Question about Jensen A600HLX Car Audio Amplifier
Help Do have to hook RCA Wires to the input and Output section on a Jensen A600HLX Amplifier?
  • 156 Answers
No. The amplifier gets its signal from the RCAs connected to the "input" jacks, but the "output" jacks are just there to make it easier to add another amplifier. You only need to connect the inputs for the amp to work.
Posted on Jun 29, 2007
SOURCE:
How should i run my Jensen A600HLX Amplifier if i am using it to power 2 10inch Rockford P1 Subwoofers?
U need to check the impedance of your woofers .If they are 4 ohm i would reccomend hooking them in series, which is the positive output of your amp will go to the positive of one woofer, the negative of that woofer goes to the positive of your other woofer and the negative goes to the negative output of the amp.If that amp is bridgeable this will give u a good bass and the impedance will be 8 ohm so your amp will run cool and stable
Jul 30, 2010 | Jensen A600HLX Car Audio Amplifier
I wanna equalizer a jensen 760 but i can`t can you tell me how can i do?
Hello, if you want to put an equalizer on an amp then I would suggest you get a preamp style equalizer, non powered of course, take the rca output whichever one you want to use and conect it to the input on the equalizer. Then take the output from the equalizer and hook it up to the input on your amp. That's it. Most equalizers also have sub outputs, make sure you hook the correct output from the equalizer up to your amp. Also most have 3 outputs depending on the type you have. If you need more help just let me know, good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Aug 14, 2009 | Audiovox Jensen Power 760 Car Audio...
My amplifier has one pair of rca inputs. radio only has 1 output
Subwoofer signals should be MONO - not stereo (hence the single Component out on the radio)
Only use one RCA to send signal to your amplifier.
If you use a Y splitter - the signal voltage will be cut in half - deteriorating the quality, and therefore amplifying "dirty" signal.
If you require further help, simply reply to this thread.
Thanks for using FixYa - a FixYa rating is appreciated for answering your Question.
Apr 09, 2009 | Jensen Car Audio & Video
No remote from Cd player. What to do?
thats a car dvd player right what u would do is to take the back of the unit and look for the female ends of rca's on the unit that they will say rear out put hook them up and run them to the amp and i dont get what u mean about the remote wire but let me no if that helps
Apr 04, 2008 | Jensen A600HLX Car Audio Amplifier
OEM gm stereo
If your amplifier has what they call High level inputs (basically inputs on the amp that you run the speaker wires from your radio into), you can splice wires from where the connectors are on your rear speaker(s), still leaving the speaker hooked up, and use those as an input into the amp. If your amplifier does not have high level inputs, a convertor is available to turn an audio signal from your radio output speaker wires ( spliced in just as above, leaving the speaker hooked up), into an rca output jack. Or the best thing to do would be to buy another say 2-4 channel amp w/high level inputs and rca inputs and outputs, and run your rear speaker wires into the amp. Then you'll be able to run the rca cables out of that amp and into the sub amp, and you'll have the new amp to power your rear speakers or rears and fronts. That would be ideal. But, A convertor is your best bet. Got em at best buy, circuit city, etc. Hope this was helpful.
Nov 25, 2007 | Car Audio & Video
600 watt 4 channel bridgeable mosfet power supply jensen amp
Swap the wires from one speaker to the other to see if it is the speaker or the Amp/wires.
Oct 23, 2007 | Jensen A600HLX Car Audio Amplifier
JENSEN XA 184 AMPLIFIER
Hi, Jensen is under different ownership from when your amp was made, so it's unlikely that you'll find a replacement plug for the high-level input. A high-low converter is also called a line-out converter. It's a device that connects to the speaker wires and changes the signal to a low-level RCA connection. This allows you to use the amp's RCA plugs with your speaker wiring (through RCA signal cables). A line-out converter should be available any place that sells car audio accessories.
Aug 11, 2007 | Jensen XA92 Car Audio Amplifier
Need Help
input and output slots???? is it playing although thump present,low current could be the problem check for good connections as well as adequate wire guage.
Jun 29, 2007 | Jensen A600HLX Car Audio Amplifier
Jensen A600HLX
check pwm ic 494 or other
Dec 16, 2006 | Jensen A600HLX Car Audio Amplifier
My amp wont put out sound
it's blown....probably, check your connections and make sure your presenting it an ohm load it can handle....so check the sub with a dmm.
Feb 28, 2006 | Jensen A600HLX Car Audio Amplifier
Jensen A600HLX Car Audio Amplifier Logo
119 people viewed this question
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
