Question about Vehicle Parts & Accessories
Repair for a temp gauge for 1990 mercedes benz
Temp gauge not working
    Novelist:
  • 157 Answers
Remove thew temp sender wire and ground it. watch to see if the gauge goes to full....inoperative temperature sending unit? system filled up with coolant???
Posted on Nov 20, 2013
Has one code po507, won't reset, won't start, but it will run, if I spray starting fluid in the air box
Search Results
    P0507 Mercedes-Benz - Engine-Codes.com
    engine-codes.com/p0507_mercedes-benz.html
    Possible Causes and Repair Information for P0507 Mercedes-Benz code. Learn what does P0507 Mercedes-Benz means? P0507 Mercedes-Benz Idle Control ...
Aug 01, 2015 | Mercedes W202 C230 C280 Rear View Mirror...
Tip
My 1987 250D benz does not have this problem, actually the temp gauge is alway...
This is listed under the 300 series but fits most 90's Mercedes Benz cooling systems.
The first thing most people notice about there Mercedes benz is the the temperature needle climbs or sneaks towards the red in there car. This is not uncommon. Is it wrong or bad for the vehicle? The plain answer is no.
First lets talk about what is going on. The motor heats the water, the thermostat holds most of the water back to keep the block a more constant temperature. The water pump is always pumping while the motor is running so none of the hot water goes the wrong way backwards into the radiator or coolant overflow tank. The radiator is cooling off the coolant by either driving, viscous fan or the electric fan or fans your Mercedes has up front when stopped or slowed. When the thermostat reaches its set temp around 85-95 it fully open until the block fills with cooler water then shuts again, filling the radiator with hot water to be cooled. All in all pretty simple system to keep the block cool and evenly heated to keep stresses down.
Now some do not like the fact there system goes so close to red. Well one contributor is the Air conditioning system. When that compressor kicks on it basically is just a pump that transfers heat out of the car into the engine compartment making the cooling system work harder.
Another cause of climbing heat systems is a failed thermostat closed or open that keeps the system water hot in the block or hot throughout the system. Best fix is to of course replace it. Just follow the top hose unbolt it from the block and insert the new unit with proper gasket and direction and its good to go.
A bad or failing water pump can limit water circulation so if your car doesnt cool off after replacing the thermostat its the next to replace. Kind of not a simple Do It Yourself job with all the belt and pulley issues that may come up due to age. Not impossible just not easy.
Leaks in the system can cause boiling and rising temperatures so look around. The coolant tank small hose to the radiator on either end is normally the first, or even the winshield washer deicer or heater core lines. Cap can go bad but you will normally see a bad gasket on it if it fails.
Radiators can become clogged with scale after years and years of service with limited flushes and not adding distilled water. Sometimes the plastic cracks and just need replaced.
Ok now there are some external parts to the coolant system that directly effect it.
The viscous fan, it can lose the oil it has internally and not spin enough to cool. The rule is with the engine running if you can stop it easily with a rolled up newspaper replace it.
The engine temp sensor is normally 2 wire sensor near the front of the engine close to the intake normally. When it goes bad it will not let the electric fans come on when needed. If your having issues, cheap fix replace it.
The last piece of the system is the electric fan/fans. These have alot of integrated systems to look at if they do not work so just be careful. First there fuse is not in the fuse box. It is a aluminum strip fuse normally located on the firewall inboard of the brake booster in a tootsie roll sized container. When it goes out the fans do not come on. First without the A/C on operation is as follows 105 fans kick on low speed kick off at 95. So as you can see the needle will easily climb close to red in traffic again stay calm this can be normal. When the A/C is engaged (in a system with proper charge and working order) the high speed fan operation will happen independent of engine temp. This is because all the heat being transfered by the compressor as noted earlier.
I hope this sheds some light on some cooling system woes of anyone. This may apply to alot more vehicles but is specific to Mercedes. Operation of the coolant system is similar no matter what car you drive (unless its electric or air cooled of course).
Thank you.
on Jun 22, 2010 | Mercedes-Benz 300-Class Cars & Trucks
I need Mercedes E200 model 1990 manual catalogue
We have no repair manuals here at fixya. You can pay to access them here
Oct 08, 2012 | 1990 Mercedes-Benz E-Class
Temp gage is not working how do i fix
Welcome to FIxYa.com
Ground the sensor wire to ground does gauge go to hot if so replace sensor
Regards, Lee Davidian
Thank you for using FixYa.com
Nov 03, 2010 | 1987 Mercedes-Benz Mercedes Benz 190 Class
How to repair 1990 mercedes benz sun roof it dont work
Welcome to FIxYa.co
Check fuse. Do you hear the motor working but no movement
There is a new cable design
Nov 02, 2010 | 1990 Mercedes-Benz 190
Electrical Instrument cluster does not function
I had the same problem with a car i owned and found out it was a short in the wireing in the dash, you will have too have it re-wired, but too be certain you should have it checked out by a mechanic in your city.........
May 22, 2009 | 1990 Mercedes-Benz E-Class
HOW DOES GAS GAUGE WORK WHAT DOES THE GOLD OR GREEN LIGHT MEAN ON MERCEDES BENZ 300 E 1990. WHERE CAN I GET A FREE OWNERS MANUAL
the gold or green light means that you need to add gas the lights are a warning that you have approx. 40 miles left before you run out of gas.
Apr 15, 2009 | 1990 Mercedes-Benz E-Class
Cooling system of motor don't work properly, above 80 degree Celsius then it start to work!!! What's wrong??
Thermal temp switch usualy located at the bottom of the radiator or the temp gauge sensor is sending wrong temp signal to gauge. Have you put radiator thermometer in radiator to test that its all working when its supposed to?
Oct 30, 2008 | 1992 Mercedes-Benz E-Class
Mercedes 190e
in 190d ,engine 2.0.l diesel this thing is lokated near oil filter.
Aug 23, 2008 | 1990 Mercedes-Benz 190
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
