Question about Lands Phones
I have a eircom 7000 twin phones as we stopped using them for a while took out batteries now they are needed again cant remember what type of battery to use as the plug into a charger do i need to use rechargerble batteries or will ordinary alkalines work
SOURCE: Vtech 8L55 2 unit portable phone
I just had the same problem. Could be dirty terminals. I took the battery out, cleaned the terminals on the battery and phone with a pencil eraser, put the battery back in and it's working fine. (Says fully charged, where just a few minutes ago it said low battery).
Posted on Nov 09, 2007
spare_head_2
  • 47 Answers
SOURCE: SIEMENS GIGASET A160 TWIN CORDLESS PHONE
It's not an easy website to navigate, but if you look hard the all the information is available.
Is this the page you were looking for Graham?
Regards,
Spare head 2.
Posted on Jan 04, 2008
GrinningFool
  • 625 Answers
SOURCE: sidekick 3 battery problems :(
You may need a new battery.
You can get Sidekick Batteries on ebay for about 10 dollars.
Sidekick 3 Batteries for Sale
Follow the procedure below to recalibrate the battery meter when you get it.
Try this to recalibrate the battery meter if you get a new one. This trick really only works within the first week of use. If you've used the device for 2 months already, this won't help as much (but it'll still help). Keep in mind, when I say "train the battery," I mean RECALIBRATING THE BATTERY METER:
A) I cannot stress enough that the initial charge out the box is crucial. Instructions state you should charge the device 6-8 hours upon initial start up. Most people are so geeked by getting the device that they yank it off the charger 3-4 hours later so they can go out and floss their sidekick. HUGE mistake. Despite evey urge to do so, let it charge at least 6 hours out the box.
B) Now, for the next couple of days try and let your device totally drain out it's battery before you charge it again. I've had a couple nights where I come back from work with the device already dead (Sucks for my commute, but well worth it in the long run). When you finally do plug it in, make sure it charges 4-5 hours minimum before you remove it. I usually leave them plugged in overnight...
C) You'll begin to notice an improvement in your battery life. Your device now has new "baselines" for when it's full and when it's not. Keep it up for another day or so (but don't waste an entire week doing it) and then you're set. Sometimes I would bypass the old automatic cutoff for charging by charging it while off just to make sure I "topped it off" (NOT reccomended for consistent charging, tho').
Posted on Jun 23, 2008
  • 157 Answers
SOURCE: Midland rechargeable battery packs won't recharge and vibrate
Hello batterbum, from the info you listed you have the right battiers & charger, with alkaline the radios work leads to wrong or a bad batch of Ni-MH battiers. Vibrations from a battery pack states too much current being drawn for battery capacity. Note: depleting a battery and recharging with a charger will place the battery in a false full charge state. Recharging a depleted battery with a DC power supply with current limit can reboot the battery to a 90% cycle. I suggest returning battiers for correct replacements, if they are correct 'by the book' ask for the highest in mAhr specs. Please inform me of your outcome. Good Luck
Posted on Nov 07, 2008
  • 17 Answers
SOURCE: maxxum 7000 camera lithium battery
The above posting is correct, and the cell is a CR2016. The main batteries are removed by unscrewing the battery holder on the right grip. Most Maxxum 7000's have AAA's, some have AA's, and if you have the lithium holder, it uses a 2CR5, available at the photo shops / pharmacies.
-John
Posted on Mar 16, 2009
Can batteries be replaced in the 7000 series shavers when they are no longer able to take a charge?
You can change the batteries in 7000 series shavers. You will find the correct battery type at shaveroutlet.com. See link below. You will need two
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Scroll down the page for installation videos
Aug 18, 2011 | Braun 7000 Series Foil and Cutterblock
I have for gotten how to make the machine sew and im having trouble threading a bobbin for my moms machine elna 7000 i need a manual or a quick note to get started
YOu can down load a manual from here http://www.arizonaexpressionz.com/elna_instruction_manuals/Elna7000.pdf
Just remember to click the bobbin thread into the tension device correctly and hold the two threads behind the pressure foot when you start each seam - Elna top loading bobbins give great stitch quality but you just need to keep stray threads out or they'll jam up.
