Question about JVC JLE32BC3001 32 Class LED HDTV - 1080p, 1920 x 1080, 16:9, 60Hz, 20
I have no picture and no sound. it does not even turn on. I tried plugging in to different outlets. nothing.
Its only a year and two weeks old. It was working fine then all of a sudden nothing.
  • 1,238 Answers
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Please rate
Posted on Jan 06, 2013
Display not working, power button LED turns on blue for 1 second and won't turn on again
Have you tried checking with another monitor. Meaning that if the second monitor does not come on then the problem is with your computers mother board. But if the monitor other monitor you check it with comes on then of course it is your monitor.
Jun 12, 2016 | Acer 22" X223w LCD Monitor
Amana refrigerator sparked by plug and now won"t turn on even when plugged into another outlet with extension cord should i repair or replace?
i am in the uk so i dont no if this will sound right,but have you tried changing the fuse in the plug of the fridge? make sure you put the same size fuse back in.
Oct 12, 2017 | Kenmore Refrigerators
Panasonic viera TC-L42-U22 will not turn. No lights, no sounds, nothing happens... only 1.5 year old. Any suggestions?
There is a primary power supply failure, probably a fuse blown. This is a case to be handled by a qualified service technician.
Jul 17, 2012 | Televison & Video
For the last 2 weeks our PVR has worked fine only about half the time. It will suddenly cut out: picture and sound disappear and the pushing the MENU button the produces zip: no signal strength screen or...
Sounds faulty to me (especially if it has been working fine for the last few years), i'd get it replaced, some of the new TiVo boxes are insanely good, and well worth checking out despite their also insane prices.
Thanks,
Moza805
Aug 30, 2011 | Televison & Video
My 12 year old plunge router 7529 does not start. It worked just fine a couple of days ago and all then sudden... nothing. Any suggestions!
A 1 year old router...that suddenly stops working. My suspicions would be brushes first then the switch.
There are 3 different types of this router Type 1, 2, and 3.
Parts can be found here:
http://www.ereplacementparts.com/porter-cable-7529-type-plunge-router-parts-c-129_1672_1985.html
Brush is item 3 and switch is item 4.
pdf of diagram: http://www.ereplacementparts.com/images/Porter_Cable/7529_TYPE_1.pdf
Thanks for choosing FixYa,
Kelly
Kelly
May 11, 2011 | Porter Cable Garden
We had 52' HD JVC Tv for 2yrs and the other day, the power button was flashing and didn't have a picture and now it won't even turn on. We tried unplugging it for a while and still nothing
This can be a power problem it can be a power problem inseide the tv or a power distribution problem from your power outlets. So before you send this to a repair shop you can try to plug the tv to a different outlet by using an extension cord. I understand that you have tried to unplug the tv for several minutes but plugging the tv to a different plug in can make a difference.
Sep 09, 2010 | Televison & Video
Kdf42-we655 works for awhile then no sound or picture - standby light flashes for awhile then turns to red and flashes in sequences of 5 - then after a short bit tv comes up and works for awhile again. tv...
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 21, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a Kenmore Ultra wash dishwasher model # 665.13692K600. It was working fine one day then all of a sudden I have nothing. No lights no nothing. I have tried shutting the breaker off and it didn't...
You probably blew your thermal fuse that is attache to the main circut board, you can buy the thermal fuse seperatly. it is located in the console.
Sep 14, 2009 | Dishwashers
JVC JLE32BC3001 32 Class LED HDTV - 1080p, 1920 x 1080, 16:9, 60Hz, 20 Logo
55 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
