supply. Cheers
regards
robotek
Posted on Sep 14, 2008
I'm hooking up an APEX Digital TV and when playing a DVD, the picture is fine, but there is no sound. When on TV mode, sound is fine. Suggestions on how to fix this?
  • Turn everything off. Turn on TV and Select dvd input (Source). Wait 10 or so seconds. Turn on DVD player. Works for me with similar problem. Good luck -
  • John
Jan 17, 2016 | Apex Digital Televison & Video
I have a red key on bottom left side of screen. Have volume but no picture. None of the controls work on tv or remote.
Hello
Your TV is locked.
The Child Lock feature prevents unauthorized viewing of the
television. To activate, press and hold the Function key, and then
press MUTE. you should see a key symbol appear on the screen.
This will lock out all remote functions (except for Standby). To unlock
the TV, press and hold the Function key and press MUTE. This will
unlock the TV. Please note that the only way to activate or deactivate
the Child lock feature is via remote control - please insure that it is
stored securely.
Jul 11, 2011 | Apex Digital AT1314DV 13 in. TV/DVD Combo
Locked tv
MY TV IS LOCKED CANNOT GET IT TO TURN ON HELP!!!!!
May 03, 2008 | Apex Digital AT1314DV 13 in. TV/DVD Combo
Blue screen and a small red key
worked just fine for me! thanks!!! 'function' key is in the top left hand corner
Mar 16, 2008 | Apex Digital AT2402 24" TV
13 in apex tv
On the remote hold down the (F) function key and press mute.
Jan 01, 2008 | Apex Digital AT1314DV 13 in. TV/DVD Combo
APEX TV donĀ“t work
Try pressing the "F" or function button and hold while pressing the Mute or "M" button at the same time. Hope this helps.
Sep 01, 2007 | Apex Digital AT2002S 20" TV
Dec 19, 2006 | Apex Digital ADV3800 DVD Player/VCR
Dvd/vcr combo,vcr is fine ,but dvd no picture,or sound,disc reads.
Aug 16, 2006 | Apex Digital ADV3800 DVD Player/VCR
How can I remove the little 'green key' in the lower left hand corner of the screen
Try pressing the "F" or function button and hold while pressing the Mute or "M" button at the same time. Good Luck
Jul 27, 2006 | Apex Digital AT1314DV 13 in. TV/DVD Combo
Apex Digital PF2725 27" TV Logo
655 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
