Question about Sony 1GB Memory Stick PRO Duo Memory Card
What could have happened to my memory stick pro duo? I took pictures and was able to view them perfectly fine. When I went to deveolpe them I put the stick in the wrong slot that was too big. The sti
There are a few scratches on the back where the white horizontal strip is -but doesnt look like anything major. Help! I have a lot of memories on this stick... Is there anyway to be able to view them?
  • Sony Master
  • 32,281 Answers
When you plug this memory stick into your computer and the computer cannot detect this memory stick then the memory stick is damaged and your photos cannot be retrieved.
Posted on Jan 11, 2013
5 Suggested Answers
onyeredson
  • 404 Answers
SOURCE: How can i fix my memory stick pro duo if the computer does not detect it?
Hi Guy's!
Don't brick/bin it It is probably fine Your P.c. can possibly only read a Max of 2Gb so buy yourselves an external card reader that can read up to 8Gb or more and your back on the case.
There you Go FixYa'd
Paul 'W'
Onyer~EDson(:0)~[>< U.K.
Posted on Jan 09, 2009
Geekman
  • 32281 Answers
SOURCE: memory stick pro duo sony won't read
Files on a flash drive and memory cards in a card reader can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the memory card and flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Posted on Nov 19, 2009
  • 7 Answers
SOURCE: Memory Stick PRO Duo is write protected
I had this problem and figured out a easy fix.
1. Take out memory stick from psp
2. Plug in usb to psp and start usb connection
3. Psp will recongnize there is no memory stick inserted
4. Now insert your memory stick and your good to go
For some reason you might have to repeat these steps everytime you want to access your memory stick.
Hope This Helps
Posted on Jan 23, 2010
SOURCE: my laptop cannot read memory stick pro duo 2gb
same problem here The driver is recognized but not opened
Posted on May 27, 2010
Camera keeps telling me to reinsert the memory card. I&#39;ve tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
My sandisk memory stick pro duo wont work anymore
I have a Sony Cybershot DSC T70 and it keeps saying "Reinsert memory stick" whenever I turn on the camera or slide down the camera lid. Also, whenever I try to view the pictures on my laptop it shows "Please reinsert the memory stick" something along those lines. As I have been researching for the solution, I would have to format the memory card. However, I wouldn't want to lose the pictures as I just took many as from the holiday last week. The only problem is the memory card, I tried using another memory card and it works fine with the camera. There is nothing wrong with the camera.\r\nCan someone please help me how to solve the memory stick problem? It would be great. Ty.
Sep 11, 2009 | Sony Cyber-Shot DSC-P92 Digital Camera
Will not allow me to view pictures I just took
Try to recover what is left on the memory stick with TestDisk on a pc.
Note, download the windows version and not the dos/windows version, the
dos/windows version is for windows 3.11 and lower.
http://www.cgsecurity.org/wiki/TestDisk_Download
Try to fomat the card afterwards if this does'nt help at all try another card in
your camera, if the other card works replace your other card else get te camera autorized repairs man.
Succes.
Aug 28, 2009 | SanDisk 4GB Memory Stick PRO Duo Memory...
Pictures stored on card, and unable to retreive them on camera
Have you tried accessing the pictures via a card reader connected to your PC. It is possible the card is damaged and you will not be able to recover your pics. But it is worth a try. If you do not have a card reader take the card to a camera shop and see if they can see and manipulate the pics to another card, then reformat the card and reinsert it to see if it then reads anmd writes.
Jul 22, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
My sony memory stick pro duo doesn't work
It sounds like the software on the card has suddenly dissappeared. Try downloading the software from sony back onto the card. Let me know if this helps.
Jun 19, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Error Viewing pix
Do not use a Memory Stick Pro Duo - High Speed , use a Memory Stick Pro Duo below 2 GB
Apr 16, 2009 | Sony Cyber-shot DSC-W90 Digital Camera
CAN NOT VIEW PHOTOS OR ADD TO MY PICTURES
The picture must be a j-peg file or the memory stick is a fake
thats why it wont work i have go through that technical problems i try and try it and the i figure it out !!!!
Jan 11, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
Memory card.
Supported Flash Memory Cards: CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, Microdrive, MultiMediaCard, SD Memory Card, Memory Stick Duo, xD-Picture Card, Memory Stick PRO Duo
Your phones card is a RS-MMC type not combatable, wont fit, no eject on printer, card too small for slot, wrong type
Power off carefull tweezer hunt or bluetac on a match, happy hunting
Oct 19, 2007 | Office Equipment & Supplies
File error
I have seen this problem with generic SD memory cards so it could be a faulty memory stick.  Try to get a replacement.  If you want to try to recover the pictures you have taken, I suggest Zero Assumption Recovery (Google for it). Check to see if it is compatible with your camera before downloading.
Barry
Sep 17, 2007 | Cameras
Sony 1GB Memory Stick PRO Duo Memory Card Logo
54 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Computer Links
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
