Question about KitchenAid KBMS1454SSS Microwave Oven
KBMS1454sss-1 The digital display is only partially lit. Oven works in all other respects.
I also have a Sharp Carousel Microwave oven model # R-409AK in which the clock/ timer digital display has become faint and can not read the time. The microwave part works fine otherwise. What part do I...
It is a display panel you require and you should be able to get a manual at the same time.
Try http://www.sharpdirect.co.uk/support/spares-and-accessories/page/spares/
Hope it is helpfull
Feb 27, 2011 | Sharp R-319FW Microwave Oven
GE Spacesave microwave won't work. Display says REM. What does that mean?
"REM" is "reminder". That's covered in your owner's manual.
Here's a sample:
"The Reminder feature can
be used like an alarm clock
and can be used at any
time, even when the oven
is operating. The
Reminder time can be set
up to 24 hours later.
1 Press REMINDER.
2 Enter the time you want
the oven to remind you.
(Be sure the microwave
clock shows the correct
time of day.)
3 Select AM or PM.
4 Press REMINDER. When
Reminder signal occurs,
press REMINDER to turn
it off. The Reminder
time may be displayed by
pressing REMINDER.
NOTE: The REM indicator
will remain lit to show that
the Reminder is set. To
clear the Reminder before
it occurs, press
REMINDER, then 0. The
REM indicator will no
longer be lit."
Jan 27, 2011 | GE Microwave Ovens
Digital clock loosing display
sorry display needs to be replaced, will need service tech
Dec 19, 2010 | KitchenAid KBMS1454SSS Microwave Oven
Blinking display of advantium m/w oven
by unplugging the m/w for a few minutes and then replugging the problem is gone.
May 29, 2009 | GE Advantium SCA1001SS Convection /...
Jenn Air JMC7000ADW
I would consider the
JMC9158BAW this is a 1.5 cubic ft, yours is 1.6, yours is about 24 inches and this one 24 inch, this model is a built in/countertop
the closet model you are going to find
Kitchenaid has the KBMS1454SSS 24inches comes with 27 and 30 inch trim kit
and KBMS1454S same specs just different model
May 01, 2008 | Microwave Ovens
Error code of F-3.
F3H —Humidity Sensor Failure: Refer to the Tech Sheet and test the sensor.
The microwave oven may be provided with a self diagnostic routine that can be operated through the touch pad keyboard. To enter the self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door. You will see the following display.
CHART
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "—" is displayed.
If you want to try to fix it your self, Always remember Electricity is dangerous and should be treated with respect.
Microwaves are very dangerous, they can still shock you even unplugged!!
Use a metal ( not the shiny chrome type ) screw driver with a insulated handle to short across ( touch both at the same time ) the terminals of the high voltage capacitor to discharge it. With the microwave unplugged.
If my attachment made it, it shows a common way to do this....
Good Luck!
Microwaves are very dangerous, they can still shock you even unplugged!! These pages are to help give you indications of what might be wrong and some safe "how to check" or repair help.
Oct 29, 2007 | Kenmore 62702 Microwave Oven
Readout on microwave
This is a problem with the control panel assembly, which we repair nationwide for $39.95. For full details, our site is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Aug 16, 2007 | Sharp R-1502 Microwave Oven
Microwave was fine in the morning. In the evening I noticed that the display board was not lit up. when I turned it on nothing worked. I moved around the cord and pushed and wiggled the oven. The...
Could you explain in more detail what you mean when you said you moved around the cord and pushed and wiggled the oven? I'm concrened about a bad cord or outlet, which could lead to a fire.
Mar 10, 2007 | GE JVM1870 Microwave Oven
Digital display lighting
The solution depends first on the type of display your microwave has. Please refer to the picture. The left side shows a partially defective LCD type display. If you have this type of display, we regularly repair them for $32.50 nationwide. The right side is a VFD type display which is weak due to age. On some brands and models, we are able to get a replacement display tube and repair it to a like-new brightness. Feel free to e-mail me at _ if you have other questions.
Sep 17, 2006 | Frigidaire FMT144G1 Microwave Oven
KitchenAid KBMS1454SSS Microwave Oven Logo
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