Also, you must use the Elna plastic bobbin that the manual specifies for this machine - the 5000, 7000 and 9000 were Elna Tavaro Switzerland's first foray into computerised machines and first released in 1986.
Also, please check the manual when you go to buy twin needles, there are two types now as computerised machines usually need the twin needles offset from the shaft position. They have red or black plastic block between the shaft and the twin needles - I think you need the red ones but just double check the manual to make sure. And you can't do all the wide stitches with a twin needle as it will strike the foot.
Hope this helps a little.
Jan 16, 2011 | Elna 2007 Mechanical Sewing Machine
Notice for sagem 7000 eircom missing - how do you set up mailbox (answering machine0?
My Sagem Eircom 7000 handset is not charging properly when put back on the base. It usually gives a little bleep when you do this but does not at the moment. It charges for a short while but then it bleeps slowly and cut out when in conversation. Can you tell me you to FixYa!
Frankie
May 13, 2010 | Lands Phones
My Maxxum 7000 won't power up with new batteries
Good Afternoon,
it's very possible that you're still having a battery supply issue. When the battery compartment is tipped out to replace the one inside AAA battery you'll notice a small sliding contact it's very easy to overlook. I would suggest cleaning always contacts again using vinegar. Then wash it off completely, dry well and then reattach your batteries and try it again. Remember that the battery box has to be firmly in place and the retainer screw completely screwed in to activate the switch on the side of the camera to allow the camera to function. If you try this and it again fails it's also possible that your particular maxim had a used metering link installed just underneath the battery compartment that metering link can also fail when it does get acts as a crime or refuse and the camera won't function. The last thing I would check would be your primary backup battery which is located under the stainless steel plate that your batteries set up next to on the side of the camera it's held in the position by six screws. This is a 2025 battery and is easily replaceable. Please be sure and check your power supply first as this is 90% of the problems that we see in the shop good luck if you have any other issues feel free to contact me directly at Dave@advancecamera.com
Jan 15, 2010 | Minolta Maxxum 7000 35mm SLR Camera
For my mac g4 first generation, i bought a Ati radeon 7000 PCI. the goal was to stop using my original graphics card and use the ATI radeon 7000 for my main and only screen but when i start up with my...
hello...the way is try to open the Bios Settings then disable the on board video then set primary AGP/PCIE slot Video Card to run then try again to install the video card driver but 1st you need uninstall the old driver..thanks and Good Luck..have a nice day..^_^
May 12, 2009 | IXMicro ix3D Dual Monitor (8 MB) Graphic...
Maxxum 7000 camera lithium battery
The lithium button cell is under the metal plate where the battery holder attaches. There are six screws holding the plate to the camera. I believe the cell is a CR-2025.
That being said, replacing the lithium battery will only restore the cameras ability to remember your settings and frame counter when the regular batteries are not on the camera. It will not restore functions of the camera.
If the camera is not functioning properly, you have a power problem with the main batteries, not the memory backup cell
Mar 21, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Cu 400 battery cover
just go online and go to google and type lg cu400 battery cover and somthing shold pop up
Dec 13, 2007 | LG CU400 Cellular Phone
Minolta maxxum 7000 35 mm camera
I had the same problem. After I replaced the lithium backup battery, everything works perfectly. It is a CR2016 watch battery and it is located behind the silover plate inside the battery compartment. Remove the 6 screws and replace the battery. Note the polarity when you remove the plate because the camera will not operate if if it is put in backwards.
H
Nov 14, 2007 | Minolta Maxxum 7000 35mm SLR Camera
Nov 06, 2007 | Vtech IP8100-2 Twin Cordless Phone
Lands Phones Logo
57 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
