Question about Clarion DXZ475MP CD Player
Message: amp guard
What the heck does this mean? I used the volume on the remote and that message came up and no sound... I've tried the on and off..... tried reset... help..
  • Anonymous Mar 15, 2008
    how to reset amp guard
    President:
  • 3,130 Answers
That means the unit went into protect mode because of a fault in the amp of the unit. This will need to be serviced. good Luck
Posted on Jun 29, 2007
SOURCE:
TV audio output vastly different for satellite feed versus DVD feed. Why?
It is possible there are separate sound level functions for the DVD player, the tv and the satellite box, try the different remotes for each by unlocking the volume control on the satellite remote until you get them close or use the device specific remote volume controls. I would also try and use HDMI if available for the DVD instead of composite. If the volume controls are different it will show on the tv, might also go through all audio settings for each device. Some devices are pre-amped or send out strong sound signals while others are line level outputs designed to be amped by the output device, in this case your tv I believe. The HDMI vs stereo audio that goes with composite may be the cause or it could be in the settings of the device. Worst case is to remember to drop volume before you switch back so you don't ruin speakers.
Jan 25, 2015 | Televison & Video
Philips TV 42PFL7403D/F7 Remote no longer controls Volume & ON/OFF
you can start with opening the remote control and clean the buttons on your remote control. don't use any aceton based products. there can be some grease on the buttons.
if you used the on/off and volume more then the other buttons.
Dec 19, 2017 | Philips Televison & Video
Volume at max and won't go down
This sounds like a common problem on these TVs. Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Aug 12, 2012 | AOC L42H861 42 in. LCD TV
Turntable hookup to AUX or CD (no Phono input) only producing very weak sound, even at full volume
You are doing nothing wrong at all. It's just that as you say it has no phono input. Which means the sockets you have will NOT amplify the signal. So you need to buy a magnetic cartridge pre-amp and once connected to the aux the weak signal will be at the normal level.
Jul 11, 2017 | Pioneer VSX-818V-K Receiver
Audio isn't working
ya know I hate to say it but I've done this before. check the mute button on your remote. I've accidently hit mine before and it took me several days to realize it. lol. if it's not that. check the volume of the set itself, then check the volume with the remote....I know these are weird things to check, but they do & have happened, to me. lol. good luck & God bless.
Mar 21, 2012 | LG Televison & Video
My Nad 306 when swithed on sends sound to only one speaker (the left one) but if I rotate the volume control back and forth a few times I get the sound from the right speaker. If I want to increase the...
Sounds exactly like a failing volume potentiometer. If you can access it try some tuner cleaner or just exercise the heck out of it with no power applied.
While you're at it, treat every knob, switch and button for the oxidation that comes with age or little use.
Sep 02, 2011 | NAD Audio Players & Recorders
Clarion dxz545mp amp guard
, the message you are getting is "amp guard". This is the mesage it will display when a short in a speaker wire or speaker with low impedence is hooked to the internal amp and sends it into protect mode, shutting down the amplifier section while the rest of the unit continues to work.
check all of your speakers
Jan 16, 2009 | Clarion DXZ645MP CD Player
Volume fix problem
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there Good Luck! This worked for me.
Aug 02, 2008 | Yamaha RX-V659 Receiver
Amp guard
Other sites I've read about this problem suggest that first you try checking the wiring to the speakers for a fault to ground OR you have speakers with too low impedance. If those check out ok, the unit needs to go back for service.
Apr 14, 2008 | Clarion DXZ645MP CD Player
Clarion DXZ475MP CD Player Logo
458 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
