Question about Thermador PRG304US Gas Kitchen Range
Thermador prg304 burner problem
Burner shuts off
  • squint1902
    squint1902 Jan 10, 2013
    Sorry here, is a little more detail... after about 5-10 minutes with all the burners on the left rear burner shuts off and doesn't turn on again. When the oven is on the burner doesn't go on either. Thank you for your input.
Why my thermador cooktop shuts itself off ?
Has it been smelling of gas recently? That usually indicates your lp gas cylinder is almost empty.
Ray
Apr 24, 2014 | Thermador Cooktops
When Thermador oven is on and the simmer burner on low-low and the igniter sparks, the oven shuts off and the clock blinks (as if there were a power outage).
Check your earthing, all the way back to the earth stake too for safetys' sake!
Otherwise, try lighting the burner with a gas match instead of the peizeo ignition module >> check ignition module
Oct 16, 2013 | Thermador Ovens
Burner shuts itself off after 10 0r s minutes of working normally
this unit has a gas coil controling the valve . and wen it gets hot it is failing and cannot keep the gas on . replace the valve coil // mm
Jul 12, 2010 | Thermador PC366BS Stainless Steel Gas...
The burner wont shut off it keeps clicking
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 07, 2010 | Thermador 37 in. SGSX365 Gas Cooktop
I have a 7 year old Thermador prg304 gas oven. Sometimes, during long usage, the oven shuts itself down and when we try and turn it up we smell gas. I think it's the igniter? The service people tell me...
Hi, I have the same stove purchased in 2003. Same problem. I really like to get this oven working again so if you find any solution please let me know. I will post it if I find any solution also.
Thanks!
Dec 02, 2009 | Thermador PRG304US Gas Kitchen Range
Have a thermador pc366 six burner range, the 2
Did you get an answer on this? Have the same problem and the house call starts at about $100
Sep 21, 2009 | Thermador PC366BS Stainless Steel Gas...
Thermador rdss30rs xlo burners don't light and right side burners don't light either. can light right side with lighter. while burners are on igniter spark continously.
IF THE BURNERS DO NOT IGNITE
• Are the burner caps properly aligned and seated in the burner bases?
• Are the burner ports clogged?
• Is a fuse blown or is the circuit breaker tripped?
• Is the manual shut-off valve closed, preventing the flow of gas?
Jun 29, 2009 | Thermador RDDS30 Dual Fuel (Electric and...
Oven shuts off
Sounds like the spark module has been shorted out and quite possibly the main control board. Apptech.
Oct 19, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Thermador PRG304US Gas Kitchen Range Logo
85 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
