Question about E-Machines eMachines Desktop PC
E-mach no video
E-machine turns on but no video. the hard d is running the diskdrives open and close the keyboard does not light up during startup. I tried another video card but still nothing. AMD athlon xp inside.
  • 70 Answers
Try other RAM module or Processor
it could be
Posted on Jan 20, 2009
I am having some difficulties with my biostar G31-M7 TE Ver. 6.5. When I start up the machine, with all well in place and cleaned, it never shows anything on my monitor. The monitor works, but keeps...
1. Disconnect the computer from the power conecction. 2. Disconnect the power supply from the motherboard 3. Remove the Bios battery and wait one minute. 4. Turn on your PC.
If the problem continue reset your memory. Remove it and re insert. Also clean the memory contacts.
Mar 18, 2011 | Biostar G31-M7 TE Motherboard
How do I turn on the back light to the keyboard of my ASUS UX50V? The light comes on mometarily during start up. The F3/F4 keys have a picture of a lighted keyboard, but do not activate the light.
Hi.. Norman
i hv bought the same laptop ..earlier i was facing this problem at day time , it consumes battery.but at night it does excellent work.
Now talk abt ur problem...
1. to on/off it use "Fn" key given near window key(near left control)
2.use Fn+F4 key to dim or off light
as u can use Fn+F5 key
3. to perminant off
and disable ATK HOTKEY driver..
NOw i have problem with my laptop(asus UX50V)..
it came with VISTA but i installed WIN7 ultimate.
now i can't open my webcam.. I dont have DRIVER for it..
if u kno help me where should i download driver for it...
rply soon...
Aug 04, 2010 | ASUS UX50VRMSX05 Notebook
Boot mgr Is missing on a tobisha laptop
Method 1:
Use the following procedure to repair the file system on the hard drive:
  1. Turn off the computer and wait at least 5 seconds with the computer in a full off state.
  2. Turn on the computer and press the F8 key repeatedly as the computer starts. An "Advanced Boot Options" screen opens.
  3. Select Repair Your Computer and press Enter.
  4. Select a keyboard layout that matches your country/region and click Next.
  5. When the login prompt appears, select the user name with Administrator rights (not Administrator) from the User Name drop down. The user name with Admistrator rights is most likely the first user name that was entered during the initial computer setup.
  6. Type the logon password into the Password field and then click OK.
  7. A System Recovery Options window opens.
  8. Click Startup Repair.
A Startup Repair window opens and automatically scans for startup problems.
  1. Perform the actions suggested by Startup Repair: system restore, correct damaged or missing files, or other action.
  2. After Startup Repair has been used, try to open Windows.
    • If Windows Vista opens, you are done.
    • If Windows Vista does not open, perform the first portion of this section again to open the Startup Recovery Options window and continue.
  3. From the Starup Recovery Options window, click Command Prompt.
  1. Enter the following at the command prompt:
bootrec /fixboot
bootrec /fixmbr
  1. After the bootrec tool has been used, close all open Windows to restart the computer and open Windows.
    • If Windows Vista does not open, continue using these steps.
  2. Perform a full system recovery using recovery discs. For more information refer to the HP support document Performing an HP System Recovery in Windows Vista .
If the recovery cannot be completed from recovery discs, replace the hard drive.
Sep 13, 2009 | IBM ThinkPad T43 Notebook
Keyboard not working
try to update your machine's bios and re-install your keyboard driver and touchpad.
Jun 30, 2009 | Acer Aspire 5100-5022 Notebook
The hobart lxih is stuck in delime.
To reset or clear delime message, on control board there are 3 buttons. from power off, drawer open, manget on door switch, door closed, hold PROG on board and press the ON key on keyboard. pressing select moves to next poption, up arrow increases setting. step through select until you see delime, settings for LXi are de for disabled, and 1 through 65= x100 cycles. rg if set at 5, after 500 cycles the message apears. To keep the settings and clear the message a delime sequence needs to be run precisely as described.
With machine off, remove rack , close door, press and hold wash/delime key and press ON. Delime will be lit on display, release wash/delime key, and let machine fill. you should then see ADD and DELIME on the display, open the door and add the delime agent following supplier's instructions precisely. close the door, press wash, delime will flash. After delime is complete power is turned off. Inspect the machine and repeat if necessary.
Jun 18, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
I wanted to take some clothes out during the cycle but don't know how to stop it properly and get the door unlocked
your mach depending on model and cycle selected has a 3 to 5min "add a garment" feature.that means in the 1st 3-5mins of cycles when add a garment light is lit you may hit pause button once and the mach will stop and unlock door.after add a gament light is off,if u hit pause the cycle the mach will drain water and reset cycle..hope this helps
Mar 29, 2009 | Kenmore 42822 Front Load Washer
Mach speed
Unplug the the dsl & any other device except the keyboard & mouse. Double check the video cable at both ends monitor & PC. Boot up system. If the system starts shut down & connect 1 device. Boot the system. OK? continue to do this. On the dsl there is a reset button. With it unpluged from power use a pen & hold in the reset for about ten seconds. Reconnect the power & reconnect the Rj45 to the PC. Boot system.
Jan 26, 2008 | Mach Speed VENOM MSA2-6100V Motherboard
Solis Palazzo - stuck in descale mode?
Are you refilling the tank during this process? You need to let in run dry, and then the buttons flash. Then, refill the tank with clean water, and let the tank run dry again.
Dec 11, 2007 | Bosch Benvenuto B30 Espresso/Coffee Maker
E-Machines eMachines Desktop PC Logo
32 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
