Question about HP DeskJet 5550 InkJet Printer
HP Deskjet 5550
The problem of my printer is stock up, it cannot continue to print,, i already replaced the te cartidge, color and black. I think that the problem of my printer is carriage assembly.. but i am not really sure.. can you please hepl about this problem... thanks menace..
  • 432 Answers
I'm not really understanding your question. Does the paper get stuck as it exits the printer?
Posted on Jun 30, 2007
SOURCE:
HP5550. Color ink ran out. Replaced with refilled cartridge, ink light still flashing. If I use an original cartridge this does not happen. Shop tells me cartidges are fine and proved it
some HP printers do this after a non original cartridge used The printer should still be able to operate even with the light flashing. If this does not work you may require to replace the print head.
Mar 21, 2011 | HP DeskJet 5550 InkJet Printer
HP Deskjet 5550 quit printing red color. Installed new color cartridge HP57. Quit printing red again after 5 pages. Is it a printer problem or cartridge problem?
Have you check your color cartridge if they are properly installed.
Make sure your are not using a refill cartridge.
Replace your tri-color cartridge with original an HP tri-color cartridge.
Aug 26, 2010 | HP DeskJet 5550 InkJet Printer
I have an HP 5550 printer. The Ink Cartridge light continually blinks (and nothing prints) when I have both the colored and black cartridges installed. When I remove the black cartidge, it works fine and...
More than likely you have either a defective 56 (black) cartridge or it's empty. If you have Windows XP you may go to control panel and select printers and then right click to get to properties and preferences. From one of those you can get maintenance and attempt to do a clean and see if that works. If you have a cartridge refiller in your area take the cartridge to them and get it weighed....they'll know if it's empty or not by the weight. If you're lucky enough to have a kitchen scale that weighs in gms then weigh it yourself...if it's empty then it will problem be in the mid 20's vs. mid to upper 30s when it's full. EBAY has lots of 56 cartridges for sale and they will usually work just fine. The tri-color ones are more of a crapshoot.
Aug 14, 2010 | HP DeskJet 5550 InkJet Printer
My deskjet 5550 printer stopped printing in color it only print black ink i have replaced the color cartridge still only prints in blank only; i have tried calibrate printer and clean cartridge options;...
If the Cartridge and printer alignment is successfull and you are still not able to print in color, mostly the Color print is disabled in your pc
Click on START Button
Click on CONTROL PANEL
Open Printers and Faxes folder
Highlight the Printer icon for Deskjet
Right click on the printer icon and choose Printing Preferences
Under Printing preferences, you will find Printing mode - It must be on BLACK or GREY SCALE, Change to COLOR/ ALL
try printing.
Jul 03, 2010 | HP DeskJet 5550 InkJet Printer
Hp 5550 deskjet not printing
This is typical cartridge problem.Which cartridge changed?This printer can print with the only one cartridge inside it, whatever which.Try this: Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
If this not help your printer has problem in carriage unit and need repair.
Nov 04, 2009 | HP DeskJet 5550 InkJet Printer
The top orange light is blinking and it says its offline??? What do we do??
One or both print head are defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
Oct 22, 2009 | HP DeskJet 5550 InkJet Printer
HP Deskjet 5550 will not print black&white after cartridge change
Here is a link to a page that explains how to clean the cartridges:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=71895&prodTypeId=18972&prodSeriesId=71895&objectID=bpa00226
Mar 17, 2009 | HP DeskJet 5550 InkJet Printer
Hp 5550, cartridges not recognized,
i had the same problem but i only replaced my black cartrage ink and my color was empty so if one is empty remove it and it will work
Jan 31, 2009 | HP DeskJet 5550 InkJet Printer
Color printing
Hi manatoba,
you have not told that problem was starts after replassing the ink cartridge or for this problem you replased
the cartidge.
First reinstall the printer driver, then reinstall the
cartridge if problem iteel presists takeprints from outher printer
check whether there is a problem or not with the printing if its happen again with the other printer also then ther is a problem with your opereting system,if not presist then problem is in priners card.
I hope after cheaking these things you can able
to solve the problem.
vyas
Apr 19, 2008 | HP DeskJet 5550 InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
49 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
