Question about Coffee Makers & Espresso Machines
Krups xp7240 error code 0A
Error code 0A
4 Suggested Answers
SOURCE: Machine Fault Error No 06
ERROR CODE 06 and/or CODE 07 on the XP7245 model is requesting you to remove the water filter. I had this problem and I called Customer service for the answer. Once you have removed the filter they indicated to allow the unit to go thru set up mode again and then put the filter back in once the machine no longer has an error code.
I didn't actually try it b/c I took my maching back to the store I bought it from only 2 weeks after buying it to get a new one.
Posted on Sep 29, 2008
  • 5 Answers
SOURCE: Error Code 9 on a Krups XP7240 Expresso machine
After I changed piston sealing I get the same error 09. It was caused by missing connection to the thermoblock temperature sensor. In my case both connectors for thermocouple were cracked. They are located directly on the body of thermoblock, below two fuses, covered by rubber housing. After I solder them again on the position error 09 disappeared. Unfortunately it is necessary to open at least front panel of the machine. Moreover I tink that there is also important to save polarity of those two cables.
Posted on Aug 07, 2009
espressonist
  • 1711 Answers
SOURCE: I have a problem with my Krups XP7240, it is
You can just removed the water tank filter (the cylinder inside the water tank) and washed it up. (Actually the filter should probably be replaced). Fix it back in the water tank and tide it safety upon the exit ring.
Don't forget to unplug the machine BEFORE doing this.
Next, restart the machine and let it perform the automatic self testing.
Posted on May 10, 2010
Krups XP7240 error OC
OC can mean faulty communication between the 2 boards, disconnect from mains & try again which you have probably already done. There is only 1 cable from the display pcb to the control pcb and that is to the top front of the side pcb.
OC can also mean the distributor is drawing too much power, if that's the issue just replace the distributor.
Apr 05, 2014 | Krups XP4030 Espresso Machine
Error 0A en xp7240
The sensor is not detecting any heat from the boiler element. Most common cause is the sensor has become unstuck from the front of the boiler. Second most common cause is solder failure and wire is no longer making contact. If you cannot fix it then you need to buy a new boiler so be very careful and make no mistakes about how you plan to fix it.
Feb 06, 2014 | Krups XP7245
I had some water problems with mij krups and try to solve it. Now it gives an error 0D. What does this mean?
I have a Krups XP7240 that came with the same error code (0d). I believe that the XP7240 and the XP7245 is pretty much identical inside. The sollution for me was that the connector to the front was loose. After pressing down on the connector, the machine worked perfectly again.
RuneBune
Feb 11, 2011 | Krups XP7245
KRUPS XP7240 leaking water
My XP7240 has the same problem. I went through all cleaning cycles and the filter in the boiler still gets clogged up with coffee oils. This causes back pressure and blows the boiler seal out. Easy replacement if you can turn a screw driver.
Part number for Seal: MS-5015004. You might as well change the Jack too. (the part that slides into the boiler that compresses the ground coffee. (this is a redesigned double seal unit) Part Number MS-0697072.
Both these parts you can get at http://www.krups.com/Tools/Contact/Contact.htm choose your country and email the parts list. Mine cost in Australia $27.00 including shipping.
Good luck.
May 31, 2010 | Krups Small Appliances Espresso Machine
May 10, 2010 | Krups Small Appliances Espresso Machine
Jun 06, 2009 | Krups XP4030 Espresso Machine
Krups xp7230, no water running through nozzles
Yes, you're machine is identical to the xp7240. Look up the post on leaking xp7240 and follow the instructions on how to open the machine and fix the valve.
Jan 06, 2009 | Krups XP7230 Compact Super Automatic...
I have a 12 month old KRUPS XP7240 coffee maker. It has just ceased to grind the beans. I suspect that the grinder or hopper to the grinder is blocked? Any suggestions how it might be...
You need to open the machine which is easy see my other post on leaking krups xp7240. The grinder can be taken out by removing two torix screws. Probably the electical brushes are gone. Take the grinder engine to a repair shop where they replace them.
May 19, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Coffee Makers & Espresso Machines Logo
81 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
