Question about Electrolux 8 cu ft Steam Gas Dryer Titanium EIMGD60LT
How to install lp conversion kit on electrolux eimgd60lt
How to install lp coversion kit
Need part number for LP conversion kit
Good Morning Friend,
I understand you are looking for the part number for the LP conversion kit for your Frigidaire range. The LP conversion kit part number is PCK4200. I hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
WE HAVE A BRINKMAN GRILL AND BOUGHT THE LP TO NG CONVERSION KIT THAT IS RECOMMENDED FOR THIS GRILL ...KIT HAS TOTAL OF 6 ORFICES AND THE GRILL IS A 5 BURNER, WITH SEAR AND SIDE GRILL SO THAT MAKES 7..NOT...
Some Brinkman grills have the LP orifice installed on the NG orifice directly from the factory.
If that is true, you remove the LP orifice and the NG orifice is already there. Check instructions in the conversion kit and look for this detail carefully. I just did a Brinkman conversion and instructions were very confusing. The orifices in the kit are not used (on my unit).
Gary
Aug 21, 2011 | Garden
Do they have coversion kits for webber summit silver grills lp to natural
eber does not sell conversion kits for any of their gas grills.Nor, do they recommend converting them, as a matter of safety. Each grill whether Natural Gas or Propane is tested and approved for that specific gas type.With Weber grills,as with many other brands, there's more to converting the grill from one gas type to another, than just changing the burner orifices. It also requires changing all the burners, because their venturi valves (air intake) are not adjustable.
Hope this helps you and thank you for choosing FixYa.
Aug 15, 2011 | Weber S-420 (NG)
I have two Williams 1403622 wall furnaces in my children's room. they seem to leak gas not when the furnace is on, only when it's on idle. Both heaters were converted to LP with the Williams Conversion...
When the units were converted, did the installer also adjust the burner's air intake valve to what's required for propane? Sometimes, that's forgotten. Also, I assume all of the connections were leak tested .... not just where the conversion kits were installed, but throughout the heater? The reason I asked this, is that propane enters the heaters at a higher pressure (water column inch) than Natural Gas. Almost twice as much. In which case, it may have loosened the seals in the regulators.
Those are the things, I'd be looking at.
Mar 03, 2011 | Williams 1403622 Gas Compact Heater
How do I convert a gas dryer model # (DLG2302R) to LP ? Does the required Installation kit come with the unit upon delivery
Here is a link to the conversion kit you will need. It comes with the instructions you will need to do the conversion to LP gas.
Dec 01, 2010 | LG Dryers
GE stovetop with propane, too hot to simmer
I think you are right. Check for an optional valve for propane in your service manual or online on an appliance parts website. You can look up a schematic of all the basic parts.
Dec 03, 2009 | Car Audio & Video
Changing from natural gas to lp.
By getting a gas license! LOL
Remember to tip your waitress! I'll be here all week - Goodnight!
Alright...got it out of my system...here we go:
1. Find out if a conversion kit exists. Answer: Yes it does...in fact it came with it originally. If it had me doing the install, I would have taped the kit to the back of the range.
http://www.fixya.com/support/p106248-kitchenaid_kgsa906pss_gas_kitchen_range/manual-13680/page-7
....and I quote, "IMPORTANT: Your cooktop is factory-set for use with natural gas. If you wish to use L.P. Gas, an L.P. Gas Conversion Kit is included with your new range. Models with the TripleTier Flame Burner will include a TripleTier L.P. Gas Conversion Kit and a kit for standard ranges. See “Installation Instructions” for details on making this conversion.
2. Obtain the kit. This is more difficult than actually doing the conversion. Unless you have a dealer nearby, I'd simply call Kitchenaid directly: (1.800.461.5681) They will either send it to you directly (quite possibly for FREE) or point you in the right direction.
3. The kit will come with instructions, but briefly, here's what you're getting into: The kit will consist of 1-3 orifices. These will reduce the amount of flow going to the burner(s).
Why? Two reasons: a) Propane burns hotter and b) Propane moves quicker than N.G.
You might need: Allan Keys, Screwdrivers, Channel Locks, Adjustable Wrench.
You'll just disassemble the manifold, install the orifice(s), and GO!
Good Luck.
Sep 08, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Maytag dryer conversion
heres the number for the natural to lp canversion kit, complete with instructions. p/n Y33002923, give your local part warehouse a call.
Apr 04, 2008 | Maytag Neptune MDG5500AW Gas Dryer
LP Conversion for Jenn Air CVG316 (about 10 years old)
I have the same stove and I got the LP Conversion Kit at Sears Part Direct.:
http://www.searspartsdirect.com
Thisis the Part Number for the LP conversion for the Jenn-Air CVG316B: Part# Y04100687
Hope that can help you
Eddie Rentas
Tupper Lake NY
Nov 21, 2007 | Jenn-Air Cooktops
Electrolux 8 cu ft Steam Gas Dryer Titanium EIMGD60LT Logo
79 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
vince
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
