Question about Behringer Vmx200 DJ Mixer 2 Channels with Bpm Counter
No input level and no audio
Mixer turns on, but no input signal on level meter and no sound go out of the main or tape output. I also noticed that the XPQ Surround but does not light up when I press it. It started to act like that after I used the wrong voltage 220 instead of 110 (Brazil). However I replaced the fuse as indicated and now it turns on and everything, but not working properly as I described above. My 2 CDJ 200 were also connected to the wrong voltage in the same episode, I replaced the fuse and they are working fine now.
  • 110 Answers
The problem is that it may not have 'just' been the fuse that blew. Sometimes, because components are delicate, the fuse blows shortly after the damage has already taken place. My concern is that the logic board has a component(s) fried as a result. The fuse blew only after the fact. Luckily, you did not suffer any damage to your CDJ 200s.
Unfortunately, the cost to fix this situation may be much more than the unit is worth. You're probably looking at having to get another unit to replace it.
Posted on Jan 16, 2013
4 Suggested Answers
  • 5603 Answers
SOURCE: the mixer has xlr main output x2 and jack
The output jacks are PSUEDO balanced so use TRS cables and you should be able to drive two amps from each with no problem either as a WYE or daisy chained connection. The PSUEDO balanced connections do NOT drive differential voltages, but tie the return to ground through a 120 ohm resistor. It is imperative that you power ALL the amps and the mixer from the SAME receptacle or power conditioner. If you don't do this, expect lots of hum and risk of ground bounce damage to your equipment. Run extension cord if you need to.
Posted on Aug 05, 2011
  • 5603 Answers
SOURCE: Behringer SX3242FX intermittently looses signal
Make sure you are using BALANCED cables from this... eithe XLR or TRS cables. Using TS unbalnced cables MAY ground out the signal which is sent as balanced. Here is a schematic for the 24 channel unit... yours just has eight more channels. http://elektrotanya.com/behringer_ub2442fx-pro_sm.pdf/download.html
Scroll down to "get manual" and click to download. Ignore other download links.
By looking at the signal paths, you can OFTEN do a lot of testing from the available jacks. If the contacts on the right main INSERT jack go bad, that would cause your problem,,, NEVER use other than an insert cable in these jacks.
Posted on Sep 24, 2011
mechanicsonl
  • 431 Answers
SOURCE: Beringer PMH 660M has very low power output to speakers and when the volume in increased the output pops in the speakers and goes completely dead, everything else works ok and the lights stay on
could possibly be the volume switch, try changing the switch with one that you hardly use to eliminate the problem. any further probs just let me know. hope this helps
Posted on Feb 16, 2012
How do you connect tape deck to pmp 4000
Hi, use the RCA/Phono connections for the Tape In & Out. The level will be set by the Master/Main fader. If that is not so convenient (& assuming it's a PMP4000?) there should be a "Main 2" output & connections with the level controlled separately to Main 1 via a Knob / Rotary control over to the right above the "Mono" fader... Hope that helps... Good Luck!
Jul 11, 2014 | Behringer Pmp3000 16 Channel Audio Mixer
How to hook up to home amp
If home amp has a phono input and you have no turntable, plug the output of the MP3 player into the phono input and begin with the volume turned all the way down. If you do not have a phono input, you can plug something like a DJ mixer in to get that extra level of amplification you want for comfortable listening. If you do that, the MP3 player would plug into the turntable input and the mixer output would go to the available line level input of the home amp.
The CD player has either the coaxial connector, which is not common for home amps, and a pair of "RCA" jacks (right and left) which are.
The CD output can be connected to any avaialble line level input, such as anunused "Aux", "Tape In" "MD/VCR audio in, etc.
Dec 16, 2012 | Stanton C314 Tabletop CD and Mp3 Player
No sound
This is not a powered mixer and so you must connect a power amp to the "line level" outputs of the mixer. Other "no output" problems could be related to buss assignments and other signal routing issues. Check for output by connecting "Main Out" left or right to a guitar amp input instead BUT turn all volumes down to zero before conductiong this test as guitar amps are designed for "Microphone" level inputs. Owners and Hookup manuals can be found here...
http://www.mackie.com/products/1604vlz3/
Sep 09, 2012 | Mackie 1604 Vlz3 16 Channel Mixer
Hi i need to connect a microphone to the mixer and output sound to a tv monitor to hear audio across a cctv camera. hope you can help. adrian
INPUTS:
Mic into CH 1
Camera audio output into CH 2
OUTPUTS:
Mains L/R>>>>>>>>>>>>>>DVR/Tape
Control Room>>>>>>>>>>>>audio monitors.
