Question about Bosch TASSIMO Coffee Makers & Espresso Machines
Bosch Tassimo coffee maker trips breaker
When powering on the ground fault breaker trips. The unit has been dry for weeks. Internal inspection does not reveal any obvious problems. Is there a common component failure that would cause this?
  • 3 Answers
SOURCE: NOT SO GREAT COFFEE GROUNDS!
Might there be some stuff crusting the dispanser vent? Did you clean it regularly? If you've not done that, this is what you do:
1) Open up the lid where the T-Disc is supposed to go.
2) Take out any moveable (not breakable) object, for instance the thing that punctuates the T-Disc(its made of two parts stuck together) and the T-Disc holder.
3) Take 'em apart and put 'em into your dishwasher or wash it by hand.
4) Wipe the entire T-disc area with a damp cloth, make sure nothing stays there that isn't supposed to be there.
5) Put the removed and cleaned parts back very carefully and watch out that they are exactly in place, if in doubt wheter they are fitted correctly, just shake them a little. There should be no movement other than up and down.
6) Enjoy your coffee!
Posted on Jan 23, 2009
  • 131 Answers
SOURCE: Bunn coffee maker trips the breaker
It is possible that you have a short in your limit thermostat, but most likely this is caused by small holes in your main heating element. these units start to split length ways down the element, causing a short to ground through the water. These elements are readily available at your local Bunn repair shop.
Posted on Feb 13, 2009
SOURCE: Tassimo machine leaking water underneath
I'm having the same problem with my machine. I rang the Tassimo careline and they told me to descale the machine but, so far, this has only made matters worse. I'm now going to take it back to where I got it from because it's still within its warranty.
Posted on Nov 20, 2009
SOURCE: trips ground fault on plugging into receptacle
I just opened one of the machines with this issue and found that the heating element is entirely ripped open (over the length of the coiled heating element) and the water contaminated with brownish stuff from within the element.
Was wondering if that part can be replaced.
Posted on Nov 30, 2009
SOURCE: manual instructions bosch tassimo coffee maker
hi, this morning I was making a capuccino, and the first part was fine, the expresso was fine, I waited for the light to change colors, open the lid, put disc with the cream in the machine and the green light won't come on, only the yellow on the left hand side and is not working<br /><br />
Posted on Aug 23, 2010
Sta-rite heater is about a year old. It worked well up until a week ago. It now trips the gfi breaker. I swapped out the breaker and it trips that too. If I disconnect the exhaust fan, the heater powe
Something in the electrical system supplied by the GFI breaker has a ground fault. The current to ground required to trip a GFI is very little such that dampness on any electrical connection can trip it. This is especially true with motors that have a lot of fine wires in the windings and are open to allow cooling.
Hard water and pool chemicals all are worse than condensation from the air because of their ionic nature.
If the same GFI powers the pump it is what I would suspect first. Your question got cut off before the result of the fan disconnect which if disconnected didn't trip the GFI, is probably the problem. But you should open whatever you can access containing electrical components and make sure everything is dry
Feb 07, 2015 | Sta Rite Pool & Spa
I bought a used washing machine that was stored I outside while it snowed. How many days should I let it dry out before I plug it in and use it?
Depends on how long it was stored outside. If just briefly, for one snowfall, 72 hours in a warm, inside the house environment ought to be enough for drying out. I would recommend that you tip the machine on its back after it has dried out this way and inspect the working parts for any signs of obvious damage, mouse nests or bad wiring connections. You might want to use a vacuum with a hose attachment and clean out any obvious dirt or cobwebs too. When powering the unit up for the first time after the drying out and inspection, I would also recommend that you plug it into an outlet with a Ground Fault Interrupter (GFI) either in the outlet itself or on the circuit breaker for that branch circuit in the breaker box. Run a short wash cycle while you physically observe the complete operation of the machine (fill, agitate, empty, rinse, spin etc) and make sure that you don't hear screeching noises (bad bearings) or see or smell smoke from the control panel, belts or motors.
Jan 05, 2015 | Washing Machines
Simoniz S2000 XE02 internal cct breaker keeps tripping after 30secs tried to get a parts break down but that info is really ****** and nothing on line anywhere. Any idea what causes the cct breaker to...
First be very careful because the unit is protected by a ground fault internal circuit interrupter and may trip if there is a short circuit to ground. Even a very small short circuit will trip the circuit breaker.
Something else: If you are plugging it into an already existing ground fault outlet then that may also cause one of the breakers to trip.
Like I first mentioned, if you don't know what your doing be very careful. Electricity and water are not friends, especially if the circuit breaker is tripping.
Good luck,
Marty
Jun 26, 2014 | Coleman Powermate DuraBuilt 1400 PSI...
After being turned off for 4 days through Hurricane Irene... the pump will trip the breaker whenever we turn it on. The switch is good. We can only assume maybe the water is wet. Any suggestions?
