Question about Porter Cable Tools & Hardware - Others
Remove belt pully on armature of 351 porter cable belt sander
How do I remove the drive pully on end of armature so I can remove armature and replace bearing.
I have a Porter Cable 2'' A-2 belt sander and need
you can buy that gear from ereplacementparts.com you will need the type number off the tool to make sure you order the right one, they cost around 25.28 and for a type 2 the number is D839309
Sep 10, 2011 | Porter Cable 363 4" X 24" Belt Sander
How do I adjust the porter cable sander so that the belt runs stright?
The porter cable belt sanders have an adjustment knob (threaded screw with a black plastic t-nut on the end). The knob adjusts the angle of one of the rollers and thus the tracking of the belt. The know takes very little adjustment to change the belt's tracking.
Is the know perhaps missing? You can get replacement parts for for porter cable tools at www.servicenet.com.
Hope this helps.
Apr 27, 2011 | Porter Cable Garden
Replace armature, I have it all apart except I can't see how to release armature from base.
The armature bearings fit very snugly in their holders. If you have the case split and the belt drive pully off, you just have to pry the armature out of the other bearing holder. If you are replacing the entire armature and the new one has a fan on it just pry it out. If the new armature doesn't have a fan on it be careful not to break the fan or any of the fins. It should pull out smoothly, if it doesn't come out with even pressure you still have something on the armature holding it in.
Mar 04, 2011 | Porter Cable Cable 363 4" x 24" 1500 SPFM...
Have a porter cable 352vs 3"x21" belt sander. was using it and blue sparks started occuring in the rotor and brush assembly. kept using as I needed to try and finish my project. No longer...
this tool has various type numbers but I checked on the type 5-6 and came up with the same number. the brush number I found is NO30461 and they run from around 3.50 to 4.00 each. If you have removed the brushes if the spring is burnt/collapsed it could have been from a loose brush cap or worse an armature problem. Before I sent it out for repair I would look at the brushes, UNPLUG tool first and remove them after removing look into the brush holder and see if the commutator (part of armature you can see) and see if it is discolored or other obvious imperfections. You can buy replacement brushes online from "ereplacementparts.com" or direct from "dewaltservicenet.com". Let me know if you need more assistance before voting and thank you.
Feb 24, 2011 | Porter Cable 352VS Factory Reconditioned...
My Model # 362 Belt sander keeps breaking belts after just a few minutes of continued use. Why?
This is usually indicative of someone pushing down on the sander too hard while sanding. The motor in this sander is strong enough to pull the belt around even with too much pressure on the sander. This causes excessive heat to build in the sanding belt and sander shoe which causes the belt to break down prematurly. It's also very hard on the sander's bearings and motor. Use an appropriate sandpaper grit that will do the job without excessive pressure on the worksurface. This will make your sanding belts and sander work longer and cooler.
Sep 13, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Broken belt on Porter Cable 334 T2 palm sander
got it, go to Dewaltservicenet.com and download the instruction manual or look at it and on page 14 it gives a really great view of how to replace the belt. If I have helped you with your question would you please rate this response accordingly and thank you
Oct 12, 2009 | Porter Cable Palm Grip R.O.S. With Kit Box...
Replacing sand paper
Look on the side of the tool between the guide and drive wheels for a lever
Loosening or disengaging this lever will take the tension off of the belt so that it can be removed
If there is no lever, there will be a tension know on the front of the tool that you can loosen to remove the belt
Jul 05, 2009 | Porter Cable Tools & Hardware - Others
How do you replace the drive belt on a Porter Cable Belt Sander
There is a lever on the side at the front right near the roller that you can use to release the spring tension on that roller (moving it slightly to the rear).  Once the tension is released you can slip the sanding belt onto both rollers from the side.  Release the lever and the spring will put tension on the belt to hold it in place.  Use the knob on the left side to center the belt on the roller if it starts to slip sideways when in use.
May 28, 2009 | Porter Cable 361 3" X 24" Sander
Belt sander clogged dust collection
What have you been sanding?  Make sure the sander is unplugged. Remove the dust collector bag and use a flexible wire, like a coat hanger, to free the clogged material from the dust tube.  Replace bag and sand away!  Hope this solution works for you.  Michael Mittelsdorf
Jan 10, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Tools & Hardware - Others Logo
53 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
