Question about GE Refrigerators
GE Profile Refrigerator - electical short
Hi!
We discovered that a rat partially gnawed on the electrical cord to our refrigerator. When we plugged it back it, there was a small spark, and now the refrigerator won't turn on. Thoughts? We did use electrical tape to do a repair on the cord until my husband can replace it tomorrow.
Thanks!
    President:
  • 2,559 Answers
Unplug it,take off the tape,where it was chewed,Seperate each piece into 3 indiviual wires(You should see grooves in the wire,just cut along those grooves about 3-4 inches in each direction)Clean up the wires that are damaged,remove .5 inches of insulation only from the damaged wires,Twist the center one back together and tape,then do the same for the remaining wire..After you plug it back in you may need to check the breakers in the panel.
Posted on Jan 20, 2009
My Hunter Douglas ceiling fan/light operates with a wall remote. It suddenly stopped working. When I tried out putting in a new battery the fan still does not work but the light turns on bright briefly,...
rats have gotten into your electrical wirings, probably gnawed the wires to fan totally and partially on the lights, might still find the dead rat on the wirings.
Mar 14, 2014 | Televison & Video
DF light on continuously
HI,
Please make sure that the cold knob is turned up.Next unplug all the cords of your refrigerator for 30min and allow it to reset.
Let me know the result.
Oct 11, 2008 | GE Profile PSW26P Stainless Steel Side by...
Hi our ge refrigerator has freezer on top its freezing but not keeping foods cold in fridge.fridge is warm and theres two holes in fridge on top that keep freezing up.what should we do?
by the number on the refrigerator its a side by side,if the freezer is actually on top,then remove rear cover inside the freezer and the drain hole in the freezers plugged with mold take a wire and rat out this hole to get water to flow down the hole again
Aug 07, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE Profile PSCS5RGXSS refrigerator is heating. The freezer section is still freezing. The unit is less than 2 years old.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 10, 2011 | General Electric Profile PSCS5RGXSS...
My Ge profile refrigerator is making a loud fan noise what is causing it?
Ice is built up and hitting the fan...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 27, 2010 | General Electric Profile PFSF5PJX Bottom...
Hi, our ge profile refrigerator is having temp
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Can I use a short appliance extension cord on a refrigerator?
as long as it is fused to 3 amps you can use a cable run as long as you like.....
Apr 12, 2010 | GE Profile PSW26P Stainless Steel Side by...
After plugging in the fridge the compresser does not come on. I looked at the electric panal and the fuse is still good. could it be my compresser? Ge profile. t
The compressor is controlled by the cold control. This is probably where your problem is. on a GE Profile, this is usually located on the back wall where you change the temperatures for the fridge or freezer. With the refrigerator unplugged, this control can be easily replaced, and you compressor should come back on! Hope this helps!
Dec 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Profile ice maker stopped making ice
ice maker for ge profile wont' make ice.Unplugged elect supply from both waterin the door coil and ice maker coil.Plugged water in the door elect to ice maker valve coil and pressed water in the door input sw out front and got water to ice maker so this let me know it wasn't the solonoid valve.Got another ice maker unit plugged in and mounted waited several days still no ice.
Sep 27, 2009 | GE Profile PSW26P Stainless Steel Side by...
The door handle on the freezer of my GE Profile Bottom Freezer Refrigerator came off.
Hi, Please get me the model # from the label inside the refrigerator and I will look this up for you. Most handles have a set screw that tightens down.
Vic
Jul 11, 2009 | General Electric Profile PFSS2MIXSS...
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
