Question about Braun 8995 Electric Shaver
Braun 8995 - YELLOW LIGHT STAYS ON!
I am getting a permanent yellow light on the base station of my Braun 8995. The light stays yellow even with the cleaning fluid cartridge removed. If I press the button to clean it instantly turns to red, (empty). Any advice please.
I experienced the same symptoms on my 8995; solid yellow light (even though the cartridge was full), cleaning failed (red light on) after pressing either start button. After many failed attempts to clean the razor, unplugging the station and pushing start button, I decided to clean the razor under running water. I rinsed the razor under water and then turned it on allowing it to run in a pool of water (like it would in the station). After water cleaning, I returned the razor to the station, pressed the start button and it worked! Was able to do both the quick clean and auto clean.
Posted on Feb 27, 2015
2 Suggested Answers
  • 5 Answers
SOURCE: Red "empty" light on Braun Clean & Renew fluid turns on too soon
Put a few drops of tap water in the solution if the light goes red until it goes out. Cheap, green way to reuse the plastic container!
Total Cartridge Size = 170 ml
DIRECTIONS:
1.) Clean old cartridge with 70% Isopropyl alcohol
2.) Add 3 ml of Lemon oil
3.) Add 3 ml of glycerin
4.) Add 2 ml of water
5.) Add 70% Isopropyl alchohol to 3/4 of the top of the cartridge
COST ANALYSIS:
16oz (473ml) 70% Isopropyl alcohol = $1
16oz (473ml) Glycerin = $10
16oz (473ml) Lemon oil = $8
Cost Savings on one unit
Normal = $11
Homebrew = $0.81
Savings = $10.19 per refill
Posted on Dec 26, 2009
Yellow wire with fuse ? coming out of cdx4090
usually the yellow wire is your permanent power wire that connects to the battery or any power that stays on when the ignition is off. if you are losing your preset stations when you turn your car of then my bet is that this is what it is.hope that helps
Jan 26, 2011 | Sony CDX-4090 CD Changer
Yellow light with exclamation on parenthesis stays
It means you have a tire that has low air pressure air up the tires and it will turn off automatically. Assuming you have radials stop at any gas station and air them up to 32 PSi for firmness and better fuel mileage or 28 PSI if you like going around corners a little faster cause the tire to grab the road better. Also any tire shop will air them up for you if they are not busy.
Dec 28, 2009 | 2007 Mitsubishi Galant SE Sedan
My ps3 doesnt work and is because of a yellow light!!!
the hardware is done you cut the station off before without waiting
Nov 30, 2009 | Sony Playstation 3 (PS3) Console
The cleaning station for my 8995 goes through the motions of cleaning but the bristles are no longer flushed into the fluid reservoir as they used to - they remain inside the shaver and also in the...
You can make sure you have a nearly empty old cart in your shaver cleaner base, and then run some rubbing alchol into shaver or even some mixed with some soap to help break down the oils in the stubble crud. If you can put some also in a spray bottle and use it to clean with a little force, that will help some.
Nov 19, 2009 | Braun 8585 Electric Shaver
The power indicator light on the console stays yellow - even when the console is shut off.
Normal after setting up a wi-fi connection. Just lets you know wii connect 24 is on so you can get updates and messages automatically. Let me know if you have any other questions, I can answer anything about the Wii.
May 27, 2009 | Nintendo Wii Console
Yellow light comes on to heat water, but does not change to green
I would try opening and closing the disc enclosure latch-- this triggers the machine to re-read the barcode and start a new cup of beverage. If the machine perceives that water needs to be heated more, the yellow light to should flash and the cycle to green when ready. If the water is already hot enough, when you close the latch, it will flip right to green.
Give this a try.
Also see my solution to my own problem with the water reservoir: http://www.fixya.com/support/t1267835-braun_tassimo_model_type_3107_brew
Gazzer.
Jan 07, 2009 | Braun Tassimo Espresso Machine/Coffee...
Kenwood kdc 3011 rests its self every time i turn the car off
This means that the power lead you connected the red and yellow to is a switched live and each time you turn off the ignition the power goes off and therefore resets. to fix this problem you need to connect the yellow to a permanent 12v supply that stays live when you turn off the ignition.
May 27, 2008 | Kenwood KDC-2011S CD Player
Braun 8995 Electric Shaver Logo
461 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
