Question about Microsoft Windows XP Home Edition
Cant boot iso cd on hp pavilion 525c how can i fix ?
I am currently runing ubuntus 12.04 lts an i want to go back to windows but wen i put boot it say select a driver and pres eny key and i do then it say select a driver n press eny key
  • Microsoft Master
  • 27,725 Answers
It could be a problem with the cd / dvd either not reconized or not recognizing the cd / dvd
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
Hope this helps.
Posted on Jan 06, 2013
5 Suggested Answers
robocop
  • 90 Answers
SOURCE: Windows XP Boot CD Network Boot Drivers
I would try to boot in safe mode, then download the appropriate card driver.
Posted on Jan 23, 2009
  • 273 Answers
SOURCE: trying to boot from windows CD and not working
If its the full windows xp cd by booting it from the cd drive it will erase everything and ask if you want to upgrade or advanced install I think. Your correct in choosing the atapi cd-rom as 1st boot device. The cd should be in the drive on startup. IDE is the type of hard disk drive. I'm guessing the FDD stands for floppy disk drive which you might not have that many but you have that many bay windows available.
Put disk in, shut down computer, Start computer and it should give you the xp disk contents. Be aware of data loss though.
Posted on Nov 14, 2009
Awawada
  • 201 Answers
SOURCE: computer booting time ntdlr missing displayed how
Make sure there is no removable disk in any drive that may be causing the error.
If thats not it then place the CD in the CD drive and boot to the recovery console
use the recovery console to copy NTLDR from another machine
See http://www.computerhope.com/issues/ch000465.htm
Posted on Jun 13, 2010
sree710
  • 30 Answers
SOURCE: i have a hp pavilion
You can dump the windows98 setup to your usb flash drive using wintoflash software and boot your system using usb flash drive. Proceed with the installation steps for win98.
Regards,
Sreejith
Posted on Aug 12, 2011
I have an hp dv9925nr laptop running vista home premium 64. I tried to reset to factory settings and now when I try to start up I get a boot manager error. It says \boot\bcd status 0xc000000f error...
Most of the boot up of problem because of hardware problem, registry missing or crashed, file deleted or changed.
You can boot up your Windows with Tenorshare Data Recovery WinPE.It allows users to burn ISO file to CD/DVD/USB flash drive directly.
Step 1: Download Tenorshare Data Recovery WinPE in any available computer (not from PC that can't boot up). Then launch it.
Step 2: Insert CD/DVD/USB flash drive to the computer, choose ISO image file. Here we take USB flash drive for example. Then burn ISO file into flash drive.
Step 3: Insert the burned flash drive to the unbootable PC. Run computer and press "F2", "F10" or "Delete" to enter BIOS setup.
Step 4: Use the arrow keys to select Boot tab, select Boot Device Priority and press Enter. Please choose 1st Boot Device to USB, and then press F10 to save setting. Now,you can boot up your PC.
If you have a backup for your Windows then perform a system restore to fix it.If not,reinstall it.If you have no backups for all your data,you can use Tenorshare to retrieve data under any boot up problem.You can get it from http://www.any-data-recovery.com/product/datarecoverywinpe.htm
Here is tutorial to guide you how to do --How to Recover Data from Computer Won't Boot Up?-Windows Data Recovery.
Sep 19, 2011 | HP Pavilion dv9925nr Notebook
I am using HP pavilion with Windows xp OS installed on. When i turn the power on, a black screen saying "sorry for the inconvenience, but windows did not started succesfully, -safe mode, safe mode...
You need to find your "Operating System CD" sometimes they give you this sort of stuff with your computer but if not, find one from somewhere. Put the CD in when the computer starts and you will see a message saying "Press any key to boot CD" or something similar, boot the CD and press install Windows XP - when you have pressed F8 to agree to Terms and Conditions, it will give you an option to overwrite your current system or Repair. Click repair and it will start installing stuff. DONT WORRY - its not deleting your information its just fixing your computer. When the installation has finished, you will be sorted! - Make sure its a Microsoft windows XP CD though, otherwise you cannot repair your system.
Hope this helps.
Jake
Jun 30, 2010 | HP Pavilion dv2000t Notebook
Can I add a hard drive to my old hp pavilion 525c which is still running XP and running well?
Best way to do it if you aren't familiar with the internals of a PC is to use an external drive. If you have a drive aleready you can get an external drive case and put your own hard drive into it in about 5 minutes.
Jun 13, 2009 | HP Pavilion 525c (DD210AR#ABA) PC Desktop
Plss i need an urgent information i dont want to format my system cos everyone has been telln me to do that cos i forgorgot my administrator password on my hp dv 6000 pavilion series laptop pls wot do i do...
Google the OPHCrack Live Cd on another computer. download the cd image and then burn this cd. boot it on your laptop... this can take a while.... after it fully boots(which can take up to 30 minutes) it will display all windows passwords in the program window in the top let corner of the screen.... If your first boot off of the cd fails then choose a different video mode in the startup menu....
Feb 02, 2009 | HP Pavilion dv6000z Notebook
Pavilion 525C won't start
HP Pavilion 525c/525c-b
Model Comments - 266MHz FSB, NVIDIA nForce2 IGP Chipset
After installing a new harddrive
The system may not boot and may need to be reconfigured.
You may have setup your new harddrive incorrectly.
Your system BIOS may require you to check it's settings due to the addition of new hardware.
It's recommended that you check your system bios configuration for errors after installing new hardware.
Az.
Sep 23, 2008 | HP Pavilion 525c (DD210AR#ABA) PC Desktop
New operating system wanted
after formating hdd u can install any op sys on ur computer, please put ur op sys cd in drive
after starting computer and boot it with this cd when u start ur computer u will get a massage "press any key to boot from cd"
and install xp from cd also format ur hdd with xp op sys
it will solve ur problum
Jun 02, 2008 | HP Pavilion a1240n (EG136AA) PC Desktop
Microsoft Windows XP Home Edition Logo
48 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
