Question about Jaybird JF3 Freedom Bluetooth Earbuds, Midnight Black
JF3 freedom won't charge
Blueparrrot B250 is 1 year old & it went dead so I
how do you know it is fully charged? i think it may be dead battery
Nov 06, 2012 | Computers & Internet
Toshiba satellite l305d-s5934 Won't charge battery dont power On
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 25, 2012 | Toshiba Satellite L305D-S5934 Notebook
Battery life nikon coolpix s3000
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 06, 2012 | Nikon COOLPIX L18 Digital Camera
Cf moto 250 revs but won't move
no gears?? brakes stuck on, no chain, need more info
Aug 26, 2012 | 2007 C_F Moto 250 Freedom Scooter
My Go gear vibe 4gb MP3 battery is flat and won't recharge.
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 03, 2012 | Philips GOGEAR SA6045 MP3 Player
Battery that was sent won't stay charged, goes from 4 1/2 hr. charge to 0 in a flash if pc is moved, it arrived 1 week a go
you need to contact the people you bought it from & tell them what it's doing & see if it's still under their's warranty?
Sep 13, 2011 | PayPal Accounts
My Minolta Freedom Zoom will turn on and zoom but won't take pictures. The numbers dissapear when you try.
Hi. It could be that the camera needs more memory. Also replace your batteries. if the batteries are low the camera won't run properly.
Jun 26, 2011 | Cameras
I cant find the low pressure recharge port on a 2005 thunderbird so I can charge the air conditioning
Look about 5" from the compressor on the hose assy,
suction or return side
If you need to add refrigerant,& you won't know that
you do,you would have a leak & be breaking federal
laws by trying to add & then poluting the atmosphere
You car & and Lincoln LS are twins for the most part
You need a knowledgable a/c person & a scan tool,
as well as the usually a/c equipment you won't have
You can not add to any vehicle system,as you will let
air into it,it won't take ref under prressure & you may
overcharge it & ruin the compressor or worse
Jun 23, 2011 | 2005 Ford Thunderbird
Jaybird JF3 Freedom Bluetooth Earbuds, Midnight Black Logo
244 people viewed this question
Top Jaybird Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Jaybird Audio Player and Recorder Expert? Answer questions, earn points and help others
