Switching on & off until 9 blinks on error code
Switches on for 20 sec & off for 10 sec. again and again until goes to off and getting 9 blinks on error code.
  • m_kokkonis
    m_kokkonis Jan 08, 2013
    Thanks all for your support, TV is sony kdl32S2530. It switches on at the begining stays on with TV signal (showing channel) for 15-20 sec and then switches off for 10-15 sec. It does that for 5-10 times (repeats on & off) and then goes to OFF finally with the self diagnosis code on the power led -9 blinks-. I read from trablesooting(internet sites) that the spesific error has the following possible cause: Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. .... >> I can't find the specific diodes on the G1 power printed board. The only thing I'm thinking at the time is to replace the PowerMOSFETS K3561 & K3683 as well as the diodes FCQ10U06 FSF05A60. The capacitors are measured by the multimeter and seemed OK. Thank all of you Maximos.
freetek
  • 5568 Answers
SOURCE: cant switch it on!
Sounds very much like a main power supply that needs a 'kick' to start up. This is often caused by the loss of value of a capacitor in the power supply, one that handles feedback to start the supply initially and carries the signal to shut it down in case of a circuit fault in one of the areas the supply services. Inadequate feedback will make the supply unable to start properly and more likely to shut down even though no fault condition exists. If I'm right, it will get worse and searching for the problem requires an instrument not found in the average home; a capacitance meter with loss measuring capabilities.
Posted on Sep 11, 2008
  • 267 Answers
SOURCE: Panasonic TH42PZ70B
You have an internal problem. take it to an authorized servicer.
Posted on Mar 06, 2009
  • 233 Answers
SOURCE: 37PF5320/10
Hello, I would advise as I do not know all the specifics to try to give the T.V. a signal from a cable box or dvd player. Then I would unplug the T.V. for about 5 minutes and then plug it back in and try to turn it on. Most newer televisions will have a One Year warranty included at the time of purchase so if all else fails, you maybe able to get a warranty replacement.
Posted on Jun 10, 2009
  • 1738 Answers
SOURCE: When i turn my tv it goes on and off for 10-20
Sounds like, and no it usually take a professional to replace. Trust me there tiny parts in there. Some tv's takes speacial tools to take apart without damage them.
Posted on Oct 22, 2009
  • 10865 Answers
SOURCE: 42 inch philips plasma just turns itself off. when
There can be several causes for this, few of which you can do anything about. However, a few things to try:
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
I hope this helps. Joe
Posted on Mar 31, 2010
No video 9 blinks of red light. if hold power button 30 sec will come on
Sounds like main power supply regulator bard fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 14, 2015 | Panasonic TCP58S1 TCP58S1 58"" Plasma
Panasonic th-42pz80ba Turns off by itself then standby light starts blinking 7 times pause 7 times again fault solving please ? And part replacement ?
If blinks continue without any pause, the main board is faulty.
Jan 21, 2015 | Panasonic Televison & Video
Why my Sony Wega tv standby light blinks 10 times?
Aug 23, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
When I turn my Sony TV on I get 10 flashing lights, the sound comes on for a few seconds ad then goes silent. I get no video at all. I power it up again (with the 10 flashes running) and the audio comes...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Feb 15, 2018 | Sony Grand WEGA KDP-65WS550 65" Rear...
Problem with a Sony KLV-26HG2 LCD tv switching on for 2 secs then switching off/ flashing standby light
http://electro-medical.blogspot.com/
Apr 12, 2012 | Sony WEGA KLV-26HG2 26 in. HD-Ready LCD...
Reset photoconductor unit gestetner dsm415
Zeroizing the counter Fotocondactor. The Sign - twinkle all lamps, in readiness not vyhodit.
1 To Press "copy" and include feeding with pressed кнопой. All indicators, except "Ready", light.
2 Release "Copy", press her(it) once again and keep until it is ed indicators "Toner" and "Paper" 10 sec
3 Release button. Switch off feeding, wait 15-20 sec, include once again
Sep 23, 2009 | Gestetner DSm415pf Digital Imaging Sytem
Alarm light on and u051 error mx310
Hi
You’ll need to reset your printer to clear the ink counters, after resetting it’ll not display the error code again. Follow this procedure to reset the printer--
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset.
Please rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Canon PIXMA MX310 All-In-One Printer
Akai hdtv 1080i no picture
http://homenol.blogspot.com/
Sep 02, 2017 | Akai PTH5498 54" Rear Projection...
Reprogram remote
xl-7 programming instructions first you need to stuff your head up under the dash and locate your module drivers side upper corner under dash does it say programmable transmitter (the first models had no programable modules) if it says that then......
1 confirm all doors are shut and key is out of ignition
2 open drivers door insert key and turn to on within 10 sec
3 turn ignition switch to off in 10 sec
4 push and release drivers door switch 3 times in 20 sec
5 turn ign. switch to on in 10 sec
6 turn ign. switch to off in 10 sec
7 press and hold lock and unlock button on transmitter for 5 sec within 20 sec of step 6 alldoors will lock/unlockto confirm correct process
8 press lock unlock buttons on second remote within 5 sec after step 7 once again all doors will lock/unlock to confirm
9 to add another remote up to a max of four repeat steps 1 through 8 this was taken directly out of an owners manual supplement that comes with a new keyless entry kit (part number for a xl-7 or grand vitara can't remember which one it goes to but it works on either one is 84900-67810) which you would have to purchase if yours is not programable these instructions are the same for vitara, grand vitara, xl-7 and the esteem hope this helps
Jul 05, 2008 | 2002 Suzuki Grand Vitara
Standby Light blinks
it is an error code of the sony maybe there is a problem in it.
Apr 09, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
