Question about Olympus Pearlcorder T1000 Desktop Cassette Transcriber / Recorder
My pearlcorder is eating the tapes. Any solutions?
PEARLCORDER S922, HOW DO ERASE THE TAPE
Re-record over the tape with no microphone input for silent recording.
Nov 04, 2010 | Olympus Pearlcorder S831 Handheld Cassette...
I need the instructions manual for olympus pearlcorder j300 microcassette
put in 2 AAA batts and insert a tape, then push record to record, and expirament!
VCVA
set it to VCVA on the left side and push record, will only record when detects noise
Oct 24, 2009 | Olympus Pearlcorder J300 Handheld Cassette...
How to turn on Olympus Pearlcorder ''voice activation'' feature?
On my model the Olympus Pearlcorder S909 there is a slide button on the end marked VCVA (variable control voice actuator). Switch it to that position then press record and away you go, voice activated recording!
Hope this helps.
Aug 27, 2009 | Audio Players & Recorders
My Olympus Pearlcorder J300 plays the tape back too fast
Hello check the switch for VOX needs to be in the middle position make sure is not on F.Play
If the speed doesn’t change is your main motor
Apr 03, 2009 | Olympus Pearlcorder J300 Handheld Cassette...
How do I erase tapes?
http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=1229
Jan 15, 2009 | Olympus Pearlcorder T1000 Desktop Cassette...
Will not erase a tape
The erase switch has probably failed and needs to be replaced.
Sep 03, 2008 | Olympus Pearlcorder T1000 Desktop Cassette...
Vcr eating tapes
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
Let me know if you need more information as to where to purchase these parts.
- Jim
Feb 12, 2008 | Philips Magnavox 20MC4304 20 in....
Tape eating
unit need to be cleaned or have parts replaced if they got bad enough.
only, only, only use the more expensive JVC tapes. They keep their tension far better than cheaper brands. Also, they won't rub off their oxide coatings on the heads as easily, avoiding the 'clogging' of the heads (which thereby requires constant cleaning-further damaging the heads).
Feb 04, 2008 | JVC COMPACT VHS-C CAMCORDER
My T1000 will not erase tapes.
Press the erase and rewind button at the same time.
Nov 16, 2007 | Olympus Pearlcorder T1000 Desktop Cassette...
Olympus Pearlcorder T1000 Desktop Cassette Transcriber / Recorder Logo
Top Olympus Audio Players & Recorders Experts
Mitch Davis
Mitch Davis
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
