Question about KitchenAid KBMS1454SSS Microwave Oven
Kitchenaid KBMS1454sss-1 digital display only partially works
Micro works but you have to guess on what it is doint since the numerical display is only partially working.
2 Suggested Answers
SOURCE: hello sirs l have an kitchenAid microwave
Most often when a MW oven will not go, it is to do with the Magnetron and or the High voltage Diode breaking down under load, and or the power supply.
The absence of any indication of power also indicates a problem with the internal power supply, either the fault, has caused the power supply's protection circuitry to shut it down, or the fault has caused the Power Supply to fail as well. It's not really possible to tell until one actually investigates inside the unit.
MW's are very dangerous to service and these especially are best left to the professionals.
You need to contact the KitchenAid head or local office, and ask for a referral to an authorised service center, now when here, ask for a 'Quote" for the repair before allowing any repair work to proceed. this way you can make an informed decision as to repair or replace, as with many repairs, it can all quickly add up.
Posted on Nov 11, 2010
Sharp R-9H84B-display black, cleared display shows "Conv Mix, 88:88 Auto". Short time all dark again. Hit clear happen 2 times then, all dark, no power, can't clear won't start, nothing works.
R-9H84B - May 29, 2017
I would suggest pulling the control board out and looking on the foil side (opposite the component side) for "ring cracks," most likely on the low voltage transformer's connections.
The board may have the screen-printed reference designator "T1" near the low voltage transformer.
Also be sure the fuse is not easy to turn with your fingertips when it is in the holder. If it is, the fuse holder is too loose and must be replaced (not just squeezed with pliers).
You can order a fuse holder, part number WB06X10034 for $6.49 (subject to change) from the Pros here.
If you have any keypad issues, please note that the membrane keypads for this model have long been discontinued.
FixYa does not directly notify us experts of responses, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 28, 2017 | Sharp Microwave Ovens
There is power supply to the micro however when turned on sounds like microwave is working before any buttons pressed and no buttons work when pressed. Also when door is opened display light comes on and...
Without a make and model number it is difficult to guess.
If the door switches are faulty, odd things will happen. I suggest they are checked first of all.
Feb 15, 2011 | Microwave Ovens
Digital clock loosing display
sorry display needs to be replaced, will need service tech
Dec 19, 2010 | KitchenAid KBMS1454SSS Microwave Oven
KitchenAid KCM2145JSS-1 built-in Doesn't Heat
Everything working is a real good sign. Most likely all thats wrong with your unit is a blown fuse. Go to http://www.partselect.com/MultiModels.aspx?ModelNum=kcms145j&SearchTerm=fuse&RefineSearch=0 and you will find the fuse. It's behind the touch pad with most all the other workings. Very easy to replace and cost only $11.76. It looks like an old round glass car fuse but it's made just for micro waves. It's most likely a 20 amp fuse. To get to it, take all the screws out from the back that hols the case on. once you have removed the case you will be able to locate the fuse. Good luck.
Dec 19, 2009 | KitchenAid KCMS145J Microwave Oven
Jenn Air JMC7000ADW
I would consider the
JMC9158BAW this is a 1.5 cubic ft, yours is 1.6, yours is about 24 inches and this one 24 inch, this model is a built in/countertop
the closet model you are going to find
Kitchenaid has the KBMS1454SSS 24inches comes with 27 and 30 inch trim kit
and KBMS1454S same specs just different model
May 01, 2008 | Microwave Ovens
KitchenAid KHMS155L 1000 Watts
According to the owner's manual for model KHMS155L:
To Lock/Unlock Control: The microwave oven and Timer must
be off. Touch and hold START for 5 seconds until 2 tones sound and a lock icon appears on the display. Repeat to unlock and remove the lock icon from display.
You can download the manual here:
http://www.kitchenaid.com/custserv/service.jsp
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 16, 2008 | KitchenAid KHMS155L Microwave Oven
Readout on microwave
This is a problem with the control panel assembly, which we repair nationwide for $39.95. For full details, our site is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Aug 16, 2007 | Sharp R-1502 Microwave Oven
KitchenAid KBMS1454SSS Microwave Oven Logo
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
