Question about Canon Pixma MG5220 InkJet Printer
Cannon pixma mg5220 won't power on
Printer was working fine, had just used it to copy some pictures, turned the power button off, next day printer wouldn't power on when power button was pushed.
SkinWill
  • 148 Answers
SOURCE: canon pixma 530
unplug it from power and plug it back in.
if that doesnt work try unplugging it and GENTLY try moving the ink carrage to make sure it isnt in some odd position that the porinter cannot detect.
IF the carrage is properly seated on the one side of the printer it is normal for it to be locked and seated on pads that keep the ink from drying out.
Posted on May 02, 2008
Grubhead
  • 5151 Answers
SOURCE: I have a PIXMA MP460
Try re-installing it again. You may have not installed the application software for scanning if you did a Custom Install.
Posted on Feb 02, 2009
  • 74 Answers
SOURCE: cannon pixma mp145 printer error code e7 & e2
E2: Reload the paper correctly and press [Black] or [Color].
E7: The cartridges are not installed in place.
These are from the manual.
Posted on May 10, 2010
Micoman
  • 198 Answers
SOURCE: Every time I try to print my canon pixma MG5220
You need replace the ink absorber .
Or you can disassembly the printer and clean with running water tha ink abserber.
Is located below the cartrigde
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Posted on Sep 27, 2011
SOURCE: Canon PIXMA MP495 InkJet Printer - Offline issues
For Vista wireless setup: Open your Control Panel. Choose Printers. In the Printers box it lists your printers. Hover over the wireless printer icon, right click, choose Run as Administrator, then choose Use Printer online. This should change the status of the printer to Ready (from Offline). Be sure you've chosen this printer as your default printer. Might have to do this on a regular basis.
Posted on Dec 11, 2011
Cannon pixma mg5220 printer, b200 error msg. how do you remove the printhead ?
Error B200: A service error has occurred.
  1. Turn off the printer.
  2. Disconnect the power cable.
  3. Open the printer cover.
  4. Check for any orange protective tape or white polystyrene and remove if necessary.
  5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary.
  6. Close the cover.
  7. Reconnect and turn on.
If the above solution has not resolved your error, the device needs to be send to service for repair.
It can be that only the print head has malfunctions, but mostly it is another defect in the printer which causes also a defective print head. Changing the print head can solve the issue for a couple of weeks, but then the error will occur again.
May 06, 2014 | Canon PIXMA MG5220 Wireless Photo...
Printer head for my cannon MG5220 wihich was purchased through amazon in December is not working
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Aug 21, 2012 | Canon PIXMA MG5220 Wireless Photo...
How to use the back paper tray for Canon Pixma MG5220 Printer
To use the Rear Tray for your current print job (this should last until you close Word) :
Use Ctrl+P to open the printer window. Click on the Properties button. On the Quick Setup tab find the Paper Source drop-down and select Rear Tray. Click the OK button.
To permanently set the Rear Tray as the default:
Click the Windows Start button, then click Control Panel and select Printer. In the popup window right click on your printer icon and select Properties. On the General tab, click the Printing Preferences button. On the Quick Setup tab find the Paper Source drop-down and select Rear Tray. Click the Apply button, then the OK button.
Apr 01, 2012 | Canon Pixma MG5220 InkJet Printer
Reset to factory settings MG5220
turn off the printer.
Press and hold the resume button and click and hold the power button.
While continuing to hold the power button, release the resume button.
Still holding the power button, click the resume button 2 more times.
Release both buttons.
Click the resume button 4 more times.
Turn the power off then on.
Sep 27, 2011 | Canon Pixma MG5220 InkJet Printer
My area recently had a power failure. Oddly, during the power failure I could still see a light coming from the Canon MG5220 printer. After power was restored, it was sometime later when I noticed that...
Unfortunately, it sounds like when the power was restored, the printer experienced a surge. If this was not plugged into a surge protector, then it's possible the switch was fried at the point of power restoration. It is important that with units such as printers, monitors, towers (computer), tv's, vcr/dvd players, almost any type of electrical appliance be plugged into a surge protector. However, even if this was true in this case - when a power shortage (outage) is experienced, it is necessary to unplug everything so that when the power is restored, nothing that is plugged in will be affected; as your printer was.
Now, you can have this fixed - either take it to a local computer repair shop; that might be able to fix it, or contact the manufacturer and inquire about sending the unit in for repair - regardless of warranty or not. If it is still under warranty, they may honor it. I am not positive they will for an accidental damage such as this, but it's worth calling them.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert, Phone Support, Live Chat @ Fixya.com
Jun 25, 2011 | Canon Pixma MG5220 InkJet Printer
I have a Cannon Pixma MP150 printer. I am
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again .
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 15, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon Pixma MG5220 InkJet Printer Logo
1,386 people viewed this question
old marine
old marine
