Question about Toshiba Satellite R15 Tablet PC
Clean dust from tablet pc screen
How do i remove the protective cover of my toshiba tablet pc, as there are dust particles behind it.  Now they've become annoying.
model toshiba satellite r15-s829
  • SibylSys May 11, 2010
    are you meaning the plastic cover that sits on top of the lcd screen?
  • Toshiba Master
  • 7,993 Answers
I have an R10 tablet.
I once asked a Toshiba certified technician if I could remove the screen cover and I was told that I am not supposed to do that.
Maybe you shoul take the unit to a Toshiba repair center in your town, or country.
Hope it helps.
Posted on Aug 22, 2009
It won't let me use the touch screen
If you have one of the adhesive touch screen protective covers on it. Remove it and try. I have found that over time these screen covers will start to cause sensitivity issues and need to be replaced.
Jul 20, 2015 | Tablets & eReaders
How to clean ipad screen
best is a microfiber towel which you can buy in many shops and can also be cut in small pieces.
  • microfibers lift dust and oils from delicate surfaces without the use of chemicals
  • Ideal for eyeglass lenses, camera lenses, displays, binoculars, microscopes and other delicate surfaces
  • Non-scratching, non-linting
  • Dirt and particles are trapped within knitted tufts of the fibers
  • Ribbon-shaped fibers lift dirt and grease instead of rolling over it
clean-ipad-screen-megbyxdvyw15034h4mjt4m35-4-0.jpg clean-ipad-screen-megbyxdvyw15034h4mjt4m35-4-2.jpg clean-ipad-screen-megbyxdvyw15034h4mjt4m35-4-5.jpg
Jan 15, 2014 | Apple iPad Tablets & eReaders
I have a Toshiba Tecra M7 that won't boot and up until this morning nothing worked. This is what I've done so far this morning WHEN it does decide to boot. 1. Power up computer from off with ESC...
Your hard drive may have gone south. Remove it and check with diagnostic software. Bad sectors in critical areas of operating system data will do this.
Apr 01, 2017 | Toshiba Tecra M7 Tablet PC
You have to remove the screw covers (the black squares around the screen), remove the screws and gentley pry the cover open with yor finger nails or a flat head screw driver, but be careful not to dent the sides with the screw driver. You can then take a can of air and blow the dust out. I would not touch the sensetive screen under neath. You could take a anti static, micro fiber cloth to wipe off the tough stuff.
Jan 26, 2009 | Toshiba Tecra M7 Tablet PC
Cleaning inside lcd panel for toshiba r15 s829
Remove battery then remove trangular black tabs (2) at the top of the screen. Then remove square silver tabs (4) at the bottom of the flip top. This can be accomplished with either a push pin or sharp knife just get under one corner and peel off. They are just thin pieces of plastic with and adhesive backing. Remove the screws underneath ( 6 in all) with a small screwdriver. Run your fingernail around the entire outside edge of the flip top to pop off the plastic front with screen. Wipe off LCD and inside of the screen with a soft damp cloth; do not spray anything directly on to the LCD. Reverse the above steps and if you were careful you can just reattach the plastic tabs over the screws.
Clear view again!!!
Jan 23, 2009 | Toshiba Satellite R15-S822 Tablet PC
Toshiba Portege 500 Laptop
need a toshiba mother board for m40x250
Aug 04, 2008 | Toshiba Portege M400-S5032X Tablet PC
Blank screen on boot
hi firend
u havre to do this chk the ram remove & clean it reinstall it in your pc if problem occers then
u have heting problem ur prosser fan has been dust so remove your prosser fan clan it put it back agin
Apr 27, 2008 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Toshiba M400 tablet wont start
hello jpmca
try to take off your fan cable
here http://slashstar.com/blogs/alex/archive/2006/09/30/Toshiba-M400-Fan-Hack.aspx
and try to release the memory sodimm, release the battery and plugin the power cord again
if problem solve try to updated your bios for fan noise solution
here
http://support.toshiba-tro.de/kb0/TSB6A01KJ0000R01.htm
oke
cropp
Mar 15, 2008 | Toshiba Portege M400 PPM40U01000E Tablet...
Toshiba Satellite R15 Tablet PC Logo
333 people viewed this question
Top Toshiba Tablets & eReaders Experts
micky dee
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
