A/c will not turn on at all gives me error codes F0 and F6. The brand is Comfortair CSD-12Y3.
  • 691 Answers
I cannot find your aircon unit anywhere. Changchong manufacture a CSD12Y3. I cannot find any support on that either. Because the unit flashes from F6 to the fan It would suggest an error with the fan.
Check the motor and PCB for errors.
Posted on Jan 13, 2013
2 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: i'm getting error code F6
F-6 High discharge coil temp. due toover charged /condenser coil blockage/less rpm of fan motor in outdoor/non-condensate gas.
Purge out over charged gas/clean condenser coil/Replace fan capacitor./Releaseall gas and flush out the system,replace filter drier and vacuum & do gascharging.
Helpful?
Posted on Dec 31, 2010
Code f1 f3 f6
virtual machine - VNC send Ctrl+Alt+F1-F6 to server - Unix ...
unix.stackexchange.com/.../vnc-send-ctrlaltf1-f6-to-serv...
Stack ExchangeMar 15, 2012 - Hence I can switch to the TTY's if my CTRL + ALT + F1 - F6 ... As I understand it, you want to send CTRL-ALT-F3 to the remote .... What numeric keycodes do I need to send for the magic sysrq functionality in a VNC session?
error code f1 dishwasher model gldt696tss 00 KVM Switches
www.fixya.com > ... > error code f1 dishwasher model gldt696tss 00
KVM Switches error code f1 dishwasher model gldt696tss 00 questions and ... 6F 23 20 F1 01 = F2 46 B1 59 04 61 77 71 Telewest 00 = 75 4A 66 04 CF 7F 55 F3 ... ...96 F6 1F C4 01 = 6D EA BE 97 6A AA DA 71 NTL 54 01] 07/10/09 00 = F0 ...
kleenmaid f6 code KVM Switches Questions & Answers - Fixya
www.fixya.com > Forum > Tags > kleenmaid f6 code
KVM Switches kleenmaid f6 code questions and answers. ... 01 = C6 64 1D EF 47 5A 0E EF tellywest 00= B7 DE 73 DE 2F A4 F3 BO 01= FA 4B 82 4C ... ...in bradford area plz 5a 01 83 5D 12 B8 96 F6 1F C4 6D EA 8E 97 6A AA DA 71 Hope ..
Jan 27, 2016 | Computers & Internet
What is an F8 error code meaning? Thanks!
From this website ::
http://www.ehow.com/facts_7597003_maytag-range-error-codes.html
Codes "F0," "F1," "F5," "F6," "F7," "F8" and "F9" are all various errors with the Maytag electronic range control, or ERC. The errors are various faults with the ERC and a replacement part is needed for the range.
F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) More info, let me know. Charlie
Jul 26, 2011 | Maytag MER5775Q Electric Kitchen Range
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
Dec 18, 2009 | Ovens
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Starview ntl codes 7/10/09
ntl (5401)
key 00 = f0 0e 91 e0 2d c1 c5 fd
key 01 = f0 cf c3 01 f1 2d ab b8
Oct 07, 2009 | StarTech.com StarView SV211K 2-port KVM...
Starview gone off need codes for 00 01 7/10/09 can any1 get the codes plz
C & W 5C 01] 07/10/09
00 = BC B6 BB DD 97 AD 11 63
01 = D2 D1 80 FA 21 85 0F 53
Telewest 5A01 07/10/09
00 = 83 5D12 B8 96 F6 1F C4
NTL 54 01] 07/10/09
00 = F0 0E 91 E0 2D C1 C5 FD
01 = F0 CF C3 01 F1 2D AB B8
Eurovox code
ntel.
0,3F B8 36 62 72 E5 E2 76
1,35 5E D6 40 6E AA 99 41
tw.
0,C0 F6 61 87 91 F9 67 57
1,F0 83 35 E5 28 40 49 B2
Dec 10, 2008 | StarTech.com StarView SV211K 2-port KVM...
I need help
U DIDNT SAY FOR WHAT PROVIDER U NEED???? telewest or ntl or c+w?/???
telewest codes 5th dec
5a 01
c0 F6 61 87 91 F9 67 57
F0 83 35 e5 28 40 49 b2
if ure not telewest send me a request and tell me if ntl or c+w and ill give u codes
Dec 05, 2008 | StarTech.com StarView SV211K 2-port KVM...
Starview 3 codes tele 4th dec
4 th dec
tw
co f6 61 87 91 f9 67 57
f0 83 35 e5 28 40 49 b2
Dec 04, 2008 | Audio Players & Recorders
TW Code Starview
New New codes for tw at 17.30 4/12/08
00=co f6 61 87 91 f9 67 57
01=83 35 e5 28 40 49 b2
Dec 04, 2008 | StarTech.com StarView SV211K 2-port KVM...
Heating & Cooling Logo
412 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
