Question about Sony KDF-E55A20 55 in. LCD Television
Sony lcd kdf-50we655. alot of blue spots. now..
Lamp light is on and i get no picture. What steps do i take to fix it? new lamp?
  • hardgt Feb 20, 2009
    I have the same problem with my e55a20, however I've been told that it's the light engine, are you sure it's the bulb?
    Novelist:
    Scholar:
  • 67 Answers
Yep. New lamp. I believe that it is an XL2100U for the kdf-50we655. Should run about $200.00.
If you have your original owner's manual, it will walk you through changing the lamp. If you do not have it, then it should be available to find the manual on the support section of SONY.com or on Sonystyle.com.
I hope this helps you...
Posted on Jan 20, 2009
I have a Sony KDF-50WE655. There is what looks like a big yellow oval in the center surrounded by blue over the picture. I've read that this is due to the optic block. Is there any other possible fixes for...
That is the sound of a damaged blue LCD unit. Probable cause = overheated due to blocked air ways or an old lamp producing more heat than light.
A very expensive repair. Sorry.
Jan 02, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
We Have a Sony KDF-50WE655, we've replaced the lamp and housing and we still have no picture or sound. Can you help?
Make sure that lamp cover is fixed back on its position securely after lamp replacement, turn On tv to check.
If still no picture or sound then check power/standby light is blinking?
If yes, count it how many times it blinks after 3 seconds long pause and let me know to diagnose possible cause of problem.
Thanks.
Aug 01, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Blue blothes on LCD screen
Blue blotches spreading over the screen are failure of the optical block
contact Sony to see if you are eligable for a free repair.
Sony will cover the cost of the optical block repair (parts and labor) at no charge through December 31, 2008 for 2004 Model Year Grand WEGA™ Televisions with the blue spot problem.
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
http://esupport.sony.com/US/perl/news-item.pl?news_id=
Read more: Help from Sony for LCD rear projection with blue spots - Home Theater Forum - Home Theater Systems - HomeTheaterShack.com http://www.hometheatershack.com/forums/sony/5351-help-sony-lcd-rear-projection-blue-spots.html#ixzz0gm8a3718
Don't bedeterred by the dating of this announcement, it is a manufacturing fault and they have been pr5etty good to a lot of people with the same problem.
Please rate my help++++Thanks for using FIXYA
Feb 27, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
I have a Sony grand wega KDF-50we655. The picture was dim/dark etc. as suggested I replaced the lamp. Not much change. I did notice when the screen was White the left side had green in it and the otherside...
These tvs are LCD they have no tube to fill or color wheel.
You need to clean the glass light filters and lens.
If you remove the back and unplug the 9 plugs that go to the fans and LCD board/light housing it has 4 screws that hold it in to the front of the tv. 30 min Job.
Dec 12, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
My LCD projection HD TV model KDF-50WE655 has an
Is your TV LCD or DLP? Encompass Parts shows your model to have Lamp with part number for lamp as A-1606-034-B which then means DLP ,which then it means you may have your light engine going bad which is called optics unit Block part number is
A-1084-660-A They do have them in stock Call 1-800-638-3328 or visit their website www.Encompass Parts.
Nov 30, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
My Sony Grand Wega LCD TV currently has a large blue spot on the left side of the screen when powered on. I have changed the lamp, but this did not solve the problem. Could this be caused by bad component...
I'm afraid, it is problem of optics unit block (light engine), there are 3 LCDs red-green-blue for color picture formation and blue LCD sounds bad, please call local TV tech for fix.
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Problem with Sony Wega 50 in kdf-50we655 light blinks 55 times
Symptom shows that TV needs Lamp replacement.
Sony TV Lamp is available in Part Store and lamp replacement procedure is written in user manual of TV.
Mar 27, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
SONY WEGA KDF-50WE655
Did you replace your lamp with a generic lamp? Many generic lamps do not produce as much light as OEM lamps do. Also, you may have a separate issue causing the picture to appear less clear than before. Check my solutions to other Sony LCD owners who have had problems with their optical blocks( light engines)
michtech
Feb 16, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Kdf-50we655 dim picture and turns off and then back on
Symptoms shows that Tv requires new Lamp.
Lamp replacement procedure is written in user manual. Let me know if you need further info about Lamp purchase or need user manual.
Please buy original Sony lamp for replacement.
Jan 16, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Bad picture
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Sony LCD Rear Projection TV - Optical Block Problems
http://splinke.googlepages.com/sonyrearprojectionlcdtv-opticalblock
Jan 19, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony KDF-E55A20 55 in. LCD Television Logo
108 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
