Question about Jensen A600HLX Car Audio Amplifier
Need Help Well I got a Jensen A600HLX Amplifier that is weird. I hook up all the power sources right but when I hook up the RCA wires and the subwoofer. All the subwoofer does is make a thumping sound every 5 seconds. Do I have to hook up RCA wires in the input and output slots or just throw it away. Help Me Please.
    Problem Solver:
  • 6 Answers
You most likley have a weak ground or your power wire is to thin
Posted on Nov 08, 2008
  • 113 Answers
Input and output slots???? is it playing although thump present,low current could be the problem check for good connections as well as adequate wire guage.
Posted on Aug 08, 2007
SOURCE:
How should i run my Jensen A600HLX Amplifier if i am using it to power 2 10inch Rockford P1 Subwoofers?
U need to check the impedance of your woofers .If they are 4 ohm i would reccomend hooking them in series, which is the positive output of your amp will go to the positive of one woofer, the negative of that woofer goes to the positive of your other woofer and the negative goes to the negative output of the amp.If that amp is bridgeable this will give u a good bass and the impedance will be 8 ohm so your amp will run cool and stable
Jul 30, 2010 | Jensen A600HLX Car Audio Amplifier
My sub is making a humming sound
Hey austinpippen,
The noise you are experiencing is due to your rca plug shorting out causing a loop, in outher words, bad earth.
Try getting a noise filter, you take your rca plug and plug it into the noise filter, then wire it to the amp!
you can try a ground loop isolator or relocating your ground [earth].
I hope this helps you out.
Fingers crossed.
Apr 08, 2009 | Jensen A600HLX Car Audio Amplifier
I got it smoking
it would be cheaper and smarter to buy a new one
Nov 25, 2008 | Jensen A600HLX Car Audio Amplifier
Amp stereo hook ups
You need to run RCA cables from the RCA output jacks on the back of the Sony to the input RCA jacks of the Jensen amp. Then you need to run a wire that connects to the blue wire of the wiring harness on the sony to the "remote" or "turn on" terminal of the jensen. That is the wire that turns the amp on when the radio is turned on. It should be on the power wire terminal of the jensen along with the +B (positive) and the GND (ground) terminals. Those are the only ones that go from the Sony to the Jensen. You also need to have the speakers connected to the speaker jacks of the amplifier, and the power wires connected to the power terminal of the amp. The positive power wire needs to go to the positive battery terminal and the ground should be connected to the chassis of the car close to the amplifier. make sure the ground is connected to a clean bare metal part to make sure it is good.
Thats all, but you also need the proper guage wire and make sure no bare wire is exposed to any metal areas or the chassis of the car. You can get all of those things at anyplace that installs car audio. They can tell you the proper guage wire and they have the RCA cables to.
If you are not experienced at this type of installation you really would be better off lettng a professioanl do it for you. It is easy to wire something wrong and damage the amp and/or the receiver.
The wires also need to be run in a place that they will not be damaged and are out of the way.
Ihope this helps you, and please be careful. Help is here if you need it.
If you found this information to be helpful a rating of "FixYa" would be appreciated. It is the only reward we get for the free help we offer.
Thanks,
Dave
Jun 28, 2008 | Tomtom GO 700 GPS NAVIGATION BRAND ONLY...
No remote from Cd player. What to do?
thats a car dvd player right what u would do is to take the back of the unit and look for the female ends of rca's on the unit that they will say rear out put hook them up and run them to the amp and i dont get what u mean about the remote wire but let me no if that helps
Apr 04, 2008 | Jensen A600HLX Car Audio Amplifier
600 watt 4 channel bridgeable mosfet power supply jensen amp
Swap the wires from one speaker to the other to see if it is the speaker or the Amp/wires.
Oct 23, 2007 | Jensen A600HLX Car Audio Amplifier
Help
No. The amplifier gets its signal from the RCAs connected to the "input" jacks, but the "output" jacks are just there to make it easier to add another amplifier. You only need to connect the inputs for the amp to work.
Jun 29, 2007 | Jensen A600HLX Car Audio Amplifier
Jensen A600HLX
check pwm ic 494 or other
Dec 16, 2006 | Jensen A600HLX Car Audio Amplifier
My amp wont put out sound
it's blown....probably, check your connections and make sure your presenting it an ohm load it can handle....so check the sub with a dmm.
Feb 28, 2006 | Jensen A600HLX Car Audio Amplifier
Jensen A600HLX Car Audio Amplifier Logo
171 people viewed this question
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
