Question about Stanley TR250 H Heavy Duty Heavy Duty Staple/Nail Gun w/ Free Staples
The staples won't go fully into the Wood
Staple sticks up, is only just making contact with the wood
    Top Expert:
  • Stanley Master
  • 45,139 Answers
1. The wood may be too hard for the staples to penetrate
2. The stapler drive spring may have ghotten weak
3. You may not be holding the stapler nose firmly against the wood while stapling
Posted on Jan 06, 2013
    Habit-Forming:
    New Friend:
  • 3 Answers
My T50 would fire ONE 1/4" staple correctly and then jam, eating 3 or 4 and after digging those out do it all again. This was one staple eating machine!!.. I disassembled the thing, making some mechanical adjustments which allow only enough room for smooth feeding of ONE staple at a time and now it NEVER misfires or jams. These adjustments will take careful thought and filing of the end of the staple tray nearest the firing pin, along with slight bending of the firing pin to lay flat again the outside head cover. I also filed the outside "tips" of the firing pin to be absolutely flat where it contacts the staple. DO NOT shorten the firing pin if possible. Now I can get even 9/16" staples to go all the way in. :)
Posted on Aug 17, 2016
Loringh
  • 185 Answers
SOURCE: Tr250 does not drive brad nails all the way down.
Jason,
I think this is typical of these staplers/nailers. I bought a lighter model Stanley the first time and had this problem. I took it back and exchanged it for the heaviest Stanley they had at Home Depot and had the same effect. It drove the stapler a little deeper but not all the way.
I did find that if I put all the down pressure on the stapler right on the edge where the staple comes out and then pull the trigger it would drive the staple almost all the way in. I think that there is a recoil effect (like with a gun) when you pull the trigger and the staple enters the wood. Try this. it will help.
Hope this helps Good Luck Loringh PS Please leave a rating if appropriate Thanks for using FixYa
Posted on Nov 16, 2008
  • 52 Answers
SOURCE: the staples don't go in far enough
Either the pioston backed off piston stem or the blade is broken. remove 4 bolts holding shoe to yellow body. remove magazine and shoe. remove yellow bumper inside gun. Pull piston down and inspect blade. if not broken see if piston backed off stem. if so gun must be rebuilt and part # BC347 must be replaced. visit www.bostitch.com and download schematic and where parts can be obtained.
Posted on Feb 14, 2009
jj505
  • 195 Answers
SOURCE: Can you help with loading
Look at rear handle bottom, Push in then pull out,load. Please rate. Thanks
Posted on Mar 23, 2009
  • 342 Answers
SOURCE: Need help loading staples in my Stanley electric staple/nail gun
there should be a button / lever at the rear press it and it should open so as to insert the staples
Posted on Apr 05, 2010
  • 37 Answers
SOURCE: staples wont penetrate wood and keep foldin up
are the nails proper for nailer? the gauge of the nail is important
Posted on Oct 02, 2010
Arrow CT50 stapler I am looking for a staple gun which I could use for upholstery, It would need to drive staples into extremely hard wood. Thanks
Sorry we do not have that information. I suggest you contact a local Auto Trim shop and ask them what they use.
May 17, 2017 | Arrow Tools & Hardware - Others
Upholstery stapler will not eject staples
sounds like they might be the wrong staple for the gun .
Jan 04, 2016 | Staples Tools & Hardware - Others
I bought a hammer staple from lidl wher do I get the staples from ?
Google search make, model and manual if you do not have the manual at hand. Staple size will be in the manual, and many times will be on or inside the staple slide. They should be available locally from any hardware store.
http://www.lidl-service.com/cps/rde/SID-8C181B36-F49FF6CE/lsp/hs.xsl/product.html?id=8000278&title=Kladivov
Mar 09, 2015 | Staples Tools & Hardware - Others
The side of the staper lists 3 different staple sizes, does it really take all 3? (1/4, 3/8, 1/2 inch)
Samantha, Yes. These sizes are the lengths of the legs. They are all the same size wire, bent into the same width of "U". Yes, it will take all 3, but you have to buy the right type. When you buy staples, look for compatibility with this brand & model stapler. By the way, if you a stapling something thin to something substantial (such as paper to wood), use short staples. Otherwise you will have difficulty getting the staple to penetrate the wood sufficiently for the staple to lay flat. Good luck, Al K
Dec 08, 2010 | Powerfast Stanley TR110 Light-Duty Staple...
I am using the 1 1/2 staples and going into oak, and can't get the depth wheel to seam to adjust. Leaves the staple sticking up about a 1/8 in.. I have sprayed everthing good with WD-40. Combination...
well oak is a barn hard wood, do you realy need a big staple cant you use a shorter one??? its that or buy a stronger staple gun or a big hammer!
Jan 12, 2010 | Air Tools & Compressors
How do you adjust the staple size to load 1/2" or 1/4" staples?
Staple guns can use a variety of staples; the width of the staple is fixed, the lengths vary from 1/4" up (usually in 1/8" increments). You don't need to adjust the staple gun for the different lengths, just be sure the width fits your gun since some manufacturers have used brand-specific staples.
There are also a variety of staple types; there are staples for ceiling tile, electric wire, window screening, etc. My favorite staples for wood have the tips cut on a sharp angle, they penetrate wood well. Some staple types require a particular gun, I have a gun that shoots only round-top staples for small cables like phone & thermostat wire.
Dec 05, 2009 | Stanley CT10C Heavy Duty Staple Gun/Cable...
The staples do not enter the wood completly
often when squeezing the tool the front gets lifted and the staple does not set fully. try making sure the front is tipped down fully and in contact wood when it fires. if that doesnt work the push rod is not working properly and is easier to replace than try to fix
Apr 22, 2009 | Arrow CHROME STAPLE GUN ARROW IND....
Powerfast staple gun works poorly
Gun is most likely a multi strike gun. Try not moving the body of the stapler and pushing the strike lever again, repeat if necessary.
Dec 20, 2008 | Watts Brass Pipefast Staple Gun Pipe To...
Jason,
Nov 06, 2008 | Stanley TR250 H Heavy Duty Heavy Duty...
Staple Gun Troubleshooting
Most of the staple gun models lack an "anvil" — the metal plate with curved slots that office staplers use to bend the legs of the staple inwards and flattens them against the paper. Staples set with a staple gun retain their straight legs, and are held in place only by static friction of the legs against the compressed surrounding material, much like common nails. Indeed, some staple gun models can handle brads and nails as well as staples. Some staple guns also use divergent point staples where the legs twist as the staple drives into the surface providing superior holding power.
Aug 27, 2008 | Arrow T59 Wire & cable staple gun
Stanley TR250 H Heavy Duty Heavy Duty Staple/Nail Gun w/ Free Staples Logo
4,010 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
