Question about Cuisinart CBK-200 Bread Maker
Motor runs paddle does not move
Cuisinart bread machine paddle does not move
  • ursulinead
    ursulinead Mar 05, 2013
    It has taken me this long to figure out the tool I need to get off two of the legs/screws. The belt is in place. Any other suggestions?
    Genius:
  • Cuisinart Master
  • 1,280 Answers
Your drive belt is probably broken or has slipped off. unplug your machine and turn it on its side (remove the pan and paddle first) and remove the bottom panel with a screwdriver. You will then be able to see if the belt is broken or has slipped off. You can reach me at breadmachineshelp.com for reinstall or replacement of your belt.
Posted on Jan 11, 2013
  • 1 more comment
  • Daryl Nash
    Daryl Nash Mar 06, 2013
    Ok, with the pan and paddle out of the machine and with the machine still on its side plug it in and choose the basic white bread program and then push the START button. Does the large pully wheel turn around and around?
  • Daryl Nash
    If it does turn around and around then go ahead and push the START/STOP BUTTON AGAIN TO END THE PROGRAM. If it doesn't spin around an around then you do have a serious problem.
  • ursulinead
    ursulinead Mar 06, 2013
    I did everything you said and it works perfectly as of now. Of course, I'm having a terrible time getting the bottom plate back on. grrrrr Thanks!
4 Suggested Answers
SOURCE: how do i remove the
 Grasp pan handle with a potholder, press down on outrer housing,lift handle sharply releasing pan .Now who can tell me how to stop my CBK200 from burning each& every loaf?        Dave from Succasunna,N.J.
Posted on Dec 17, 2008
SOURCE: I bought my Cuisinart Bread
check the underside of the basket. I have had problems with the lock washer, causing the wing nut to slip and not providing any turn to the shaft and paddle.
Posted on Feb 28, 2011
daryl441918
  • 1280 Answers
SOURCE: I have a cuisinart CBK
some machines do just rotate in one direction and that is enough to knead the dough. Was the final result (the baked loaf) not satisfactory?
Posted on Sep 19, 2011
Why does bread deflate?
See if the paddle shaft in the bottom of the pan is frozen. If it is, free it up manually. Then get it good and dry and oil it with cooking oil. After that, every time you bake, put the oil for the recipe in first and turn the paddle until it moves freely. Once the oil is in the bearing, it will keep the water out and the machine will move properly. I have gotten away with this fix for hundreds of loaves.
Jul 09, 2014 | Cuisinart CBK-200 Bread Maker
Cuisinart cbk-200 bread pan paddle does not turn.
Your drive belt is probably broken or has slipped off. Unplug your machine and turn it on its side (remove the pan and paddle first) and remove the bottom panel with a screwdriver. Most bread machines have a removable panel. Hopefully yours is one of those. You will then be able to see if the belt is broken or has slipped off. You can reach me at breadmachineshelp.com for reinstall or replacement of your belt. If your belt has a number code on it I will need that. It will look something like this: STS 60 S3M471 If it has no code on it I still may be able to figure out the belt you need. Again, reach me at my website: breadmachineshelp.com
Mar 18, 2013 | Cuisinart CBK-200 Bread Maker
While the machine is kneading it makes an awful grinding sound.It sounds like the paddle is not moving.If you lift the dough up the paddle moves freely.
It sounds like your belt is slipping. All bread machine operate off of an electric motor and drive belt and they do wear out.
Feb 16, 2011 | Toastmaster 1142 Bread Maker
I bought my Cuisinart Bread Maker in February 2007 and it worked well until now. Yesterday I started to make Dough cycle. First 2 minutes machine kneaded the dough correctly as usual but suddenly...
Sep 22, 2010 | Cuisinart CBK-200 Bread Maker
The machine gets warm but the paddle doesn't turn.
Hi, The paddle should turn freely by hand with the bread pan out of the machine. Make sure the pan is inserted in the machine correctly. If the motor shaft turns but the paddle doesn't then the sealed bearing that the paddle rotates on has failed and is frozen so the paddle does not turn.. You may need a new bread pan. Hank
Jul 01, 2010 | Kenmore KTR2205SPR Bread Maker
Kneeding seems to jam frequently
Hi, Take the bread pan and paddle out of the machine and see if the paddle spins freely by hand. If it sticks then the sealed bearing is failing. If everything is good here, check the tension on the belt pulley. The belt may be too loose to spin the paddle freely under load. Belt and motor is inside the base of the machine. Good Luck..Hank
Mar 13, 2010 | Cuisinart CBK-200 Bread Maker
Basket is not staying in place during the kneading process and the noise is unbelievable! Help!
Take the bread pan out of the machine. Start a kneading cycle and see if the noise is still there. If yes then motor spindle is bent, the motor is bad or the belts are pulleys need attention. If the noise you heard is not as bad, then it is the seal on the bread pan ( the seal and shaft that the paddle goes on).
Hank
Nov 18, 2009 | Cuisinart Kitchen Appliances - Others
Cuisinart CBK-200 Bread Maker Logo
159 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
