Question about Refrigerators
How to change bulb in Kyoto Iceland fridge - Refrigerators
How to change a light bulb in a diplomat fridge
I Googled Diplomat Fridge light bulb and came up with this: Copy www.youtube.com/watch?v=U-yyPGlRoZ0. Go down the page until you come to a video called "How to replace a fridge light bulb". It is there, you have to look.
Jan 02, 2015 | Refrigerators
Fridge was off the other and bulb was blown, anyway after some testing i know thermostat is working however everytime i leave fridge off for about an hour it comes back on, but as soon i adjust thermostat...
With a model number I would help you better, but normally it would be the thermostat that would need to be replaced, its shorted internally.
Good Luck
Nov 01, 2013 | Refrigerators
Kyoto ku88 freezer
given a second hand Kyoto KU88 Freezer, have let it settle; plugged in and on FF, nothing happening - just red light on?
Oct 22, 2013 | Freezers
HOW TO CHANGE FRIDGE LIGHT BULB SAMSUNG rl41ecps
I have Samsung American fridge RS21FCNS and need to change light in the fridge
May 23, 2012 | Refrigerators
Trying to change upper light bulb in fridge
Make sure you unplug fridge from wall power socket,remove bulb cover if one is fitted.Carefully twist or gently try to unscrew bulb. If successful take bulb to electrical parts shop and buy a new one.You may of course use your Fridge until you buy a new lamp,Refitting is simply the reverse of removing bulb.Good Luck!
Nov 23, 2011 | Refrigerators
Fridge and freezer not working on new Maytag, Help!!
at 5 months old don't try to fix it yourself CALL the store where it was purchased or maytag
you may mess up the warranty if you try to fix it yourself
document all of the calls you make to where and who you spoke with at what time
ask for promises in writing have them fax it to you so you have the promise in hand
Dec 14, 2008 | Maytag MFD2560HES Bottom Freezer French...
BUZZING NOISE ON WHIRLPOOL GOLD FRIDGE/FREEZER
YOU MAY HAVE A BAD LIGHT BULB, SOCKET OR LIGHT SWITCH. TRY WIGGLING THE SWITCH TO SEE IF THERE IS ANY CHANGE IN THE BULB INTENSITY. IF NO CHANGE, TRY REPLACING THE LIGHT BULB. IF NO CHANGE, THE SOCKET NEEDS REPLACED.
Apr 08, 2008 | Refrigerators
Refrigerators Logo
111 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
