Question about Krups GMA1-42 Power Xtreme VI Work Top Blender
How to disassemble krups gma1 blender - Krups GMA1-42 Power Xtreme VI Work Top Blender
    New Friend:
Myron's tip about the need to unscrew the grey rubber coupling is correct, but I was unable to grab the post and hold it still, even though I was using narrow needle-nose pliers. I just could not get underneath the rubber coupling. I ended up cutting the rubber piece off the steel cord inside the coupling, which exposed the threaded post. I could hold the post stationary from above while I unscrewed the steel cord. My old coupling was stripped and worn out, so it did not matter. A new coupling can be ordered cheaply.
I found that it was not necessary to open the housing of the whole appliance as long as you can hold the post stationery. And even if you can't grab the post from above, opening the housing won't help because it won't come off until the coupling is removed at the top.
If you need to open the appliance for anything else, Myron is right, you need to remove the 4 rubber boots on the bottom to expose the screws. The screws are so-called temper-proof screws for which you need a special screwdriver. The screws are called "pin-in-head-star". But removing the 4 scows is not enough. You also need to unscrew the coupling at the top.
how to disassemble krups gma1 blender - 06621e63-afd7-45aa-a166-a736a7c0a3b0.jpg
Posted on Apr 29, 2017
2 Suggested Answers
SOURCE: Krups blender drive gear
Ed,
The problem I had was removing the grey rubber drive. The solution is that it screws off not pops off. The trick is to use narrow needle nose pliers to grab the post that attaches to the motor and turn the rubber drive counter clockwise. Removing the motor becomes easy. Pull out the 4 rubber feet under the base and the screws will be exposed. However my situation was the grey drive gear was stripped and would bottom out. My solution was to use a same size lock washer as the washer between the post and the drive. So far so good! If it fails I will need to buy another grey drive. Myron
Posted on Feb 01, 2009
I need Krups F5774 seal blender ring
Part number MS 0974091 Contact a Krups agent close to you. Use Google to find them.
Oct 29, 2015 | Krups Blenders
Brand new. Pulse feature stuck ON. Tried OFF. Tried unplugging. Still only pulses, no blending. Tried a dozen times.
So when plugged in it always just runs on the pulse? I would assume that this is an issue with the control board inside. If this is brand new return it to the store and exchange for a different blender.
You could also contact Krups to see how they work their warranties but you most likely need the control board replaced and that is something a service center would have to do for you.
Here is the information for contacting krups:
http://www.krupsusa.com/contact
Apr 29, 2015 | Krups KB790 Die Cast Blender
How do I change the serrated drive of my blender?
Hello, igriffing
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about blenders andpossibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances5.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Sep 02, 2011 | Krups GMA1-42 Power Xtreme VI Work Top...
How do i put a blender back together? its a hamilton beach wave action 12 speed
Hello, jim
Thanks, Mike
Aug 16, 2011 | Krups GMA1-42 Power Xtreme VI Work Top...
Teeth sheared off the rubber drive gear on Krups Blender Style 572. Have ordered part and need installation instructions
take a flat head screw drive to the bottom of the blender and us it to hold the blender shaft in place while you turn the gear by hand or with a plyers (it is reverse threaded) and it should spin right off. when you get the new on it should spin right on.
Aug 12, 2011 | Krups 572 Power Xtreme VI Work Top Blender
Hello, I ordered a replacement coupling gear(?) and need to figure out how to replace it. This is the little grey plastic gear that attaches to the base unit causing the blade to spin. Here are some...
Hope you have solved your problem by now, but put a flathead screw driver in the bottom of the blender to hold the blender shaft in place then turn the gear by hand or with a plyers and it should just screw off, it is reverse threaded...
Jul 14, 2011 | Krups GMA1-42 Power Xtreme VI Work Top...
Krups Type Blender 577
Mine did the same thing. I am ordering a new one from America for around $5.
http://www.abtecparts.com/index.htm
I am in Australia and they deliver worldwide.
Caz
Jun 12, 2008 | Krups 572 Power Xtreme VI Work Top Blender
Krups 243 blender clutch wheel
These little jewels are threaded onto the motor shaft so they tighten up when in operation. To remove, you will have to immobilize the motor shaft. See if you can insert an icepick or screwdriver into the blades of the motor fan on the bottom. Then using a punch and hammer, gently tap the clutch disk in the direction opposite from its normal rotation.
BE CAREFUL not to use so much force that you break either the clutch disk or the motor fan blade.
Mar 12, 2008 | Blenders
Krups GMA1-42 Power Xtreme VI Work Top Blender Logo
176 people viewed this question
Top Krups Blenders Experts
pdavis1000
Level 1 Expert
Kolbrun...
Ross Keen
Are you a Krups Blender Expert? Answer questions, earn points and help others
