Question about Sharp 52"" aquos lc-52d65u 1080p widescreen lcd hdtv - 16:9 10000:1 d
Green light blinking on my sharp aquos tv
I unplug my tv count to 30 and push in the channel down and volume up and then connect it back. Sometimes the TV will come on for about 2 seconds. What will cause this? It then starts to blink again. How do I fix this problem?
  • Angel Jan 06, 2013
    It blinks one every second.
  • 1,238 Answers
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Posted on Jan 06, 2013
3 Suggested Answers
eagle338
  • 4889 Answers
SOURCE: My Sharp 39" AQUOS will
How many times does it blink in between each pause? Please provide this info as its a self-test diagnostic that will help resolve the issue.
Posted on Apr 30, 2011
SOURCE: blinking green light on LC-52D65U Sharp Aquos
How many times does it blink?
Mom's Sharp Aquos TV no sound or picture there is a green flashing light where the power light is I heled the volume up and channel down while the TV was unplugged. plugged it back in sound no picture
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 24, 2016 | Sharp Televison & Video
Sharp Aquos TV doesn't work, power light is blinking at 1 blink/sec
Sounds like a fault code, ~I have found some info on it:-
The frequency and color of the blinks will indicate the issue. There is a hold-down button sequence to try to backdoor your way into the set to see if the panel will light. You may have simply racked up too many "weird tuner faults" and need to reset it. My suspicion is that it's either that or bad panel backlight.
Unplug set, press and hold (on set) volume-down and channel-down and hold them while pluging in set. Will come on with "k" on screen, or will crash again if backlight bad. If it stays on, use your remote and arrow right then look for "fact init" and any other reset and turn them on. Arrow back up to "fact init" and hit enter. Let set recycle to green and unplug/re-plug in 5 seconds: the set should be in OOB state.
hope it helps
Aug 23, 2014 | Sharp Aquos Televison & Video
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
My sharp aquos won't power on
CHANGE IC202 WITH TL431 OR TRY PUSH INPUT AND VOLUME DOWN THEN PLUG THE POWER UNTIL THE GREEN LIGHT START ,,, WHEN IT START PUSH VOL DOWN AND CHANNEL DOWN AT THE SAME TIME AND PLAY WITH THE SETTING
Apr 20, 2013 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
60' Sharp Aquos tv power bar flashing but TV wont turn on. Any help??
Good day!!!
please try to count the exact number of blinking lights to diagnose where the fault came from..
Also try to open the cover and look for any bulged capacitors on power supply board..
Dec 04, 2011 | Sharp LC60LE810UN 60 in. LCD TV
I am not getting picture on my TV it stic on only one channel we are chengiong channel but same sound is comming also we are getting a blue coloured K on right hand side of TV
That blue K means you are in the service mode. Unplug your set and wait 30 seconds. Then at the same time you plug it back in, you need to be holding the volume down button and the input button.
The TV should turn back and the blue K should turn pink. Once this happens, press the volume and channel down button at the same time. A menu should come on the screen. With your remote, press the up arrow to reach the nest page. The first option should say INIT. Arrow to the right and hit enter. In a few seconds your screen should turn green and say success. Unplug the TV and wait 30 seconds. Plug the set back in and turn on your TV. You can then set your set back the way you want.
May 04, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Lcd sharp tv flashing green light
Try unplugging the unit and while unit is unplugged hold the volume up button and channel down buttons down and while depressing both buttons plug the unit in. Let go of the buttons and the unit should come on in the service mode. There will be a small k on the screen. With the sharp remote press the channel up button once. This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. User channel down to highlight that line and curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. I hope this corrects the problem. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged by the surge.
Jan 06, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Small Green K on the screen
With your tv on and the green K box on your left.
*unplug your tv from the outlet
*HOLD DOWN the (Volume - and input)
*Holding down the (Volume - and input) plug tv in
Tv will power on.
Now Tap the (Volume - and Channel -)
you will go in a menu tv mode
with the "remote" hit the down in the arrow (not channel or volume)
Now hit (volume +) and the tv will get arrows ex.(/////////)
The tv will turn green "meaning it was resetted"
Unplug tv from the wall.
Wait (30 Seconds)
Turn tv back on.
Since the Tv was resetted, go through the initiative Welcome startup screen. (Pick your Language, etc..)
Dec 26, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LCD LC-46D64U
Try resetting the TV. Here's how to do it - Unplug the TV's power cable. Keep the Channel Down and Volume Up buttons on the TV pressed and plug the power cable back into the outlet. You will hear a click when you plug it back in if the reset is successful. Hopefully this should restore your video and audio.
Dec 25, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Power on problems
this worked for me before, but now the problem came back after being fixed for months! unplug the two connectors at the back of the tv, the ones that look like computer monitor cables. then go to top of tv and use manual controls, turn off main power, then turn on while holding input and vol down button, a small service menu will come up, use the channel up down button to go to test, then push input button, there should be a box with reset and some number in red. use the vol buttons to reset to 0, then power off.... reconnect the cables and then turn on the tv.
Nov 22, 2007 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Sharp 52"" aquos lc-52d65u 1080p widescreen lcd hdtv - 16:9 10000:1 d Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
