Not blowing cold air
I have a centrex split wall mounted air conditioner the model is a ctar65gw it will not blow cold air, there is no water coming out of the overflow pipe outside everything seems to be running besides its blowing room at temp can you help me out
  • joarraj Feb 02, 2009
    i have same make and model,,, i have noticed that it is nowhere near as cold s it was ..... and now the bloody thing turns itself off every 15 minutes...
    good luck, will follow you answers to try help mine
    Novelist:
  • 88 Answers
Sounds to me like your compressor is not operating, first check the filter to make sure its not pluged up, if thats not it, you will need a qualified service tech to come a diagnos it for you, but sounds to me like the compressor is bad, hope that helps
Posted on Jan 20, 2009
How do i stop the leak on my panasonic air conditioner
You need to blow out the drain hose, it's clogged. You can use a water hose to flush out the line.
Sep 19, 2014 | Panasonic CS-MKE12NKU Mini Split Wall...
HOW DO I CHECK AND CORRECT THE FREON LEVEL FOR MY SANYO KS1271 A/C; WHICH IS NOT BLOWING COLD AIR?
Hire a tech it will be cheaper and safer. You may have a capacitor that is bad and not starting the compressor.
Aug 22, 2014 | Sanyo KS1271 11,900 BTU Ductless...
What could be causing one of the wall mount units to ice up on a 3 port mini split hp?
Icing is caused by one of two things.
1. The air coming in is too much and has a lot of water vapor in it.
2. The evaporator is too cold. This could be because of a low refrigerant charge
Jun 04, 2013 | Fujitsu ASU7RLF HFI Wall Mounted Mini...
My ac is not blowing cold air?
There can be multiple reasons for this. Is the outside condensing unit running? and this is assuming that the wall hung AHU is blowing? Also is there any tripped breakers/ burnt fuses, etc.? With a few more variables answered we may be able to come up with the solution to your problem.
Sep 23, 2011 | LG LS-L1210CL Mini Split Air Conditioner
My portable air conditioner stops blowing cool air after a while and the light is flashing with a sign "lo" Does anyone know what this means?
Flashing lights are generally a sign of something wrong or something needs attention. Try emptying the water canister, cleaning the filters etc.. Not sure what LO means on your model. LO on some wall mounted splits means that the room temperature is below what the remote control can pick up.
Jul 03, 2011 | Heating & Cooling
My air conditioner dont blow cold air in cold mode
Hi!!
Not enough info. Ned type make and model. Central,split, tru-wall???
Aug 14, 2010 | Heating & Cooling
Anyone know where I can get a fan motor for the indoor unit of my centrex CTAR65GW split system air conditioner. i think the motor may be generic for most of the cheaper split air conditioners. Denis
I buy alot of those motors through www.grainger.com
match up the hp, rpm, shaft size, mounting, voltage, etc... this can take a bit, but you will find a motor for partically anything there...
heatman101
Aug 11, 2010 | Heating & Cooling
Panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Jul 17, 2009 | Carrier 52PQ307 Wall/Window Air...
Centrex a/c keeps shutting off every 15 minutes ( split system)
To start, check your condencer fan and make sure the condenser is clean.After that you will need a technician with instruments. If the switching off is constant, after approx. every 15 min.it could be switching off on high pressure.
Feb 02, 2009 | Heating & Cooling
Heating & Cooling Logo
218 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
