My tv is a dynex and everything is hooked up to the cable box but my tv doesn't make any sounds. I turned all the volumes up.
I have a Dynex hooked up to a cable box too. We were unable to get sound on certain, but not all stations. The repairman explained that someone had pushed the "language" button on the remote. When this happens, the TV will go searching for spanish language for that station. If it finds none, it will cut off the sound. Try pushing the "language" button. I hope this helps.
Posted on Jan 06, 2013
    Filmmaker:
    Uploaded 5 video answers.
  • 88 Answers
Check in the tv\'s menu, there should be an option for audio. In that section there should also be an option that says internal speakers or somthing like that. Make sure its turned on.
Dynex rc01a-13 volume not working with dvd and cable box, dvd plays but no volume
Try it with an other interconnection cable. If there is an internal break in the connected cable [in terms of audio], this kind of fault can occur. As far as video is there, sound should also be. If not, check the speaker, and audio output section circuit to your TV. To get more details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 01, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
We just got a new cable box and now the Picture works but no sound. The volume is not muted on the tv or cable box. We've tried connecting the cable box three different ways and still get the same...
Does say a dvd player give sound when connected to the same input? If you have determined that the source is good and the speakers are turned on in the menu then I would replace the main board.
Sep 08, 2011 | Sony KDE-50XS955 50 in. Plasma HDTV
I have a 32" LCD
Tries tv and cable box unplug,replug it back like about an hour later.For the tv to do a resetting itself back to the factory setting.The cable box to reboot and upgraded it software.Than go in to the tv Menu go to Audio Setting go down and do a resetting back to the tv factory setting.By doing these steps u have a great chances to get ur tv audio sound back.Not have the same problems after this than the tv Tuner signal board it is shorted in the audio ICS modjulation sections.Tries websites like Shopjimmy,com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Aug 16, 2011 | Televison & Video
I'm connecting my tv to a stereo receiver to get stero sound through the stereo speakers.done this a hundred times with other tv's but can't get this one to work.
how do i hook up my stero to my dynex tv? stero has no hdmi cabl neither does my cd player. i also go through my cable box not high def Thank u for any help
Jan 02, 2011 | Dynex DX-L32-10A 32" LCD HDTV
Dynex tv works. bought ps3. when hooked up to
I would suggest you check if your PS3 is set up on going through the HDMI Cable.On your PS3's XMB scroll to settings -> Display Settings -> ANd from there go down to the one that says "Y Pb/Cb Pr/Cr Super-White (HDMI)" and hit X and select the option Yes... That sets the PS3 displaying through the HDMI
If you are already have done that I'm pretty sure you know you have to change the Input on your TV to HDMI... Take your remote and hit Input -> Scroll down to HDMI on the Input Source menu and hit Enter when you get to HDMI
If the AV on your PS3 works and not your HDMI sounds like Display Settings issue...
If you have done all that, that is strange if it still doesn't work.
There are some people that are having problems with the AV Cable with the PS3, I tried this and it really does work. I switched from HDMI on one tv to a AV Cable on another and when I did that neither TV would display content from my tv. The fix for this is resetting your PS3, like on a iDevice you hold the home button and lock button, for the PS3 you hold the Power off button and the Eject button for around 10 seconds. This resets your PS3 into default video settings. Until it Turns on, Beeps, and Turns off. This should work.
Jan 01, 2010 | Televison & Video
We have the stereo hooked up to the dynex 42'' tv, as we did our other tv, we can not mute the complete sound and also sometimes we cant turn the volume up and down whats going on?
Since you have it hooked up to the stereo system, you need to go to on screen audio set up and turn off the TV built-in speakers (you will be listening the TV sound through your stereo system speakers), then go to the audio output set up and set it to 'variable' so the audio output of the TV's RCA audio out put will vary with the volume control of the TV (not all TV will alow this function), you will need to set the stereo volume to certain level (around 9~10 O'clock setting) since the sound coming from the TV will be controlled by the TV remote volume control. You can otherwise set the TV output to be at 'fixed' level, which means the sound output of the TV will not be controlled by the TV remote volume control, you will use the stereo remote volume control to adjust the sound level instead. I hope this is clear to you.
Nov 19, 2009 | Dynex DX-L42-10A 42 in. LCD TV
I have a Vizio 42' and a cable box and there's a constant humming
I think I had the same problem. This is how I fixed it.
I have my vizio 42 hooked up to a Harmon Kardon surround sound, and the digital cable box. Essentially, I can adjust the volume 3 ways - through the tv, cable box or av receiver. The humming sound happens when you have the volume maxed out on the av receiver and not the cable box.
For example, the sound level on my Harmon Kardon goes from -10 (lowest) to 10 (loudest), with 0 being the middle ground. The buzzing was happening when the Harmon Kardon was set to 10, and I was using the cable box volume to adjust the sound. To fix it, I turned down the volume on my receiver to 0, which may be about 50% max volume of the receiver. Then, I switched devices and used the volume on my cable box. This got rid of the static I was getting. Hope that helps.
Jan 09, 2009 | Vizio VX32L Television
Hooking up sony dav-hdx 475 with digital cable box and hdtv
Plug the digital cable box audio strait into the dvd player. Plug video from the digital box into your tv.
Thats what i did and it works perfectly.
Jan 04, 2009 | Sony DAV-HDX500 System
My high definiton is working great and everything is fine except one major thing, which is that there is no sound at all. I would like to know how i might fix this problem.
Good Day, timerwer;
HD is fine but no audio! Not knowing that if you ever had sound, have surround system, hooked to an input or RF, I would suspect that you only have the Green, Blue, and Red cables hooked to your TV and the Audio cables ( red - white ).
If you do; unplug TV (reset, reboot) from A/C outlet for 3 to 5 minutes. If still no work try these suggestions:
1. Make sure the TV's internal speakers are turned 'ON'.
2. Make sure the "BOX" ( cable, sat, u-verse) volume is turned up all the way up.
Good Luck, big IRISH.
Aug 16, 2008 | Televison & Video
Volume on tv set not right
Try unplugging the TV for 2 minutes then try again.
Feb 09, 2007 | Sharp 32C-240 32" TV
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
