Question about Refrigerators
I have a Hotpoint Fridge/Freezer RFB50 and I keep getting high temperature light on
  • 38 Answers
SOURCE: hotpoint 8496p
this fault is very common for this model but not something that you can do if you r not an engineer the part you will require is an evaperator thermistor to any engineer that is unfamiliar with this it is the green one good luck
Posted on Jul 21, 2007
  • 139 Answers
SOURCE: my fridge freezer Hotpoint Mistral
E8- Evaporator thermistor short circuit
Well this is a sensor,, found in the freezer compartment of the f/f
what you have to do is reove the draws fro mthe freezer and you will c a panel which has 6 screws., remove the panel and and you will c a fan, toward the right of the fan you will c a yellow plug with a bit of wire on it,
This is what you have to replace
try connect distributions you can find them on the net if your in the uk that is
hope this helps
cheers
washdoctor
Posted on Aug 25, 2008
SOURCE: fridge tempertature
I have the same symptom too - freezer temperature flashes at -2. "Power Freezer" or setting it to any other temperature is not working either.
As a result, no ice being made. Please help!
Posted on Sep 01, 2008
SOURCE: Hotpoint Mistral Frost Free Fridge freezer - fridge not getting cold
We have just had to call out an engineer to get our 1 1/2 year old Hotpoint Graphite Frost Free Fridge Freezer repaired. The fridge had almost entitely stopped cooling even when on high. I was amazed at how easily the problem was sorted. The engineer removed all the basktes from the freezer to access the screws on the inside backpanel of the freezer. Once this panel was removed it was clear that the so called Frost Free doesn't really mean what it says. The ice need to be melted with a bit of simple care. It is obvious that with a bit of care it is easliy a diy job BUT PLEASE BE CAREFUL AND READ THE NEXT PART BEFORE YOU BEGIN TO REMOVE THE ICE> The ice forms around variouys pipes etc and he usecd a screwdriver to help release the ice quicker than waiting for it to defrost and he also used a simple hairdryer to help speed up the process. He had a ntowel and a basin to take care of the water. Next time I would have no problem doing this myself but I would need to leave it a little while to defrost and NOT USE A SCREWDRIVER as I am sure somehow I would puncture a pipe or the wall of the freezer itself and I am quite used to doing the odd bit of DIY. On a difficulkty scale of 1 to 10 with 10 being difficult I would rate the job as about a 3. Hope this helps anyone who reads this about £70.
Posted on Dec 27, 2008
SOURCE: hotpoint fridge freezer green and red light on, switch offering 0
green and red light on.Have you got a solution
Posted on Feb 20, 2009
I keep getting water at the bottom of the fridge, under salad boxes on my Hotpoint fridge
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Jul 03, 2012 | Hotpoint-Ariston HS3022VL Refrigerator
Freezer high temp light is on. So is fast freeze. It's been plugged in at least 24 hours but not freezing.
FREEZER HIGH TEMPERATURE WARNING LIGHT DOESN'T GO OUT.HOW TO CANCEL OR RESET?FOR HOTPOINT FFA74.THANK YOU
Mar 11, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint RFA70 fridge freezer - refrigerator drain blocked. Have tried boiling water; bleach; p;unging and poking. Defrosted a month ago fixed problem but is back again.
I just cleared a blockage in ours using about 6 drinking straws all attached together ( squeeze end and push about 30mm inside the next one) a small funnel insulation taped to the end and pushed right down the hole until it stops. Then pour hot water into the funnel until it clears. Remember to keep the funnel as high as possible and the hot water being poured in will push any cold water back up the tube, melt the ice and clear the blockage.
/uploads/images/5_31_2014_3_08_17_pm.jpg
Nov 11, 2010 | Hotpoint Refrigerators
Hotpoint rfs60 high temperature light staying on but freezer still works although maybe not to full potential
Had the same problem with the same model fridge, had to get the engineer out from hotpoint said it was the gases and their was a blockage in it. could not be fixed.
Jun 19, 2009 | Hotpoint RFS60 Bottom Freezer Refrigerator
Freezer switching off on Hotpoint Iced Diamond Fridge Freezer
home refrigerators are not dsigned to work in areas where the temps will drop below about 45 f to my knowledge there is no way to help wiht this problem. Thx peyton
Jan 29, 2009 | Refrigerators
Red light on Hotpoint Iced Diamond freezer
got a hot point iced diamond fridge/freezer, just got back off hols and red light on, all food defrosted with water running out of bottom. whats wrong?
Aug 27, 2008 | Refrigerators
Have a hotpoint rsf60 fridge/freezer,noticed over temp red light on, defrosted as ice buid up on top shelf of freezer.light still on red temp set at 3/4 ?
The red warning light will not go out?
1. Has the fridge freezer just been
installed? If so, this is normal and the
light will go out when the correct
temperature has been reached.
2. Has the fridge freezer been loaded
with a large quantity of food? If so,
the light will go out when the correct
3. Have the doors been closed
properly?
Jul 01, 2008 | Hotpoint Refrigerators
Ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
May 18, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
HOTPOINT FRIDGEFREEZER
Sounds like frosting up. Defrost completely...that can take 2 days. Restart. Also, clean the condenser. Check door gaskets, clean and replace as necessary. Don't keep door open longer than necessary.
Dec 20, 2007 | Refrigerators
Refrigerators Logo
94 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
