Sounds like a half shaft. Reach around behind each wheel and see if there is play in the shaft that leads from the wheel to the transmission. There should be no play. Other possibility is a bearing hub. Jack up car, grab the tire at 9 and 3 o'clock. Shake wheel if there is movement not from the tie rod then it is the bearing hub.
If a washing machine is rumbling, and very noisy on spin, the main
suspect is the drum bearings. Drum bearing failure is common on many
washing machines due to water getting into them if the drum bearing
seal fails. (Hotpoint and Zanussi in particular in my experience) To
check for drum bearing failure you can take the belt off and spin the
drum by hand. If the drum rumbles when spun then the bearings may have
gone. There should be a constant rumble all the time the drum is
revolving.
Another
drum bearing failure symptom is excessive up and down play in the drum
which can be checked for by lifting the drum up and down from the drum
lip behind the door seal. A further symptom of drum bearing failure can
be a brown rust patch underneath the washing machine and down the back
of the outer drum, underneath the drum pulley (where the belt goes)
although this patch is not always present. There are usually two small
holes at the back of the drum bearings where water that has got past
the drum bearing seal trickles out, and it's usually stained with
grease and rust if water has got into the bearings.
Loud
noises when turning the drum by hand can also be caused if the drum
itself splits, or the spider at the back of the drum has come away from
the drum, is corroded or even broken. This would normally be a loud
noise on each revolution of the drum whereas the noise when drum
bearings have gone is constant all the time the drum is turning.
Lifting the drum checking for excessive play can often reveal a broken
or loose drum spider which sometimes only occurs at certain points
round the drum (the spider has three arms and is bolted to the drum at
three points)
Check and see if the cold water has been plumbed to the 'c' on the heater, the hot to the 'h', and the relief valve somewhere else, usually on the side. Maybe the plumber cheated somewhere to make installation easy.
need a little more detail here. Rumble from front? rear? left or right side? And shake in the steering wheel? How big a bump and how fast were you going? Was the rumble instant after the bump? Is it constantly making the noise or now and again?
The drum support rollers are worn. This will cause loose belt tension and a rumbling sound. You will need to pull the drum to find the rollers at the lower back of the drum. Check the roller shafts for wear and replace them at the same time as the rollers if needed. Check the belt and tensioner for wear before reassembly. This should fix ya...
this sounds like the main bearings have worn out (they start to rumble first) when they start to brake up they rip apart the water seals that are between them and the back of the washers drum, and then it starts to leak water, to test them to see if there claped out,,,, open the door and try lifting the top of the drum lightly , if it lifts a bit then drops back when you let go its the bearings going, now spin it by hand and you will here a rumbleing noise or grinding noise, when the washer is running on spin it will sound like the end of the world is coming???? im sorry to tell you this part is not cheep to fix, its 2-3 hours work?
The rumbling noise is the steam generator working - make sure the water reservoir is full and press the on button. Inside the machine will be doing its stuff and generating steam - this is the noise that you are hearing and when you press the release switch (normally under the handle of the iron) then the steam will be expelled. The noiose comes on and off as it is making more steam - this is normal. I use ordinary tap water but don't have hard water so have no problems - also make sure you empty out the base occassionally - should be a large pressure screw behind the cable holder - make sure iron is off and cold before doing this and then shake it out and residue bits will come out - then flush out with water. These are brilliant to use and you will wonder how you managed before having this - Happy ironing.
Make sure your spray arms are not loose first.If it remains loud you may have something caught in the food shredder area that is making motor strain/rumble.Also make sure to look under the machine to see if anything(water line-Drain hose) is touching the motor which will sometimes make some unusual sounds.
