GE Harmony Profile washer, after the cycle has completed, it will fill the washer with water and over flow
  • 15,935 Answers
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the “Load Level”, “Load Size” or “Water Level”. On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½” off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Where is the lid switch located on my GE Harmony washer?
It is usually within the lock mechanism, try putting a small bar or something That look like the bar of door latch thru female mechanism, It should start when activated ( stop It when it´s filling up before There is enough water, you should not get swamp... )
Feb 03, 2015 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE profile washer wont fill all the way with water. Can only wash 2 pants and 2 shirts and its set on extra large load.
A lid switch doesn't regulate water capacity and if the lid switch fails, the machine will not execute a complete wash cycle. If the washer functions but only at partial water fill for the selected load level... then the problem is likely a clogged pressure switch tube or a malfunctioned pressure switch. Got mine used online - fixed the very same issue.
Mar 19, 2014 | GE Profile WPRE6100G Top Load Washer
GE WPRE8100 washer starts to fill and immediately shuts off
I would suspect the washer control panel or timer is the problem.
Jul 25, 2017 | GE Profile WPRE8100G
I have a GE Harmony Profile top load washer. It is stuck on filling during the rinse cycle. It usually stays at 18 minutes for about 15-20 minutes. I usually start adding buckets of water to get it going....
when washers go into rinse cycle they use cold water so the clothes don't rinkle,i would say that you have a bad water valve located on the washer,you can try to run the wash at the beginning just with cold water,if the water comes in slow you have a bad valve,you can then run it on just hot water and see if there's a difference in how fast it fills.the strange thing is that it should pop up with an error code after 6 or 8 minutes because the washer is filling to slow,have you seen any codes come up?if it is the valve the part number is WH13X10017 and that valve is under the top console
Nov 10, 2017 | GE WPGT9360EPL Top Load Washer
Two problems . . . . 1) the detergent dispenses into the wash but when I go to do the next wash, the place where I put detergent in is filled with water????? 2) the washer doesn't seem to be putting enough...
You may have sediment in the valve screen or the valve just won't open completely. In either case i suggest replacing the valve. Your 2 problems are both associated with low flow from the water valve.
Mar 04, 2010 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Not enough water to wet all the clothes.
Either the water level switch has bad calibration or the water level tube has lost its air seal and needs to be refitted and air locked. If you do not know how to go about these tasks, call someone with experience. Goodluck, Macgivor
Jan 16, 2010 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Error message only prior to the rinse cycle,not filling correctl
The cold water solenoid valve seems to have failed on you. They're easy to replace and can be purchased at any appliance parts company
Jun 15, 2009 | GE Dryers
GE Profile Harmony not draining wash load
HOW OLD IS YOUR WASHER? IT SHOULDN'T COST THAT MUCH TO REPAIR IF YOU CAN'T FIX IT. IT SOUND LIKE YOU MIGHT HAVE A PROBLEM WITH THE BELT OR MOTOR COUPLING. I DO NOT WANT TO TELL YA WRONG. I JUST HOPE YOU CAN GET YOUR PROBLEM FIXED. TRY TO CALL A REPAIRMAN SOON. GOOD LUCK.
RODNEY
Mar 27, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
