Question about Intel D101GGC Motherboard
Why my computer continuously restart ?
My pc configuration is processor intel p4 2.6 ghz and motherboard is intel D101GGC ram is 1gb ddr1... so on. i formatted my pc for 4 to 5 times successivly but still problem is there my pc is continuously restatred i get irritated why is there a motherboard problem ? because my friend also hav same problem ?
  • 4 Answers
Chodiya why you tuach it
Posted on Jan 20, 2009
2 Suggested Answers
SOURCE: continuse restart my computer
Your problem is not with the operating, the problem is overheating of processor. Kindly remove the processor fan and apply gray thermal solution and the problem will be solved. Enjoy...... using your computer
Posted on Jan 28, 2009
Does Intel Pentium 4, 2 GHz Processor support 2GB DDR1 RAM..?
Type of RAM supported has nothing to do with the processor make & type in most cases. It is more important to verify that the motherboard supports this kind of RAM.
In general, most motherboards supporting the Intel Pentium 4 2.0 GHz processor support also DDR1 RAM.
Sep 05, 2011 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
Is it possible to add 1GB DDR1 RAM 333 MHZ to INTEl D101 GGC
u can use the 1gb ddr1 ram,if the sound is coming then may there is two problem
1.may be the ram is damage
2.your motherboard is not supporting 333mhz bus support
try to find 400mhz ram instead of 333mhz
Feb 27, 2010 | Intel D101GGC Motherboard
**** for replacement (intel motherboard)
ask or take to where you bought from
Mar 21, 2009 | Intel D101GGC Motherboard
Does my computer compatible to upgrade RAM?
Yes. It should easily adapt a 1GB Ram. The 32bit processors can genarally take upto 3GB of RAM
Feb 22, 2009 | E-Machines eMachines Desktop PC
Windows xp crashes frequently after inserting new RAM.
try to use one ram at a time if the 1gb ram does not gve any error thn the 256 mb ram is the culprit and if the opposite happens than 1 gb is culprit yur ram slot also may ve got damaged somehow if the ram is culprit and ti is under warranty get it replced with the same memory clock one
Jan 29, 2009 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Continuse restart my computer
Your CPU is overheating
1) Turn off computer and remove case side
2) remove fan from "heatsink" do NOT remove Heatsink "Usually this is stuck with solidified heat paste"
3) clean all dust and dirt from heatsink and fan.
4) vacuum out case Include behind power supply and video card.and any other fans
5) use stiff brush and vacuum outside of power supply
Reboot and see if still restarts if not everything OK
shutdown PC and refit case side.
This is a common problem on a lot of computers as the environment they are used in is usually dusty.
I do mine every 3/4 months and have no problems like this
Please when works give me a fixya
Jan 26, 2009 | Intel D101GGC Motherboard
Vista compatiable
intel doesnt list any vista drivers for that motherboard on there site so you might run into problems with the intergraded devices such as the ethernet,audio,chipset, & any intergraded video
You might be able to use the xp drivers but if theres problems it wouldnt be supported by intel
Nov 26, 2008 | Intel D101GGC Motherboard
Memory Upgrade
ask for ddr1 ram of 1 gb.also take your old ram which is at present in your pc to match the locks with the new ram.
it will cost u near to 50$.
thanks.
Sep 18, 2008 | Intel D101GGC Motherboard
D101 Motherboard sound and speed problem
CHeck for VIRUS presence on your hard drives! use other ANTI-Virus if necessary!
Nov 30, 2007 | Intel D101GGC Motherboard
Intel D101GGC Motherboard Logo
94 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
