My heil n9mp2 isnt working just hums
Wont start up just keeps humming
  • shawnie Jan 06, 2013
    its a furnance, not a/c
  • shawnie Jan 07, 2013
    i checked the fuses.... all are fine.... if im not mistaken its on a 110 anyways Walter....... Laura its a furnace and not an a/c..... thanks tho
Is the flame igniting and then cutting off? on a gas furnace, the induction fan motor(draft motor) should start first (if the furnace is so equipped), then the flame, then the blower. if you have an induction motor (flue gas exhaust mmotor) this may be your problem (the induction motor isn't starting), if your unit doesn't have one, have you checked to see that you have gas? finally, the capacitor on the blower motor may be causing the motor not to start.
Posted on Jan 07, 2013
    there's no flame that i see.... and it just hums like its trying to work but something blocking it
3 Suggested Answers
kf4rwe
  • 25 Answers
SOURCE: Intertherm model e3eb020h electric furnace won't start just hums
Check fuses. one may be blown, and the other one not, Therefore you are getting only 110V to a 220v circuit.
Posted on Dec 03, 2008
  • 1078 Answers
SOURCE: the fan hums wont turn goodman air conditioning
If you are talking about the fan on the outdoor unit, let's try some things.
Kill power to the outdoor unit. Use breaker or disconnect. Now see if the fan will spin with no power going to the unit. If not, bad bearings. Fan D.O.A. If it does spin, good.
Now restore power and turn unit on. If fan runs now, it has a defective or damaged winding. Needs replacing. If it does not start running, most likely the capacitor is D.O.A. or the fan is "Electrically" locked up. Again, fan D.O.A.
If you do replace the fan motor, be sure to always replace the capacitor. It's usually only a few buck more.
Also, be extremely careful when trying to spin that fan. It may take off and take a finger with it. NEVER try to spin the fan with power going to it.
This is no joke, it's dangerous if you don't know what your doing.
It may well be worth having a tech check things out for you.
In any case, good luck and again, be extra careful. Never do this type of work alone, in case something happens unexpectedly.
And as a side note, you may find it next to impossible to find anyone to sell you the motor. Most all HVAC parts houses are wholesale only and will not sell to the general public just to HVAC companys. That's because they are trained to do this stuff with out injury.
Think it over and good luck.
Posted on Mar 20, 2009
My 2001 chevy malibu had been working fine up until this afternoon it turns but wont start,itmakes ahumming noise even when i turnoff key.
That humming noise may be your fuel pump burning out. Try turning the key to the on position while someone else listens near the gas tank. The humming should only hum for a few seconds so you won't have time to listen yourself unless you can hear it from inside. If the hum continues and doesnt shut off, it is likely a bad fuel pump. It is normal to hear a small hum for a couple of seconds , but when it starts getting weak, it will hum louder, longer, or not at all
May 11, 2015 | 2001 Chevrolet Malibu
Blower motor
Make sure the capacitor matches with the new motor
Dec 09, 2013 | Weather King 10AJA6001AH Air Conditioner
My truck dont start change fuel pump but still wont start an the fuel pump isnt humming fuses are fine
check for broke wire if you cant here it run then theres got to be a broke wire or ground bad
May 02, 2010 | 1996 Jeep Grand Cherokee
Press the start button on dryer, it hums but wont turn. With 2 people pressed the start button again, held the door switch, reached in turned the drum, it hummed stopped humming then no more nothing....
Sounds like a weak motor. You'll have to get a new motor installed. They are fairly inexpensive and easy to install yourself on that type of machine if you are handy. Motor is located in the bottom right of the machine, attached to the drum belt through a small pulley underneath the drum next to the motor.
Dec 27, 2009 | Dryers
Dryer wont tumble
i think the belt is slipping bad on your dryer,,
what puzzels me is you say you can here the motor hum? is it a hum? or a buzz?? if its a buzz then its more likley to be the motor as its past its best and it needs if it needs a new motor as well, it would work out cheeper to buy a new tumble dryer
Nov 16, 2009 | Dryers
02 grand am died while driving,thought it ran out of gas, put gas in wont start still.have no fuel pressure but security light isnt on.
First off, you should turn the key on and see if you can hear the pump hum for about three seconds. You may have to take the cap off and have an assistant listen for the hum. If there is no hum, locate the relay. It is under the hood in the fuse block. The bottom of the cover should tell the location of it. Most of the relays are the same so swap out an identical one. Try the key again. DON'T TRY TO START. Just see if there is a hum in the on position. If there is no hum, try striking the center of the gas tank with a rubber mallet. One solid blow is enough. Listen again for the hum. It may start, but your pump is definitely bad. It may not start again. To change the pump, siphon the tank as low as possible. Disconnect the wiring, the filler tube and the two straps holding the tank under the car. A new pump will have the rest of the instructions for the job. Good Luck. If the pump does hum, you don't have a problem there. Check for spark. If you have the quad4 engine, check the coil pack cover for wear. It's like an inverted distributor cap mounted to the bottom of the cover, it is white plastic and can break down with age and mileage. If you have another car, have the coil packs tested. Oh and if you do hear the fuel pump turn on, try replacing the fuel filter before dropping the tank to change the fuel pump. Good luck.
Nov 03, 2009 | 2002 Pontiac Grand Am
Lights flashing water wont drain but making a humming noise
hello sir,
Please do the following checks
  1. nspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch (some models)
  4. Inspect the water pump
  5. Inspect the drive belt (belt drive only)
  6. Inspect the motor coupler
Click on the highlighted words for details on how to check.
Jun 04, 2009 | Maytag MAH2400A Front Load Washer
Zenith C27V22 27" TV loud humming noise
There is a coil in the set with a magnet glued to it, called the horizontal linearity coil. Sometimes the coil "sings", making a squeeling sound. I have seen this many times, and there really isnt anything actually electrically wrong with the set. To stop the squeeling the coil should be replaced.
Jun 19, 2007 | Zenith C27V22 27" TV
Heating & Cooling Logo
141 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
