Question: Is it possible to program HD channels available through basic cable service? Or: is the auto channel preset function able to program channel numbers with 4 characters (example: 1001, or higher channel numbers) where the HD options reside? Model Information: Make: Pioneer Elite Model: PRO 530HD Cable Setup Information: Basic cable service = Time Warmer No cable box for this set up Basic cable wire attached directly to TV Procedure Attempted Already: In menu options: Tools, channel set up, auto channel preset = scans all channels signals The channel scan did not appear to auto-program the HD channels available through basic cable.
SOURCE: Toshiba 26AV502U Won't Pick Up Channels
Hi albertogiler,
I am happy to help, you will need to attach a antenna to the tv to pick up OTA over the air signals, depending on your location you may be able to use a set of rabbit ears, I have provided a link to a site that will explain in depth.
http://www.antennaweb.org/aw/welcome.aspx
Let me know if this helps and please rate this solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: no tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
SOURCE: Dynex 32 Inch Installation Problem
Hi I Just Bought A Dynex 32 Inch HDTV. I Did A Auto Scan And It Didnt Pick Up Any Digital Channels? Am I Suppose To Have An Antenna Or Digital Box? How Do I Get Th Channels To Come In?
Hello, the HDTV input is what you would use if you were not using a cable box.
You should connect your cable from the wall to coaxial input on the cable box, and connect an hdmi cable from the hdmi output on the cable box to the hdmi 1 input on your tv and then switch the tv to that input.
Tommy,
HD Installations
SOURCE: channel scan only finds 1
the LG will scan several tuning bands TV, DTV, CATV, CADTV
you must let it work through all of these in programming mode.
use the channel up and down button to see just what it has picked up.
the Manual Channel menu will allow you to add or delete what channels you want to surf.
if your programming in unsuccesful, unplug the TV (power) for five seconds then plug back in (reboot)
and attempt the complete setup all over again.
if it still fails, your tuner is bad...which means you need a new main board.
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable (CATV)
channels.
? When AUTO PRESET CH action is completed, the lowest memorized
channel reappears on the screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH",
the tuner will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by receiving conditions. In this case,
try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input, "NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
OK.
