Question about German 1991-1992 BMW 850i Engine Cooling Fan Blade W0133-1614194
I have a power problem with my 1991 BMW 850i.
It started with hesitation then it would be fine, then came what seemed like half the power while driving normal but after applying more gas power was there again, then came weak smile of exhaust fumes and half power, then came strong exhaust fumes and still half power, now hardly any power and can no longer drive it, when I start it up there is strong exhaust fumes and it will not idle I have to constantly give gas to keep it running then at a certain point while giving more gas it will eventually die/cut-off. I've changed the fuel relays, the fuel pump and filter inside the tanks, the fuel filters outside (left rear wheel), checked and replaced one of the air intake meters, checked the in and out fuel hoses under the hood behind the engine coming from the fuel pump, I tried to get a diagnostic read-out at two shops but their machine were not able to get a connection/read-out, I've had the car at a shop it costed me money and they could not find/fix the problem. I dare not take it to BMW in Germany for as they see me coming they will be rubbing their hands together LOL (thats too costly if you know what I mean) plus I paid at the other shops for diagnostic attempts and the shop where I had it trying to find the problem (not cheap especially in Euros). I am lost and need help trying to find this problem. I can only think now it must be a clogged CAT. Anyone out there can help me? FOR YOUR INFORMATION To FIX YA - In your "Find your product" section I only chose ENGINE COOLING because I assume no one has had the problem I have. I HAVE A POWER PROBLEM OF ANOTHER TYPE
How to set the timing on a 1957 Peugeot 203
do you mean a 403 or have you got the year wrong ?, if a 403 follow this link and search for the timing there
Specs 1991 BMW 850i automatic
Jun 29, 2014 | 1954 Peugeot 203
Bmw 850i battery disconnected cant open trunk
Careful jump the car via the alternator or starter positive post.
Please be careful.
Do this with a jumper box with a motorcycle jumper cable.
Jan 11, 2014 | 1991 BMW 8 Series
Engine loses power and stalls
try adjusting the throttle position switch very hard to adjust right car will hesitate , not idle properly and hesitate when accellerating if not adjusted properly.
Jan 23, 2010 | 1991 Volvo 740
Bmw 316i had a service a week ago but car losing power when first started up.. Once it heats up the car seems fine. Any ideas
is it just idling roughly or hesitate when accelerating? You may have a clogged cold start injector in which you could have poor performance before the vehicle heats up to its operating temp but once it reaches its peak temp will run fine. Did your servicing include a tune up and/or fuel system cleaning if not I would recommend one.
Aug 05, 2009 | BMW 3 Series Cars & Trucks
Dies and wont restart. 1991 bmw 750il
You have a cam or crank sensor that has gone out.
May 01, 2009 | 1991 BMW 7 Series
BMW 850i trunk will not open
I found if you lock the glove compartment this will disable the boot from opening. Check the solenoid on the glove compartment is not switched shut. Hope this helps.
Oct 16, 2008 | 1991 BMW 8 Series
1991 850i keeps running hot
so does mine, always has constant problems with cooling of car
expansion blew one time car over heats onless driving on high way
any answers from others?
Aug 06, 2008 | BMW X8 Series Cars & Trucks
German 1991-1992 BMW 850i Engine Cooling Fan Blade W0133-1614194 Logo
65 people viewed this question
Top German Computers & Internet Experts
David Payne
David Payne
Are you a German Computer and Internet Expert? Answer questions, earn points and help others
