Question about Atwood LP Gas Water Heater 6 Gal 96117 GC6AA-8
Atwood 6gal self ignite wont stay lit
Burner clicks off right away
  • Atwood Master
  • 6,674 Answers
Are you sure of model number, as it doesn't indicate electronic ignition. That said, if you do have electronic ignition, there is a small thermal cut-out in power line (brown wire) to thermostat terminal. It is inside the clear plastic sleeve and is connected between power wire and thermostat. Pull it apart and remove that thermal cut out temporarily and just connect wire direct to thermostat terminal where other end came off. Now try it, if it ignites and runs good, replace that thermal cut out. If no better, get back to me. That thermal cut out is a safety device in case of flame up, so be sure to replace it once diagnosis confirms it is defective.
Posted on Jan 07, 2013
Hi i have a atwood 22.7 litre water heater model mpd93754 . IT ignites heats water, but wont shut off when it gets too hot. could you please help solve this problem . many thanks rod baker.
Gas control valve thermostat might be bad.
The copper cylinder located on back of gas control that sticks into water is the thermostat.
If thermostat is not reading correct temperature, then gas might stay lit.
Usually the gas control will sense overheated water and trip the ECO so no gas will flow to burner.
In any case, the gas control valve is replaced.
http://www.adventurerv.net/images/91601.jpg
Open following links to see typical manuals, service manual, parts link, and other resources:
http://waterheatertimer.org/Atwood-water-heater-resources.html
Jul 28, 2011 | RTO Atwood Water Heater - 6 Gal LP
I have a Jayco pop up with an Atwood water heater, serial # 37C14U-5. My problem is two-fold. The water heater pilot doesn't stay lit after initial run, and propane is leaking out of the vent on the...
Leaking propane is red flag #1 and fire hazard.
Immediately update your insurance and then turn off gas.
If pilot is not staying lit, then gas leak can be cause of pilot problem since pressure on the line is reduced.
Other causes include bad gas control valve, air in the gas line, bad thermocouple, burner parts need cleaning, or all the above.
After fixing leak, replace thermocouple, clean combustion chamber and burner parts, and bleed gas line to remove air.
More resources:
Jun 28, 2011 | RTO Atwood Water Heater - 6 Gal LP
Pilot wont stay lit
change the thermocouple , its the little copper tube that runs from the gas switch to the burner itself
Jun 10, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
Just installed a 425 hn, the igniter clicks and the pilotflame goes on and off at the same rate as the igniter clicking. The main burners will not kick on. Checked all the electrical connections, checked...
I am not aquainted with the Bosch..... But it is a heater. I am going from past experience with gas furnaces and how the process works..... You said that you can get the pilot to stay on if you unhook the Main Gas Valve wire. Do you have 24 Volt power on that wire to Common? Does this have a Flame Sensor? Maybe it got damaged. Does it have a good ground from the burner to the ignition control module? Does that wire to the electro valve go into a plug that plugs into the ignition control.... Maybe that pin is not making contact to the board. Hope this helps If no one else answer right away repost Or call and see if you can get Tech support from Bosch..... I know how frustrating it is you buy something brand new and it doesn't work
Feb 01, 2011 | Bosch 425HN NG Tankless Water Heater
Burner lites but goes out after 2 or 3 min.
the white rodgers gas control needs to be replaced;
the way it works is: the thermocouple opens the pilot gas circuit and, holds it open
when it heats up by creating a magnetic field in the gas control then: when you turn
the knob on the gas control to "on" a valve inside the gas valve opens the main gas circuit and, electricity supplied by your RV keeps it open.
the main gas coil inside the gas valve is defective and, can not hold the main gas circuit to the burner open anymore.
Jul 24, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have an Atwood 6gal hot water heater with a 37c14u-5 controller. The pilot light will not stay lit. I have replaced the thermal coupler twice and the pilot tube with orfice once. It's still not...
Try removing the thermocouple where it attaches to gas control, and spray a little WD-40 in the hole, then spin a rolled up small piece of steel wool in the hole as well, then blow it out with compressed air if you can. Then reconnect thermocouple. Make sure thermocouple tip is getting good flame under it, and if that doesn't cure it, then it's time to replace gas control.
Jun 23, 2010 | RTO Atwood Water Heater - 6 Gal LP
Atwood water heater light doesnt stay on
That light in the switch should only be on momentarily while it is igniting, and then go out when everything is ok. If light stays on, it's to alert you that for some reason, the burner did not ignite, such as propane is off, or some other reason it didn't ignite. If the light stay out, then the burner should be working properly.
Oct 07, 2009 | RTO Atwood Water Heater - 6 Gal LP
The pilot light & will stay lit. untill the burner cycles on/off
MAKE SURE THE BURNER TUBE AND ORIFICES ARE CLEAN. MAKE SURE YOU HAVE THE PROPER LP PRESSURE.
Oct 05, 2009 | RTO Atwood Water Heater - 6 Gal LP
I replace my thermal coupling. burner doesn't ignite
is the burner assembly sitting pronperly on it;s cradle,, this will put it at just the right distance for it to ignite,,
Jun 15, 2009 | RTO Atwood Water Heater - 6 Gal LP
Wont Stay Lit
I would suggest that you replace the thermo-couple. It is a long, slender copper "wire" that runs from the control unit to inside of the unit. THe thermo couple's job is to regulate the pilot light and the lit flame as well.
They generally cost about $10 and take 10 minutes to replace. Some of them are reversed threaded (rights loosen, lefty tighty) and some of them are regular threaded (righty tighty, lefty loosen). TUrn off the gas supply at the meter or an external valve and remove the thermo couple by unthreading it at the control unit. Bring that with you to the hardware store (lowes or Homedepot) to make finding the correct one a simple task.
I hope this helps.
Apr 24, 2009 | RTO Atwood Water Heater - 6 Gal LP
Atwood LP Gas Water Heater 6 Gal 96117 GC6AA-8 Logo
71 people viewed this question
Top Atwood Water Heaters Experts
Lawrence Oravetz
Richard416282
Gene Haynes
Are you an Atwood Water Heater Expert? Answer questions, earn points and help others
