Question about Dacor Kitchen Ranges
ERG365BK\LP IGNITER ON ONE BURNER DOES NOT LIGHT OR CLICK, HAVE ALREADY REPLACED IGNITER ON THAT BURNER, THE PORCELAIN PART.
jsrock516
  • 5911 Answers
SOURCE: Stove burner igniter does not work.
Your problem is not the igniter itself, but the burner switch that controls the igniter. All the igniters get their power from one spark module that is mounted somewhere in back of the oven. That's why you are able to get all the igniters to spark with only one burner control turned on. This is normal. That is also why you are able to light the burner in question buy turning on another burner. The spark is being provided by a switch that is working. To answer your question: the igniter is removable, but I don't think it's necessary. Cleaning them generally doesn't make them work better. I would check the wiring from the spark module to the burner switch and/or replace the switch. I hope this helps.
Posted on Jul 18, 2007
IB4G2008
  • 3587 Answers
SOURCE: GE JGB920sec2ss: Igniters dont light up burners
two options on these..
1..the air to gas mix may be altered, from being clogged.
2. The gas lines are crudded up with grease/oil, etc.
How old is your range?
Posted on Feb 10, 2008
huuum
  • 750 Answers
SOURCE: top burners often wont light if oven is already lit
Hello and welcome,
If your range has electronic igniters, then you seem to have one or more bad igniters on top of the range if you have a pilot range then you have a gas restriction or clogged orifice tube.
Even if they make the click noise while trying to light they may not get hot enough to draw the gas on a constant speed!
This will need to be diagnosed hands on at your location.
But this is the fault!
Thank you for using fixya.
Huum
Please remember to leave a solved rating before you leave!
Posted on Dec 07, 2008
I have fix that problem before, the oven heat is soficating the top burners, you will have to adjust top burners with the oven on, so that they will light by them selfs.Or put a shield under the cook top section on the back, so that the heat will not come to the burners where they get the oxigen.
dontdiy
  • 8 Answers
SOURCE: Viking VGIC3064BS top burner work but oven won't ignite
Have it fixed under warrenty. If your asking for help here you don't have the skills to DIY.
Posted on Dec 26, 2008
Bluestar rangetop clicks several times before igniting
Do other appliances in your home using LP gas work properly? If so, then this is probably an air/fuel mix problem on the burner(s). If this is a new rangetop there should be directions with the range and the LP conversion kit to instruct on proper adjustments. Be certain the correct LP orifice was installed for each burner (they likely have different BTU ratings for different sized burners) and the ignitor post is clean and spaced properly to burner. Then adjust the air mix to achieve a blue flame with just a tip of yellow. Delayed ignition usually results from the wrong air/gas mixture which doesn't ignite until too much fuel has accumulated. In many locations the company you purchase LP gas from will have someone who can check and adjust this. If the range was shipped from the factory as LP gas ready, then you can also contact your dealer and request assistance.
Feb 25, 2014 | BlueStar RGTNB364GHCSSLP 36" Pro-Style Gas...
I have turbo CG4TDBRN and It stoped working. I used to push in the knob and hear clicking and the fire would start. now no clicking no fire. the Rotiserie went out a couple of years ago and I would like...
Some igniters need batteries. Try calling the company and asking them. They might also be able to sell you a replacement igniter. In the mean time you can always start the grill with a long lighter or by lighting a stick and putting it near the burners before turning on the gas.
Jun 05, 2011 | Barbeques Galore Turbo STS 4-Burner with...
Left burner won't light with ignition, it will light with match
If each burner has its own igniter, you may need a new igniter. If both burners light off of one igniter, check the electrode to make sure there is a spark when you hit the igniter button.
Jul 09, 2010 | Ducane 1005A (LP) Grill
I have a 36'' Wolf LP oven with 4 burners and a charbroiler in the center, When lighting the charbroiler, the electronic igniter continues clicking up to 5 minutes after the charbroiler lights
Hi.
The igniters are all controlled by a main hub switch located under the cooktop panel.
Replace the sparking igniters module to fix the sticky igniters problem.
Regards.
Ginko.
Mar 03, 2010 | Stoves Ovens
Rear burner wont light. Dont hear the click of the lighter. All other burners are fine
CHECK THAT THE IGNITION WIRE IS NOT BROKEN OR EXPOSED AND ALSO MAKE SURE THE TIP OF IGNITION WIRE IS CLEAN .
Nov 22, 2009 | Barbeques Galore Turbo Elite 4-Burner with...
First two burners, now all burners...
You have a defective spark module. This is a device which breaks down the 120 incoming volts to a 12 volt spark to ignite the burners. Replace module and problem should be solved.
Sep 01, 2009 | Jenn-Air JJW8530C Expressions Collection...
Problem with gas getting to the front burner
Follow manufacturer's recommendation in resetting the excess flow safety device....(Turn burners and LP cylinder off...Disconnect regulator on cylinder. Turn both knobs to high for at least one minute...Then turn them to off...reconnect the regulator to the LP tank...Turn LP valve VERY slowly (30 seconds) until fully opened..then start the grill in the usual manner. ALWAYS TURN THE LP TANK OFF WHEN DONE USING THE GRILL....
Jul 04, 2009 | Weber Genesis Silver B Grill
I replace my thermal coupling. burner doesn't ignite
is the burner assembly sitting pronperly on it;s cradle,, this will put it at just the right distance for it to ignite,,
Jun 15, 2009 | RTO Atwood Water Heater - 6 Gal LP
Pilot flame starved out after burners ignite
The declining pilot light might be an indication it is being starved of oxygen by the main burners or some other sort of circumstance.
I have noticed how in a closed room without ventilation the pilot light soon begins to decline and then springs back again when a window or door is opened while the main burners are hardly affected.
This is the gas equivalent of sending canaries down coal mines and is an essential safety feature. If the pilot light declines very much the thermocouple bulb will not be heated and the gas supply to the main burners will be cut off. This is why the pilot light is set at an angle and the thermocouple bulb is slightly offset.
I am not sure if this helps but I hope it does.
Mar 08, 2017 | Ovens
Top burners often wont light if oven is already lit
Dec 07, 2008 | GE JGBP28 Gas Kitchen Range
Kitchen Ranges Logo
14 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
240cpa
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