I assume when you say breaker you mean a Ground Fault Circuit Interupter (GFCI) breaker or receptacle. If this is the case then what happens is water can get into devices such as pumps and the water can cause unintended electrical paths from 120VAC nodes to the motor frame which is grounded. The GFCI is designed to detect a nominal 5 mA of current to ground and trip. If the GFCI is tripping I would let the motor dry out for a day (if the weather is dry) and try it again.
If by tripping you mean a standard beaker without a test button is tripping then it is tripping because of high current. If this is the case then it may be a water problem but you are just as likely to have a short in the wiring or the motor. I would try shutting off the safety switch, disconnecting the wires to the motor and wrapping the exposed wires with electrical tape. If you turn the switches on that would normally turn on the pump and the breaker again trips you have a problem in the switches or wires. If the breaker does not trip you have a motor problem. You can try to dry it out but probably it has an internal metalic short. If you have access to the location is you could fix it but if not the motor will need to be replaced. I hope this helps.
Aug 29, 2011 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
The 20 amp breaker for our spa circulation trips within hours or as long as one week. Tthe breaker does not trip off but cuts the power. it requires tripping it off then turning back on. Is this a faulty...
This is probably not a faulty breaker. A GFCI breaker is designed to trip when there is a 4-6ma inbalance of current(usually 5) between the two current carrying conductors (hot and nuetral) You may be having a moisture problem. Check all of your electrical connections (with power off) for moisture. If you find any throughly dry (like with hair dryer) and seal to prevent further problems. Your motor may be an open drip proof motor. IF condensation builds inside that coud also cause problem. There are GFCI testers available if you wanted to test your breaker, but for one time it probably isn't practical.
Aug 13, 2010 | General Electric 20 Amp, 1 Pole Thick Type...
Ryobi circular saw --it keeps tripping my breaker
Possible bad circuit breaker. If on a ground fault sensing circuit, the saw may have electrical leakage from it's internal wiring/motor to case ground (a possible problem if you have been using a metal cutting blade)(test by using a 3-pin to 2-pin adapter [no ground pin]). The circuit breaker may not be rated for the starting load of the saw (check the saw load rating against the breaker current rating--the breaker rating should be at least 25% higher). Possible excess current draw in the saw if any of the motor windings have shorted together for whatever reason. Hope this helps!
Feb 06, 2010 | Ryobi Circular Saw W/Dual Laser
Burnt out
internal failure possibly on power side, lower than 300A fault current so unit could not trip i/p protection and as fault was post ac section, continued to burn internally.
it just broke
no breakers tripped out so it kept drawing current until the fault burnt away.
maybe this is what happened, need to know a lot more info to change hypothisis
Jun 01, 2009 | Vector VEC056D 2500 Watt Power Inverter...
Ground Fault circuit Breaker trips each time a load is applied
The most likely causes in their order of probability are: 1) water somewhere in the circuit causing the hot wire to ground; 2) a legitimate trip caused by a defect in a device plugged into the circuit; and 3) a defective GFCI breaker. In the first case, wait until it has been dry for about a week and see if it trips. In the second case, make sure there is nothing plugged into the circuit and try resetting. In the third case go ahead and put the regular breaker in, then put a GFCI outlet into the first box downstream from the breaker. If installed according to the directions, that outlet should protect all of the outlets downstream.
Feb 26, 2009 | Cutler Hammer 1 Pole 15 Amp Ground Fault
Circut Breaker trips
  • i have no experience with RV units but if it were in a house i would suspect a bad breaker or a problem with the outlet itself. breakers  only trip when the wiring is gets hot.
  • unless it is a ground fault breaker (usually on the outlet) then this would trip if the flow of electricity is grounded. ground fault breakers do go bad often.
  • i think if the refrigerator itself had a problem then it would be consistent (as far as it is pulling amps anyway). not work fine sometimes and not others.
Jul 08, 2008 | Dometic NDR 1292 Refrigerator
Throws Breakers
Check the power cord for damage, and repair anything you find.
If confident enough, open the unit up and inspect all the internal wiring - check for chafed wires and for terminals that have come undone or that are touching anything they aren't obviously meant to.
Check the unit hasn't got wet inside - mop dry then leave to dry out properly in warm air for a couple of days if it has.
If that doesn't throw up anything obvious, then you're probably looking at insulation breakdown of some component (my money would usually be on the element). For a unit like this, I doubt it's economic to start buting spare parts, so you're probably better off buying a new coffee maker.
Good luck
A.
Feb 23, 2008 | Bunn NHB Coffee Maker
Coffee Makers & Espresso Machines Logo
401 people viewed this question
Top Bosch Coffee Makers & Espresso Machines Experts
Tre Elkins
graybeard32301
Kolbrun...
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