Sep 14, 2011 | Phonic AM220 2 MicLine 2 Stereo Input...
How to connect floor monitor to mixer
You need to connect the speakers using an XLR cable into the Main output jack on the back of the mixer. If they are powered speakers you will need to connect them into a power source and turn them on AFTER connecting them. Once powered on you can control the signal going to the mixer with the Main Mix fader.
  1. Turn mixer on
  2. Ensure Main Mix level is at zero
  3. Connect from Main Output to Monitors
  4. Turn Monitors on
  5. Turn up Main mix to desired level
Sep 14, 2011 | Behringer XENYX 2442FX Mixer
How do I attach power amp to 1832 mixer
There are a number of configurations for a mixer like the 1832, the most common are PA system and Recording system. There are Main output jacks which carry the mix as summed in the main faders. These in a PA system would feed the pa amplifiers which drive the house speaker system for the audience. These connectors are XLR 3 pin type on the rear, intended for professional pa amplifiers which use balanced +4dbv line input level. Amplifier which have 3 pin XLR connectors for input signals can accept that high level signal. For home style HiFi amplifiers, the signal level is nominally -10DBv and balanced or unbalanced signal lines with 1/4in diameter phone plugs which are connected to the mixer by way of a second set of Main output connectors which are 1/4in phone jacks. Use whichever amplifier input level your amp has.
If you are not using it as a main PA house mixer, but using it for recording, the main output connectors go to a 2 channel recorder or computer sound card recorder. The power amp and your monitor speakers are connected to the connectors labeled "Control Room" (CTRL Rm). These output are useful for recording because the signal through the mixer can be monitored from several buses, Solo, main mix, selected by buttons provided. The buttons only affect the signal heard through the control room monitors, and not the main output which only sees the main mix so selecting "solo" does not interrupt the signal going to the recorder while the engineer in the control can be checking other signal paths through the board.
Jan 21, 2011 | Behringer Xenyx 1832fx Mixer 18 Input 32...
Mic output of my pmp3000 is weak,levels must all the way up to get any mic sound louder,Im using balanced xlr's for my mics, Is there any adjustable sensitivity adjustment inside the mixer? like the...
The answer to your question is NO, there is NOT an internal adjustment.
For many mics the trim is used full clockwise. Some higher output mics I use the trims are run at 3 o'clock which is mostly turned up. This is NORMAL for most mixers. If you don't have enough mic gain relative to other inputs, the fault is balancing the other inputs down and using higher setting on your MAIN slider.
If you use 8 ohm speakers then you can expect to get about 200 Watts of audio per side with this amp. You can get about 400 Watts RMS (600 Watts peak) using 4 ohm speakers.
The efficiency of the speakers makes a lot of difference in the sound level output/
Sep 15, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
I'm running a tape player into one of the mic channels, then out the tape out; problem is any stereo presence is lost. Is it possible to run a 1/8" to RCA in the RCA in, route that to the level meter/main...
Each mic channel is MONO. You could use a 1/8 stereo splitter cable into two mic channels and then PAN them opposite to retain the stereo.
You can also use a splitter cable into the 1/4 inch stereo inputs on the mixer. The 1/8 inch plug must be a stereo plug that then splits to two RCA plugs or two 1/4 inch plugs.
Note that the manual specifies that the Tape/CD out is merely paralleled off the mains out. This means that your main fader controls the level to the CD/TAPE output... which may mean your main output has to be too loud to get adequate output from the CD/TAPE outs to be effective. This would require balancing the levels into your external amp better.
Aug 05, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Can't send instruments (live or recordings) to the tape output.. (does not see signal in Cubasis)
Anything you hear in the mains SHOULD come out the "tape out" jacks UNLESS you have the "tape to mains" button pressed in. (That is for driving the mains from tape or CD) Remember these are line level signals.
Not sure about Cybasis? Is that Cubase software? If this is through a USB port, Cubase, if that is what you have, has to be set up to receive the signals onto tracks. There are a lot of things to NOT get set right with this program... Always use a set of headphones to verify that signals are coming through the mixer.
Apr 26, 2010 | Behringer Xenyx 1832fx Mixer 18 Input 32...
Behringer Vmx200 DJ Mixer 2 Channels with Bpm Counter Logo
56 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
