Question about HP PSC 1610 All-In-One InkJet Printer
Printer not printing
Printer will not print it acts like its not connected have checked all plugs everything is good there i was also getting mess. that said new found hard ware or use cd i can't find the cd that came with computer
    Problem Solver:
  • 5 Answers
Ae you using original cartridges and have you tried changing them.Some printers won't print if one is either empty or faulty.
Posted on Jan 20, 2009
Why can't my printer print?
it could be a number of things have you tried checking all of your connections to make sure everything is connected good. Also try turning the printer off and unplugging from wall outlet for 30 secs.If you've done all you can think of go here to http://brother-usa.com/support.
they can probably get you to printing again in no time.
Also check memory make sure its not full.
hope this helps
ELLEN
Support Center
Dec 03, 2015 | Brother MFC Office Equipment & Supplies
Konica Minolta 215 c4001 solution
The sensor inside the print head LASER IS Bad cant get the sensor so need a new print head or the main board is bad , CHECK the connection between them normally the print head has a ribbon cable and a small plug check the ribbin cable especially thr end where there it plugs into the board one of the tine sliver connectors can get messed up using a screw driver GENTLY try to bring the contact material back to normal
Jul 19, 2015 | Konica Minolta Office Equipment & Supplies
My HP C4780 PRINTER WILL PRINT A TEST PAGE BUT NOTHING ELSE. How do I get it to print?
Check the settings in Windows Print Manager.
Make sure that the paper quality matches what is in the printer. If set to glossy, minimal ink is deposited on the page. Also, check the print quality - draft quality provides a minimal amount of ink as well.
Jan 17, 2015 | HP PS C4780 All in One InkJet Printer
Printing blank pages with only website
which browser do you use check it by changing browser and with different web pages
Jan 27, 2013 | Epson NX215 All-In-One InkJet Printer
The printer doesn't print when you tell it to from the computer. When you mess with the buttons, then it will sometimes print a day later.
Its not a net work printer, they how you are connected this printer for all computers & laptops?. It might be connected to one system from there its shared..right. In this situation if any computer fired print command it has to reach the local computer where printer connected. If the local computer shut down, printer unable to print due to no print command.. or else if any net work related issue with in your systems you wont get prints.. Find out were you are stuck. If printer is printing well from the local system you cannot suspect the printer. Just you start from local system, then check in all systems. Pl get back to us for further remedies..best of luck..
Feb 04, 2012 | HP LaserJet 3050 All-In-One Printer
Recently had to reload everything on a new hard drive and reinstalled the Z82 drivers and updated firmware. Printer acts like it is printing but does not print anything. Any suggestions?
do you get anything from the self test? Press Setup until MAINTENANCE appears in the display. Press ?ž?or ?¿until PRINT SELF TEST appears in the second row of the display. Press Enter/Select. The message PRINTING appears in
if that works then it is definitely on the computer if not then you know it is a printer issue. When you plug in the USB cable did the computer react as if something plugged in? Try re-installing the drivers. Make sure the port selected is USB
Nov 30, 2010 | Lexmark Color Z82 InkJet
Can HP 1410 printer support LAN.
HP 1410 is not a network printer. If you want network printing, you must purchase a printer that features network printing.
You can designate a pc to act as network server and plug printer into that server, and then print from another computer on the same network
May 28, 2009 | HP PSC 1410v All-in-One Printer
I can't get the scanner to work on my mp160. The printer and copier work fine.
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-13
Feb 25, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Printer won't print email or confirmation notes
I've ran into a similar problem at a client. They have about 20 printers in the work environment, a few of them are bigger copier/scanner/faxes that prompt for a department code upon printing. A few of the workstations were having problems printing emails to one of these multifunction printers to where the computer acted like everything printed fine, but there was no prompt for the department code so the email did not print. I could go into Word/Excel/Acrobat and it would prompt for a department code and everything would print fine, but Outlook never prompted for this code.
My fix was to just simply reinstall the problem printer and the workstation started prompting for department codes again upon printing from outlook.
Apr 24, 2007 | Epson Stylus Photo R340 InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
22 people viewed this question
Seeker5211
Seeker5211
